Help configuring 2 CCP interupts
Results 1 to 12 of 12
    Default Re: Help configuring 2 CCP interupts
    pic chips have only one interrupt vector
    DEFINE INTHAND CCP_INT ' Declare high-pri interrupt handler
    needs to do something like this
    DEFINE INTHAND which_CCP_INT ' Declare high-pri interrupt handler
    then
    asm
    which_ccp_int
    pseudo code wise
    if ccp1 INTflag set then bra ccp_int1
    if ccp2 INTflag set then bra ccp_int2
    RETFIE FAST ' not my interrupt
    CCP_INT1
    BTFSS CCP1CON,0 ; capture from rising edge?
    BRA Fall ; no .. goto falling edge
    MOVFF CCPR1L, _T1 ; get low capture byte into _T1
    MOVFF CCPR1H, _T1+1 ; get high capture byte into _T1
    BRA IntExit ; outta here
    Fall
    MOVFF CCPR1L, PW ; get low capture byte into PW
    MOVFF CCPR1H, PW+1 ; get high capture byte into PW
    BSF CF,0 ; indicate last capture
    IntExit
    BTG CCP1CON,0 ; toggle between rising/falling edge captures
    BCF PIR1,2 ; clear capture interrupt flag bit
    RETFIE FAST ; return/restore W, STATUS and BSR
    CCP2_INT
    BTFSS CCP2CON,0 ; capture from rising edge?
    BRA Fall2 ; no .. goto falling edge
    MOVFF CCPR2L, _T2 ; get low capture byte into _T1
    MOVFF CCPR2H, _T2+1 ; get high capture byte into _T1
    BRA IntExit2 ; outta here
    Fall2
    MOVFF CCPR2L, PW2 ; get low capture byte into PW
    MOVFF CCPR2H, PW2+1 ; get high capture byte into PW
    BSF CF2,0 ; indicate last capture
    IntExit2
    BTG CCP2CON,0 ; toggle between rising/falling edge captures
    BCF PIR2,0 ; clear capture interrupt flag bit
    Apr 2007
    Pennsylvania, USA
    Thank you! That helped me get it working
    Shawn
    Yes and no. 18F-series chips have two, one high priority (0x0008h) and one low pritority (0x0018h) and the DEFINE's, as they were written in ONE of the code examples posted was defining one handler for the high priority and one for the low. However, both handlers had RETFIE FAST at the end which, to me, seems like a mistake if there's any possibillity of a high priroty interrupt tripping while a low priority interrupt is executing. It may be why they worked on their own but not both at the same time.
    Anyway, if you got it working then none of it really matters.
    it should also be noted that for a low priority int handler
    wsave,ssave,bsave vars are required to save and restore chips status on entry/exit
    and that the chosen int priority must match settings
    DEFINE INTLHAND CCP2_INT ' Declare interrupt handler
    CapPriEn = 1 'Set CCP1 int to high priority
    CapPriEn2 = 0 'Set CCP2 int to low priority
    also to note that none or the isr's in this thread have made any attempt at ensuring correct banksel
    a few chk??rp lines would make things more reliable
    Apr 2007
    Pennsylvania, USA
    Below is my working ASM interrupt routine. I'm sure it could be improved, but it appears to work 100%. Using only 1 priority interrupt for the CCP module. Thanks for all the help!
    X_CCP_INT
      BTFSC PIR1,2          ; if ccp1
      BRA CCP_INT           ; goto CCP_INT
      BTFSC PIR2,0          ; if ccp2
      BRA CCP2_INT          ; goto CCP2_INT
      RETFIE FAST           ; outta here
    CCP_INT
    Fall
    IntExit
    CCP2_INT
    Fall2
    IntExit2
    Shawn
    This one statement solved a problem I was having.
    So I combined my ISRs into one and Viola',
    Thanks Richard
  1. Help with configuring
    Last Post: - 17th August 2014, 01:08
  2. Question regarding CCP
    By spcw1234 in forum mel PIC BASIC Pro
    Last Post: - 8th April 2013, 09:55
  3. Configuring 16F616
    Last Post: - 16th February 2009, 16:28
  4. CCP Module How to ?
    By capitano in forum mel PIC BASIC Pro
    Last Post: - 8th February 2005, 08:08
  5. need help configuring 16F628
    By tcbcats in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2004, 18:59
