hex dec ascii
Results 1 to 7 of 7
Thread: hex dec ascii
    Aug 2009
    Paso Robles California
    Default hex dec ascii
    Below is code to make porta.5 led come on, the "If V1>100 then high porta.5" does not work. I have basically the same code where I send out 28 receive data in hex shift it and then display it on an lcd screen which works fine.
    The lcd allows me to use dec modifier to display to the lcd but the code below v1 without the dec modifier gives me d (tested on lcd screen) which is ascii for 100 but the light will not turn on what would be my best approach here.
    TH:
    SEROUT2 PORTB.2,16468,40,["28"]
    GOSUB SOUT
    GOSUB SINV1
    GOSUB SHIFTV1
    V1 = V1 */$0065
    DISPLAY_TH:
    Default Re: hex dec ascii
    The value is 100 but your IF statements says IF Value is more than 100....
    Aug 2009
    I was just using that as an example to show I was getting ascii rather than dec, I have tried 50 and many other numbers along with = and => but without the dec modifier it just does not work guess I will input in dec and shift and try that
    Jan 2013
    Texas USA
    Can you provide us the values as you step through the routine?
    1. Initial value of V1 from the "GOSUB SINV1"
    2. What the details of SHIFTV1 does
    3. What the value of V1 is before you perform this "V1 = V1 */$0065"
    A little more clarity might help us help you get pointed to the issue.
    TABSoft
    Aug 2009
    its an old program and not sure of the values, the value is correct from them but its in ascii rather than dec when outputed to lcd if I output to lcd dec3 v1 its fine I can put them on the screen side by side one reads d the other 100
    100 dec is d ascii
    Look, a byte variable can hold values from 0 to 255, that's it.
    All this DEC, HEX, BIN and ASCII stuff is just us humans expressing the same thing in different ways, 100=64=d=01100100.
    A character LCD is used to display stuff for humans to read so it "understands" ASCII. If a variable contains the value 100 and you send that to the LCD you'll get 'd' since 100 is the ASCII code for 'd' (exactly as you say). If you want to display the numeric value of the variable AS ASCII then you use the DEC modifier. The DEC modifier does in no way change the value.
    If you do LCDOUT $FE, 1, DEC V1 and the display shows a value of more than 100 then If V1>100 then High PortA.5 statement WILL evalute true and the problem is with controling PortA.5.
    Aug 2009
    OK after HenrikOlsson spanking I started checking from his line of thinking putting in a fast blink between steps and it was hanging at a serin command and not getting value into V! also found I was missing an ADCON1 = %1111
    statement so it is working, guess I needed a slap
  1. HSERIN/OUT Dec to HEX convertion problem..
    By N6VMO_ in forum mel PIC BASIC Pro
    Last Post: - 26th July 2010, 21:48
  2. DEC to ASCII not working in HSEROUT
    By SunDanzer in forum mel PIC BASIC Pro
    Last Post: - 22nd July 2009, 06:11
  3. Converting Dec word to Hex string
    By tcbcats in forum mel PIC BASIC Pro
    Last Post: - 28th August 2007, 05:44
  4. Convert dec/binary to Hex
    By SagemFree in forum mel PIC BASIC Pro
    Last Post: - 11th May 2005, 18:00
  5. Converting Bytes from hex to Dec
    By Rob Martin in forum mel PIC BASIC Pro
    Last Post: - 8th April 2005, 19:44
