12F1840 config issues
Results 1 to 14 of 14
    Lancashire
    Default Re: 12F1840 config issues
    Yes 9600 inverted and the same line works correctly on other PIC types I have tried, its only with the 12F1840 it doesnt
    if you cant check clock with frequency meter.......... add in loop once per second (on serout) increment or decrement osctune to see if characters come in view then try to figure about how far off and in what direction (raise/lower freq)
    amgen
    Try Turning off the fail safe clock monitor, if I understand correctly it monitors an EXTERNAL clock. . .
    I would TRY altering bit 1 in OSCON just to see if it has any effect . . .
    I would add to config1
    _IESO_OFF ; Internal/External Switchover mode is disabled
    and I would disable WDT while troubleshooting at least once to judge if it has any effect.
    Oh yes, I would make a blinky program to test my configs without any serouts . . . a stopwatch using a blinky will give you a rough idea as to whether or not you are running at expected OSC speed.
    Lancashire
    Hi All
    I LED on the same pin configured to blink once per second, does just that so I am pretty sure some configs are right. I`ll try the last suggestions and see before I put in a support message. Many thanks for all the help! Cheers Pete
    Hi Pete,
    Do you think trying to use timer 1 and trying to output serial data on T1 Clkin pin might be in conflict? I don't know, just sayin' . . . Have you tried using another pin, say RA1?
    Lancashire
    That's possible, I am not using timer 1 though so I will look to disable it. Unfortunately this is a PIC upgrade from a 12F683 so I am stuck with using the same pins for this app. I've sent a support question to MELabs and I`ll post the findings. Many thanks!
  1. Problem converting 12F683 code to 12F1840
    By RossWaddell in forum mel PIC BASIC Pro
    Last Post: - 14th March 2013, 02:55
  2. PBP Support for 12F1840 8-Pin Device?
    By springtank in forum mel PIC BASIC Pro
    Last Post: - 10th November 2012, 09:32
  3. Timer1 issues
    By mitchf14 in forum mel PIC BASIC Pro
    Last Post: - 9th January 2009, 17:21
  4. 12c508a Device Config. And Burning Issues
    By sayzer in forum mel PIC BASIC Pro
    Last Post: - 29th March 2006, 17:50
