12F1840 config issues
Results 1 to 14 of 14
    Lancashire
    Default 12F1840 config issues
    Hi All
    I searched for an answer to this but came up blank. The program has been reduced to a single serout2 command to test. It works fine on both a 12F683 and 16F688 with the correct configs but I cant seem to get it to function on the 12F1840. There is data out but its garbage and clearly the wrong baud rate. I suspect I have not configured something, probably the oscillator correctly so requesting help. Its probably obvious but I cant spot it.
    Cheers Pete
    Code: PBP3
    	__CONFIG	_CONFIG1, _FOSC_INTOSC & _WDTE_ON & _PWRTE_ON & _MCLRE_ON & _BOREN_OFF
    	__CONFIG	_CONFIG2, _PLLEN_ON & _BORV_LO & _LVP_OFF
    OPTION_REG	= %10000001
    WPUA		= %00000000    'weak pull ups disabled
    ANSELA             = %00000000    'Select all digital
    TRISA               = %00001101	   ' Make A0,A2,A3 inputs,A1,A4,A5 outputs
    OSCCON      = %11110000    'SET INTOSC TO 32MHZ
    OSCTUNE     = %00000000
    INTCON 		= 0            'Latch out interrupt
    CM1CON0		= 0            'disable  comparators
    FVRCON		= 0            'Fixed voltage reference disabled
    DEFINE OSC 32
    Test:
    serout2 PORTA.5,16468,["Testing",13,10]
    goto Test
    Default Re: 12F1840 config issues
    Hi Enigma
    ' Config
    #IF __PROCESSOR__ = "12F1840"
    	__CONFIG    _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON  & _MCLRE_OFF & _CP_OFF  & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
     	__CONFIG 	_CONFIG2, _WRT_ALL & _PLLEN_ON & _STVREN_OFF & _BORV_LO & _LVP_OFF
    #ELSE
        #MSG "Wrong Processor selected!"
    #ENDIF
    'Includes
    INCLUDE "DT_INTS-14-2k.bas"
    INCLUDE "ReEnterPBP.bas"
         	INT_Handler    TMR1_INT,  _ClockCount,   PBP,  yes
    INTCON.7 = 0				' Pour čtre sur !!!
    ' Ports init
    TRISA		= 0
    PORTA 		= 0
    LATA		= 0
    NeoPinW1     VAR LATA.0
    NeoPinW2     VAR LATA.1
    NeoPinR		 VAR LATA.2
    ' Chip  Initialization
    OSCCON  = %11110000 ' 8 Mhz internal x 4
    OSCTUNE	= %00000000	' Internal osc Adjustment
    WHILE !OSCSTAT.3	' Wait for stable OSC ...
    WEND
    INTCON	= 0
    CPSCON0 = 0
    CPSCON1 = 0
    ADCON0 	= 0
    ADCON1	= %10000000
    ANSELA 	= 0
    CCP1CON = 0
    CM1CON0 = 0
    DACCON0 = 0
    FVRCON	= 0
    ' Timer 1
    T1CON 	= %00110101		' Preload @ 15536, PS=8, run
    T1GCON 	= 0
    INTCON	= %11000000
    PIE1	= %00000001
    PIR1	= 0
    This config works ...
    But I remember It was somewhat tricky ...
    I think this
    WEND
    made the chip run fine ...
    Dec 2010
    Your clock setup looks fine, but you can always do a blink test to confirm.
    However, what baud rate are you trying to achieve? 16468 seems to be about 60 baud by my calculations?
    It looks like 9600 baud by my calculations w/ open wire mode enabled. As far as the config's go everything looks good. Here is my config's for a Waterstick I designed and works great.
    DEFINE OSC 32
    ;----- CONFIG1 Options --------------------------------------------------
      __config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_ON & _FCMEN_ON
    ;----- CONFIG2 Options --------------------------------------------------
      __config _CONFIG2, _WRT_OFF & _PLLEN_ON & _STVREN_ON & _BORV_19 & _LVP_OFF
    '				SYSTEM INITIALIZATION
    	clear
    	PORTA = %00000000
    	TRISA = %00001111	'INITIALIZE PORT DIRECTIONS
    	OSCCON = %11110000	'PLL ENABLED,8Mhz,FSOSC<2:0>
       	INTCON = %00000000 'CLEAR GIE,PEIE,TMR0IE,INTE,RBIE,TMR0IF,INTF,RBIF
       	PIE1 = %00000000    'CLEAR ALL INTERRUPT ENABLE BITS
       	PIR1 = %00000000    'CLEAR ALL INTERRUPT FLAGS
      	PIE2 = %00000000    'CLEAR ALL INTERRUPT ENABLE BITS
      	PIR2 = %00000000    'CLEAR ALL INTERRUPT FLAGS
    	APFCON = %00000000	'ALL DEFAULTS
    	ANSELA = %00000011	'AN0:AN1 ANALOG,AN2:AN4 DIGITAL I/O
    	CPSCON0 = %11001100	'ENABLE CAP SENSE,DAC/FVR,HIGH RANGE
    	WPUA = %00001100	'WEAK PULLUP'S OFF, EXCEPT A.2,A.3
      	ADCON0 = %00000000  'CHS2:0,GO/DONE,ADOFF
      	ADCON1 = %11100000  'RIGHT JUSTIFIED,FOSC/64,VSS,VDD
    	SRCON0 = %00000000
    	SRCON1 = %00000000
       	CM1CON0 = %00000000	'CLEAR/DISABLE COMPARATOR
       	CM1CON1 = %00000000	'CLEAR/DISABLE COMPARATOR
      	CMOUT = %00000000	'DISABLE OUTPUT REGISTER
       	DACCON0 = %11001000	'ENABLE DAC,ENABLE POS REFERENCE,SOURCE IS FVR
       	DACCON1 = %00001000	'SET FOR 1/4 SCALE (8) ~ 1.024
      	FVRCON = %10001100	'ENABLE VOLTAGE REFERENCE,4,096
       	OPTION_REG = %00000000 'INTEDG,T0CS,T0SE,PSA,PS
       	T1CON = %11000001	'CAPOSC INPUT,PRESCALER 1/1,START TIMER 1
       	T1GCON = %00000000	'NO GATE CONTROL
       	T2CON = %00000000	'POSTSCALER 1/1,STOP,PRESCALER 1
       	TMR2 = 0			'CLEAR TMR2 MODULE REGISTER
       	PR2 = 255			'SET PERIOD ((((1 / 32,000,000)*4) * 1 PRESCALE) * (1+255 PR2)) = 31.25 KHZ.
       	CCP1CON = %00000000	'PLACE CCP1 INTO DISABLE MODE
       	CCPR1L = $00		'CLEAR CCP1 LOWER 8 BITS
       	CCPR1H = $00		'CLEAR CCP1 UPPER 2 BITS
    	PSTR1CON = %00000001'DEFAULT
    EN82fn
    Lancashire
    Many thanks, I will run through these and see. These seem tricky beasts to set up and I am sure I have probably not set something I need to. Will report back! Cheers Pete
    Lancashire
    I now have the code below. The serial data appears to come out at intervals of one second but is complete garbage still. Replacing the PIC with an appropriately configured 12F683 all functions fine. I am wondering if anyone else can replicate a serout2 on the 12F1840 and see if its the same. If the code looks good I am wondering if its a problem with PBP?. Cheers Pete
     __config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _MCLRE_ON & _CP_OFF & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_ON & _FCMEN_ON
     clear
     'PORTA = %00000000
    WEND
     SRCON0 = %00000000
     SRCON1 = %00000000
    DEFINE OSC 32
    initialise:
    serout2 PORTA.5,16468,["Waiting for X200",13,10]
    goto initialise
  1. Problem converting 12F683 code to 12F1840
    By RossWaddell in forum mel PIC BASIC Pro
    Last Post: - 14th March 2013, 02:55
  2. PBP Support for 12F1840 8-Pin Device?
    By springtank in forum mel PIC BASIC Pro
    Last Post: - 10th November 2012, 09:32
  3. Timer1 issues
    By mitchf14 in forum mel PIC BASIC Pro
    Last Post: - 9th January 2009, 17:21
  4. 12c508a Device Config. And Burning Issues
    By sayzer in forum mel PIC BASIC Pro
    Last Post: - 29th March 2006, 17:50
