Help LCD with 2 wire Connect (Idea)
Results 1 to 11 of 11
    Aug 2003
    Care to elaborate to a point where your post makes sense?
    Feb 2004
    Germany
    As Art already said:
    If you are expecting any help be as precise as you can on your request.
    If you can't (or don't want to) giv more details:
    PLEASE DO NOT POST
    in this category
    regards
    Ralph
    Puerto Rico
    Question LCD Idea
    I need to made a Displays Box with Include 4x16 LCD Char and 4 Buttons
    But I going to use only 4 wire 1 Power, 2 Serial LCD, 3 Ground and 4 for the 4 push Buttons
    Is some one have don this.
    Feb 2004
    Germany
    jetpr,
    if one of the four pins that are available is an analog input this shouldn't be much of a problem.
    A few resistors setup as R/2R Network give an excellent DAC.
    regards
    Ralph
    Feb 2005
    Kolkata-India
    Question Specify your choice of PIC
    You should be using one having hardware USART. What is the distance that you would be hooking upto ? Using a DAC / ADC combination to sense four buttons may then be difficult. I personally tend to use the 18F452 because of its speed. You don't miss characters due to overflow. Keep in mind the code overhead in your main processor. If you mention your application in details may be one of my previous code will suite your app.
    Sougata
    Puerto Rico
    Question Help LCD with 2 wire Connect (Idea)
    Ken i Use 4 Resistors of R1=10k,R2=20K,R3=30K,R4=40 AND USE THE
    ADCIN VoltChannel, Voltage
    IF Voltage > XXX THEN THIS IS = BUTTON ONE AND SO ON
    Feb 2005
    Kolkata-India
    Question What about pressing two or more switches at a time
    What if the user presses all the four or any combination of switches simultaneously. Although this can be accomodated in the algo. You still did not reply to my prevoius query. BTW without anymore details or positive outcome I am out of this thread.
    Feb 2004
    Germany
    Quote Originally Posted by jetpr
    In principle yes.
    There are many different ways to set this up,
    it depends on what type of buttons you have.
    if they have NO + NC contacts then you could setup a real R2R Network
    this would allow to detect any combination of keys pressed.
    (more than one at a time)
    The simplest (with primitive NO-pushbuttons) would be:
    5 resistors all of the same value (say 2k2, or 4k7) in series.
    (but if more than one key is pressed at a time you will only detect the one pressed closest to the input.)
    regards
    Ralph
  1. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 04:59
  2. Need help with LCD number display.
  3. LCD will not start
  4. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 12:22
  5. how? 2 wire lcd with pbp?
    By nimonia in forum mel PIC BASIC Pro
    Last Post: - 20th October 2005, 07:41
