USBIN pain
Results 1 to 11 of 11
Thread: USBIN pain
    Default Re: USBIN pain
    That might explain why garbage appears on the lcd at switch on, however as its confihured as virtual serial and not pure USB as in hid I would,nt have thought that [0] would be reserved, but it does make me think its worth another look. So you think that the buffer size should be at least 8 bytes?
    Sep 2009
    I'm not sure, but I think it should be at least 8 bytes...
    If you are using CDC, than it maybe different... Best choice is that you leave USB variable, as is. Don't change anything.
    And for CDC I think that numbers of bytes in packet is not constant... It can be one, it can be more... But again, I'm not sure... I don't have much experience with usb.
    Darn, can't remember where I read about buffer length. I would go with 8 bytes too.
    It's not going to affect performance much anyways.
    I think it is in USB Complete, but have to search and the book is far away right now...
    Mar 2008
    Gerogetown, Texas
    You can have the buffer any length as long as the discriptor is set correctly.
    example
    USBBufferSizeMax   con 16  ' maximum buffer size
    USBBufferSizeTX    con 16  ' input
    USBBufferSizeRX    con 16  ' output
      ; report count (number of fields)
        retlw	0x95
        retlw	0x10   ; 16 byte buffer
    it could be 3 bytes, 5 bytes as many as you want up to 64 bytes
  1. What a Pain In The USB-utt
    By Cobra_Phil in forum USB
    Last Post: - 23rd January 2015, 14:15
  2. PIC18F14K50 and USBin
    By ybosco in forum mel PIC BASIC Pro
    Last Post: - 7th November 2013, 04:52
  3. Replies: 6
    Last Post: - 4th November 2009, 13:36
  4. Usbin and hserin
    By mpardinho in forum mel PIC BASIC Pro
    Last Post: - 27th October 2007, 15:26
  5. Need help with USBIN
    Last Post: - 13th June 2007, 18:51
