Help configuring 2 CCP interupts
Results 1 to 12 of 12
    Apr 2007
    Pennsylvania, USA
    Default Help configuring 2 CCP interupts
    I can successfully get CCP1 to work and display the measured period on an LCD using Timer 1, but adding CCP2 using Timer 3 does not work. It never interrupts and jumps to CCP2_INT. Pretty sure this has something to do with setting up 2 priority interrupts, but haven't found the problem. Anyone have some insight?
    'PIC18F4620 CCP1 & CCP2 test
    OSCCON=%01110000            ' SET TO 8 MHZ internal oscillator
    DEFINE OSC 08               ' 8MHZ clock speed
    DEFINE INTHAND CCP_INT      ' Declare high-pri interrupt handler
    ADCON1 = 15                 ' All digital
    CMCON  = 7                  ' Turns off comparators
    define LCD_COMMANDUS 1500   ' set command delay in us
    define LCD_DATAUS 50        ' set data delay in us
    define LCD_DREG PORTD       ' set LCD data port
    define LCD_DBIT 4           ' set LCD starting data bit
    define LCD_RSREG PORTD      ' define RS port
    define LCD_RSBIT 2          ' define RS bit
    define LCD_EREG PORTD       ' set LCD ENABLE port
    define LCD_EBIT 3           ' set LCD ENABLE bit
    define LCD_BITS 4           ' set LCD bits 4 or 8
    define LCD_LINES 2          ' set # of LCD rows 2 or 4
    '************************** V A R S  /  C O N S ********************************
    'CCP1 INTERRUPT
    Symbol Capture   = PIR1.2      ' CCP1 capture flag
    SYMBOL CapIE     = PIE1.2      ' CCP1 interrupt enable bit
    SYMBOL CapPriEn  = IPR1.2      ' priority enable bit for CCP1 interrupt
    SYMBOL PriEnable = RCON.7      ' set to enable priority levels on interrupts
    _T1             VAR WORD BANKA SYSTEM  ' 1st capture value
    PW              VAR WORD BANKA SYSTEM  ' 2nd capture value & ultimately final pulse width
    CF              VAR BYTE BANKA SYSTEM  ' indicates when last capture is ready
    Period          var word
    'CCP2 INTERRUPT
    Symbol Capture2   = PIR2.2      ' CCP2 capture flag
    SYMBOL CapIE2     = PIE2.2      ' CCP2 interrupt enable bit
    SYMBOL CapPriEn2  = IPR2.2      ' priority enable bit for CCP2 interrupt
    SYMBOL PriEnable2 = RCON.7      ' set to enable priority levels on interrupts
    _T2             VAR WORD BANKA SYSTEM  ' 1st capture value
    PW2             VAR WORD BANKA SYSTEM  ' 2nd capture value & ultimately final pulse width
    CF2             VAR BYTE BANKA SYSTEM  ' indicates when last capture is ready
    Period2         var word
    'CONFIGURE DISPLAY
    ln1 con $80
    ln2 con $C0
    CS  con 1
    LCDOUT $FE,CS
    CLEAR                  ' clear RAM on POR
    TRISC.2 = 1            ' CCP1 input pin (Capture1 input on 18F4620)
    TRISC.1 = 1            ' CCP2 input pin (Capture2 input on 18F4620)
    INTCON  = 0            ' Interrupts off for now
    pause 1000             'add bootup delay to allow things to settle
    GOTO start             'jump over interrupt handler
    CCP_INT
      BTFSS CCP1CON,0      ; capture from rising edge?
      BRA Fall             ; no .. goto falling edge
      MOVFF CCPR1L, _T1    ; get low capture byte into _T1
      MOVFF CCPR1H, _T1+1  ; get high capture byte into _T1
      BRA IntExit          ; outta here
    Fall
      MOVFF CCPR1L, PW     ; get low capture byte into PW
      MOVFF CCPR1H, PW+1   ; get high capture byte into PW
      BSF CF,0             ; indicate last capture
    IntExit
      BTG CCP1CON,0        ; toggle between rising/falling edge captures
      BCF PIR1,2           ; clear capture interrupt flag bit
      RETFIE FAST          ; return/restore W, STATUS and BSR
    CCP2_INT
      BTFSS CCP2CON,0      ; capture from rising edge?
      MOVFF CCPR2L, _T2    ; get low capture byte into _T1
      MOVFF CCPR2H, _T2+1  ; get high capture byte into _T1
    Fall2
      MOVFF CCPR2L, PW2     ; get low capture byte into PW
      MOVFF CCPR2H, PW2+1   ; get high capture byte into PW
      BSF CF2,0             ; indicate last capture
    IntExit2
      BTG CCP2CON,0        ; toggle between rising/falling edge captures
      BCF PIR2,2           ; clear capture interrupt flag bit
    start:
    '******************** CCP1 / Timer 1 ********************
    CCP1CON = %00000111    'Capture mode, capture on 16th rising edge
    T1CON.7=1              'Enable timer  16 bit `
    T1CON.6=1              'Timer1 OSC
    T1CON.5=1              '1:8 prescaler
    T1CON.4=1              '1:8 prescaler
    T1CON.3=0              'Timer1 OSC off
    T1CON.2=0              'sychro clock
    T1CON.1=0              'Internal clock
    TMR1H = 0              'Clear high byte of TMR1 counter
    TMR1L = 0              'Clear low byte
    PriEnable = 1          'Enable priority levels on interrupts
    Capture = 0            'Clear capture flag bit
    CapPriEn = 1           'Set CCP1 int to high priority
    CapIE = 1              'Enable the CCP1 capture interrupt
    INTCON = %11000000     'Global + peripheral ints enabled
    T1CON.0 = 1            'Turn TMR1 on here
    '******************** CCP2 / Timer 3 ********************
    CCP2CON = %00000111     'Capture mode, capture on 16th rising edge
    T3CON.7=1               'Enable timer  16 bit `
    T3CON.6=1               'Timer1 OSC
    T3CON.5=1               '1:8 prescaler
    T3CON.4=1               '1:8 prescaler
    T3CON.3=0               'Timer 3 source
    T3CON.2=0               'sychro clock
    T3CON.1=0               'Internal clock
    TMR3H = 0               'Clear high byte of TMR1 counter
    TMR3L = 0               'Clear low byte
    PriEnable2 = 1          'Enable priority levels on interrupts
    Capture2 = 0            'Clear capture flag bit
    CapPriEn2 = 1           'Set CCP1 int to high priority
    CapIE2 = 1              'Enable the CCP1 capture interrupt
    T3CON.0 = 1             'Turn TMR1 on here
    '********************** S U B R O U T I N E S **********************************
    getCCP1:
        IF CF.0 THEN         ' figure out & print result only after last capture
          period = PW-_T1
          CF.0 = 0           ' clear flag bit
    getCCP2:
        IF CF2.0 THEN         ' figure out & print result only after last capture
          period2 = PW2-_T2
          CF2.0 = 0           ' clear flag bit
    '********************** M A I N    L O O P *************************************
    gosub getCCP1
    lcdout $fe, ln1, "#1 = ", dec period, "             "
    gosub getCCP2
    lcdout $fe, ln2, "#2 = ", dec period2, "            "
    Shawn
    Default Re: Help configuring 2 CCP interupts
    Hi, Spcw ...
    did you see this one in the datasheet ???
    Both modules may be
    active at any given time and may share the same timer
    resource if they are configured to operate in the same
    mode
    (Capture/Compare or PWM) at the same time
    ... soooo ...
    Apr 2007
    Pennsylvania, USA
    I tried using only timer 1 with the same result. The timer doesn't seem to be the issue, getting it to interrupt to me seems like the issue.
    Thanks for the help!
    Shawn
    Hi Shawn
    something I do not see ...
    When to enter ( choose between) CCP1 INT or CCP2 INT ???
    may be I miss something, but ...
    Apr 2007
    Pennsylvania, USA
    The define at the beginning of the code, I think. I actually missed it on the first post as I tried multiple combinations. I have one set as priority and the other not since it won't let me use the same define twice. I did not write the assembly routine. I did find a couple of errors and switched to timer1, but still can't get CCP2 to capture anything...
    DEFINE INTLHAND CCP2_INT    ' Declare interrupt handler
    'CCP1 INTERRUPT
    Period          var word
    'CCP2 INTERRUPT
    Period2         var word
    'CONFIGURE DISPLAY
    ln1 con $80
    ln2 con $C0
    CS  con 1
    LCDOUT $FE,CS
    CCP_INT
    Fall
    IntExit
    CCP2_INT
      BRA Fall2             ; no .. goto falling edge
      BRA IntExit2          ; outta here
    Fall2
    IntExit2
    start:
    '******************** CCP1 / CCP2 / Timer 1 ********************
    CapPriEn2 = 1          'Set CCP2 int to high priority
    CapIE2 = 1             'Enable the CCP2 capture interrupt
          period = PW-_T1
          period2 = PW2-_T2
    Shawn
    Apr 2007
    Pennsylvania, USA
    Sorry to reply again. I had the registers wrong for CCP2. Still can't get both to work at the same time. Below the first code works with CCP1 and the second works with CCP2 with the 2 lines commented out. Note I switched to an 18F2221 just to make sure it wasn't the chip. Same results.
    CCP1 works:
    'PIC18F2221 CCP1 & CCP2 test
    '!!!!!COMMENTED OUT!!!!! DEFINE INTHAND CCP2_INT    ' Declare interrupt handler
    define LCD_DREG PORTC       ' set LCD data port
    define LCD_RSREG PORTB      ' define RS port
    define LCD_RSBIT 1          ' define RS bit
    define LCD_EREG PORTB       ' set LCD ENABLE port
    define LCD_EBIT 0           ' set LCD ENABLE bit
    'CCP1 INTERRUPT
    Period          var word
    'CCP2 INTERRUPT
    Symbol Capture2   = PIR2.0      ' CCP2 capture flag
    SYMBOL CapIE2     = PIE2.0      ' CCP2 interrupt enable bit
    SYMBOL CapPriEn2  = IPR2.0      ' priority enable bit for CCP2 interrupt
    Period2         var word
    'CONFIGURE DISPLAY
    ln1 con $80
    ln2 con $C0
    CS  con 1
    LCDOUT $FE,CS
    CCP_INT
    Fall
    IntExit
    CCP2_INT
    Fall2
    IntExit2
      BCF PIR2,0            ; clear capture interrupt flag bit
    start:
    '!!!!!COMMENTED OUT!!!!! CCP2CON = %00000111    'Capture mode, capture on 16th rising edge
          period = PW-_T1
          period2 = PW2-_T2
    CCP2 works:
    '!!!!!COMMENTED OUT!!!!! DEFINE INTHAND CCP_INT      ' Declare high-pri interrupt handler
    'CCP1 INTERRUPT
    Period          var word
    'CCP2 INTERRUPT
    Period2         var word
    'CONFIGURE DISPLAY
    ln1 con $80
    ln2 con $C0
    CS  con 1
    LCDOUT $FE,CS
    CCP_INT
    Fall
    IntExit
    CCP2_INT
    Fall2
    IntExit2
    start:
    '!!!!!COMMENTED OUT!!!!! CCP1CON = %00000111    'Capture mode, capture on 16th rising edge
          period = PW-_T1
          period2 = PW2-_T2
    Shawn
    pic chips have only one interrupt vector
    needs to do something like this
    DEFINE INTHAND which_CCP_INT ' Declare high-pri interrupt handler
    then
    asm
    which_ccp_int
    pseudo code wise
    if ccp1 INTflag set then bra ccp_int1
    if ccp2 INTflag set then bra ccp_int2
    RETFIE FAST ' not my interrupt
    CCP_INT1
    Fall
    IntExit
    CCP2_INT
    Fall2
    IntExit2
    Apr 2007
    Pennsylvania, USA
    Thank you! That helped me get it working
    Shawn
    Yes and no. 18F-series chips have two, one high priority (0x0008h) and one low pritority (0x0018h) and the DEFINE's, as they were written in ONE of the code examples posted was defining one handler for the high priority and one for the low. However, both handlers had RETFIE FAST at the end which, to me, seems like a mistake if there's any possibillity of a high priroty interrupt tripping while a low priority interrupt is executing. It may be why they worked on their own but not both at the same time.
    Anyway, if you got it working then none of it really matters.
    it should also be noted that for a low priority int handler
    wsave,ssave,bsave vars are required to save and restore chips status on entry/exit
    and that the chosen int priority must match settings
    CapPriEn2 = 0 'Set CCP2 int to low priority
    also to note that none or the isr's in this thread have made any attempt at ensuring correct banksel
    a few chk??rp lines would make things more reliable
    Apr 2007
    Pennsylvania, USA
    Below is my working ASM interrupt routine. I'm sure it could be improved, but it appears to work 100%. Using only 1 priority interrupt for the CCP module. Thanks for all the help!
    X_CCP_INT
      BTFSC PIR1,2          ; if ccp1
      BRA CCP_INT           ; goto CCP_INT
      BTFSC PIR2,0          ; if ccp2
      BRA CCP2_INT          ; goto CCP2_INT
      RETFIE FAST           ; outta here
    CCP_INT
    Fall
    IntExit
    CCP2_INT
    Fall2
    IntExit2
    Shawn
    This one statement solved a problem I was having.
    So I combined my ISRs into one and Viola',
    Thanks Richard
  1. Help with configuring
    Last Post: - 17th August 2014, 01:08
  2. Question regarding CCP
    By spcw1234 in forum mel PIC BASIC Pro
    Last Post: - 8th April 2013, 09:55
  3. Configuring 16F616
    Last Post: - 16th February 2009, 16:28
  4. CCP Module How to ?
    By capitano in forum mel PIC BASIC Pro
    Last Post: - 8th February 2005, 08:08
  5. need help configuring 16F628
    By tcbcats in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2004, 18:59
