Symbol not previously defined - lib file
Results 1 to 14 of 14
Threaded View
  1. #4
    Oct 2009
    Default Re: Symbol not previously defined - lib file
    Ok, here is the work in progress - still working through the parts I don't need before I add the code for the DTH11 sensor.
    '*  Name    : single chan version
    '*  Authors : Malcolm Crabbe (inc files from Darrel Taylor
    '*  Date    : 6/2/15
    '*  Version : 1.00
    '*  Target  : 18F2520 running 20 mhz xtal
    '*          : single DTH11 sensor
    '  18F2520 config settings - for use with MPSAM
      __CONFIG    _CONFIG1H, _OSC_HS_1H
      __CONFIG    _CONFIG2L, _PWRT_ON_2L
      __CONFIG    _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H
      __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    '  Include files
    DEFINE WRITE_INT 1
    INCLUDE "DT_INTS-18.bas"                        ; Base Interrupt System
    INCLUDE "DT18x20.pbp"
    INCLUDE "incPID_mc.pbp"                         ' Include the multi-channel PID routine.
    include "ReEnterPBP-18.bas"
    INT_LIST  macro                                 ; IntSource, Label, Type, ResetFlag?
            INT_Handler   TMR1_INT,  HeaterDrive,   ASM,  yes
        INT_CREATE                                  ; Creates the interrupt processor
    T1CON = %00000001                               ; free-running, 1:1 prescaler
    @   INT_ENABLE   TMR1_INT                       ; enable Timer1 interrupts
    ENABLE DEBUG
    ;----[DS1820 Options]----Value----Default-----------------------------------
    DEFINE  DS1820_DECIMALS    1                    ' 1
    DEFINE  DS1820_VERIFYCRC   YES                  ' NO
    DEFINE  DS18B20_ONLY       YES                  ' NO
                              ' Include DT18x20 module
    ;----[Analog Settings]------------------------------------------------------                                  ' set A/D resolution to 14-bits
    CMCON = 7                                       ' disable Comparators
    ADCON1 = %00001011                              ' sets up Analogue pins
    ADCON2.7 = 1                                    ' ADFM bit isn't in ADCON1 anymore
    ;----[PID multi-channel]--------------------------------------------------------
    PID_Channels CON 1
    ;----[Port settings]----------------------------------------------------
    TRISB = %00000000
    ;----[Variables/Aliases]----------------------------------------------------
    GIE               VAR INTCON.7
    TempWD            VAR WORD                      ' temporary WORD variable
    Bvar              VAR BYTE                      ' temporary BYTE variable
    TempStr           VAR BYTE[8]
    FlashStar         VAR BIT
    EditChannel       VAR BYTE
    viv               var byte
    option            var byte
    Hours             var byte
    Minutes           var byte
    nitetemp          var byte
    fn                var byte
    cn                var byte
    HeaterOut        var PORTA.4
    StartHour	         VAR WORD[1]
      StartHour1         VAR StartHour[0]
    StartMin             VAR WORD[1]
      StartMin1          VAR StartMin[0]
    StopHour   	         VAR WORD[1]
      StopHour1          VAR StopHour[0]
    StopMin     	     VAR WORD[1]
      StopMin1           VAR StopMin[0]
    Temperatures      VAR WORD[1]
      Temp1           VAR Temperatures[0]
    spModes           VAR BYTE[1]                   ' controls how set point is adjusted PC or POT
      spMode1         VAR spModes[0]
    SetPoints         VAR WORD[1]                   ' used to store the desired temperature setting
      SetPoint1       VAR SetPoints[0]
    normtemp          VAR WORD[1]                   ' used to store the desired temperature setting
      normtemp1       VAR normtemp[0]
    HeatCycle         VAR BYTE  BANK0 SYSTEM
    HeaterDrives      VAR BYTE[1] BANK0 SYSTEM      ' outputs to SSR's
      HeatDrive1      VAR HeaterDrives[0]
    SensorActive      VAR BIT[4]
    ChannelPWR        VAR BIT[4]
    Pots              VAR WORD[4]                   ' used to set temp in manual mode
    Result            VAR WORD                      ' used to get AD results
    ADavg             VAR WORD[4]                   ' Averaging accumulators
    Value             VAR WORD
    Sensor	          VAR BYTE
    	CounterA var byte	' General purpose Variable
    	CounterB var byte	' General purpose Variable
    	CounterC var byte	' General purpose Variable
    	CounterD var byte	' General purpose Variable
    	RTCSec var byte		' Seconds
    	RTCMin var byte		' Minutes
    	RTCHour var byte	' Hours
    	RTCWDay var byte	' Weekday
    	RTCDay var byte		' Day
    	RTCMonth var byte	' Months
    	RTCYear var byte	' Year
    	RTCCtrl var byte	' Control
    	SetTime var byte	' 12/24 Hour Clock
    	SetSec var byte		' Seconds
    	SetMin var byte		' Minutes
    	SetHour var byte	' Hours
    	SetDay var byte		' Day
    	SetMonth var byte	' Months
    	SetYear var byte	' Year
    	TimeOut var word	' Variable for SetUp Menu Time-Out
    	TimeH var byte      ' Variable to store current hour for comparison to drop temp time
    	TimeM var Byte      ' Variable to store current minutes for comparison to drop temp time
    	ButtonRepeat con 200	' Timeperiod (in mS for Edit Buttons auto-repeat
    				            ' should you want to hold them down...
    DecButton          var PORTA.0	        'Press to Decrement Button
    SetButton          var PORTA.1          'Press to Set/memorise Button
    IncButton          var PORTA.2	        'Press to Increment Button
    OnButton           var PORTA.0	        'Press to Decrement Button
    OffButton          var PORTA.2	        'Press to Increment Button
    H_butt             VAR PORTA.2          'hour increase
    M_butt             VAR PORTA.0          'minutes increase
    S_butt             VAR PORTA.1          'set / memorise
    SCLpin             var PORTC.3          'RTC pin - clk
    SDApin             var PORTC.4          'RTC pin - data
    DQ                 VAR PORTA.5          'One-wire data pin for Ds18B20
    ;----[EEPROM Data]----------------------------------------------------------
    DATA @0,0
    EE_spMode1        DATA 0                        ' 0=Manual mode, temp is set by Pot.
    EE_SetPoint1      DATA WORD 280                 ' 28.0 deg. after programming if not in manual mode
    EE_pid_Kp1        DATA WORD $0700               ' PID constants
    EE_pid_Ki1        DATA WORD $0080
    EE_pid_Kd1        DATA WORD $0200
    EE_pid_Ti1        DATA 8                        ' Update I-term every 8th call to PID
    EE_pid_I_Clamp1   DATA 125                      ' Clamp I-term to max ±100
    EE_pid_Out_Clamp1 DATA WORD 255                 ' Clamp the final output to 255
    EE_CH1PWR         DATA 1                        ' this needs to be set to 1 to enable heater channel
    ;----[Initialization]-------------------------------------------------------
    init:
        LCDOUT $FE,1:FLAGS=0:PAUSE 250:LCDOUT $FE,1:PAUSE 250 ' Initialize LCD
        FOR Bvar = 0 to 3                               ; assume all sensors are working
            SensorActive(Bvar) = 1
        NEXT Bvar
        FOR pid_Channel = 0 TO 3                        ; Set # of bits in resolution
            GOSUB SelectSensor                          ; for all sensors
            GIE = 0                                     ; disable interrupts before 1-wire
            @ DS1820_Resolution 12
            GIE = 1                                     ; enable interrupts after 1-wire
        NEXT pid_Channel
        LOW HeaterOut                                  ; set heater pins to Output
        GOSUB SendPWRstat
    normtemp[0] = SetPoints[0]
    ;____[Main Program Loop]____________________________________________________
    If SetButton=0 then
    Gosub SetButtonRelease
    goto mainmenu
    pid_Channel = 0
            GOSUB SelectSensor
            @  DS1820_Convert                           ; start a temperature conversion
    pid_Channel = 0
            GOSUB SelectSensor
            DS1820_Error = 0                            ; clear any previous errors
            DS1820_Flags = 0                            ; clear status flags
              @ DS1820_Stat                             ; check the sensors status
            PAUSEUS 20
            IF !DS1820_Done THEN SensorError            ; if it's not done by now, error
              @ DS1820_Read                             ; get the temperature result
            GOSUB Check4Zeros
            DS1820_Flags = 0
              @ DS1820_Stat
            IF (DS1820_Error = 0) AND DS1820_Done THEN  ; if there were no errors
                Temperatures(pid_Channel) = TempC
                pid_Error = SetPoints(pid_Channel) - TempC
                GOSUB PID
                IF pid_Out.15 THEN pid_Out = 0          ; only keep positive values
                IF ChannelPWR(pid_Channel) THEN
                    HeaterDrives(pid_Channel) = pid_Out
                    HeaterDrives(pid_Channel) = 0
                GOSUB ShowLCD
        SensorError:
               HeaterDrives(pid_Channel) = 0            ; turn off heater if sensor's bad
               SensorActive(pid_Channel) = 0
               GOSUB ShowError                          ; display error message
    ;----[Flash Star on LCD]-------------------------------------------------------
        LCDOUT $FE,$80 + 18,("*"&FlashStar*$FF)|(" "&~(FlashStar*$FF)) ; flash a star to show sample time
        FlashStar = !FlashStar
    GOTO Main
    AllZeros  VAR Bit
    Check4Zeros:
        AllZeros = 1
        FOR Bvar = 0 TO 8
            IF DS1820_Buffer(Bvar) != 0 THEN AllZeros = 0
        NEXT Bvar
        IF AllZeros THEN DS1820_CRCfailed = 1
    ShowLCD:
        LOOKUP pid_Channel,[$80,$C0,$89,$C9],Bvar       ; Find location
        LCDOUT $FE,Bvar,DEC1 pid_Channel+1,"= "         ; print to LCD
        TempWD = TempC : GOSUB TempToLCD                ; display TempC
        LCDOUT $DF                                      ; deg symbol
    LCDOut $FE,$D4+8,#setpoints(0)dig 2,#setpoints(0)dig 1,$FE,$D4+11
    SendPWRstat:
        Bvar = 0
        Bvar.0 = ChannelPWR(0)
    SelectSensor:
      SELECT CASE pid_Channel
        CASE 0 : @ DS1820_Select  _TempSensor1      ; Select the DS18x20 pin
      END SELECT
    ;----[TMR1 interrupt handler]-----------------------------------------------
    HeaterDrive
          incf    HeatCycle,F                       ; HeatCycle
          movf    _HeatDrive1,W                     ; HeatDrive1
          subwf   HeatCycle,w
          btfsc   STATUS,C
          bcf     _HeaterOut
          btfss   STATUS,C
          bsf     _HeaterOut
      INT_RETURN
    ;----[Display TempWD on LCD]------------------------------------------------
    TempToLCD:
        IF TempWD.15 THEN LCDOUT "-"          ; if negative, display minus sign
        TempWD = ABS(TempWD)                  ; get the positive value
        LCDOUT DEC TempWD/DS1820_DIG          ; Display the Integer portion
    @   if (DS1820_DECIMALS > 0)              ; if using decimals
            LCDOUT "."                        ;   display decimal point
            TempWD = TempWD//DS1820_DIG       ;   get decimal portion
    @       if (DS1820_DECIMALS > 1)          ; with DECIMALS=2, next DIG is 1
                LCDOUT  DEC1 TempWD DIG 1
    @       endif
    @       if (DS1820_DECIMALS >= 1)         ; with DECIMALS=1, next DIG is 0
                LCDOUT  DEC1 TempWD DIG 0
    @       endif
    @   endif
    ;----[Display Sensor Error]-------------------------------------------------
    ShowError:
        LOOKUP pid_Channel,[$83,$C3,$8B,$CB],Bvar               ; Find location
        LCDOUT $FE,Bvar-1," N/C    "                                ; print to LCD
    ;----[Set Cursor according to Columns]--------------------------------------
    GetSetpoint:
        LCDOUT $FE,1
    Showtemp:
    '	Subroutine waits until user reseases Set Button
    SetButtonRelease:
    	LCDOut $FE,1
    	While SetButton=0:Wend
    	Pause 250	                                     ' Small pause to kill any Key-Bounce
    JumpStart:
    Pause 200		                                     ' Timeout for LCD to settle
    '	Time & Date Display Loop
    ReDisplay:
    ReDisplayLoop:
    nitetime:
    LCDOUT $FE,2
    nite:
    LCDOUT $FE,2,"Night Time Settings"
    lcdout $FE, $C0, "Use + key for Option"
    IF Option = 1 THEN lcdout $FE, $D4, "Set Night Temps    "
    if option = 2 then lcdout $FE, $D4, "Set Start Times    "
    if option = 3 then lcdout $FE, $D4, "Set Stop Times     "
    if option = 4 then lcdout $FE, $D4, "Return To Menu     "
    pause 150
    IF !H_butt THEN Option = option + 1
    if option >4 then option = 0
    If option = 1 Then
    If S_butt = 0 Then
    LCDOUT $FE,1
    fn=0
    goto nitedrop
    If option = 2 Then
    If S_butt = 0 Then
    LCDOUT $FE,1
    goto starttime
    If option = 3 Then
    If S_butt = 0 Then
    LCDOUT $FE,1
    goto stoptime
    If option = 4 Then
    If S_butt = 0 Then
    LCDOUT $FE,1
    goto mainmenu
    fn = 0
    viv = 1
    nitetemp = 150
    goto nite
    starttime:
    Lcdout $FE,2
    LCDOUT $FE,$80,"Set Start Time For "
        IF H_butt = 0 THEN GOSUB IncHours
        IF M_butt = 0 THEN GOSUB IncMinutes
        StartHour[fn]=Hours
        StartMin[fn]=Minutes
        if viv >=4 then viv =4
        LCDOUT $FE,$C0,"Viv ",#viv
        lcdout $FE,$94,#StartHour[fn] DIG 1,#StartHour[fn] DIG 0,":",#StartMin[fn] DIG 1,#StartMin[fn] DIG 0
    pause 200
    If S_butt = 0 then
    pause 250
    fn = fn +1
    viv = viv+1
    hours = 0
    minutes = 0
    If fn > 3 then
    LCDOUT $FE,1
    goto nite
    goto starttime
    stoptime:
    Lcdout $FE,2
    LCDOUT $FE,$80,"Set Stop Time For "
        StopHour[fn] = Hours
        StopMin[fn] = Minutes
        lcdout $FE,$94,#StopHour[fn] DIG 1,#StopHour[fn] DIG 0,":",#StopMin[fn] DIG 1,#StopMin[fn] DIG 0
    pause 200
    If !S_butt then
    pause 250
    fn = fn +1
    viv = viv +1
    hours = 0
    minutes = 0
    If fn > 3 then
    LCDOUT $FE,1
    goto nite
    goto stoptime
    nitedrop:
    inctemp:
    nitetemp = nitetemp + 10
        IF nitetemp = 300 THEN nitetemp = 150
        pause 250
    IncHours:
        Hours = Hours + 1
        IF Hours = 24 THEN Hours = 0
        pause 250
    IncMinutes:
        Minutes = Minutes + 1
        IF Minutes = 60 THEN Minutes = 0
        pause 250
    mainmenu:
    LCDOUT $FE,2,"Main Menu"
    lcdout $FE, $C0, "Select Option"
    IF Option = 1 THEN lcdout $FE, $D4, "Set Time and Date  "
    if option = 2 then lcdout $FE, $D4, "Set Night Period   "
    if option = 3 then lcdout $FE, $D4, "Set Normal Temps   "
    if option = 4 then lcdout $FE, $D4, "Set Lighting Period"
    if option = 5 then lcdout $FE, $D4, "Run                "
    pause 150
    if option >5 then option = 0
    'If option = 1 Then
    'If S_butt = 0 Then
    'LCDOUT $FE,1
    'Gosub SetButtonRelease
    'goto  setup
    'endif
    'endif
    If option = 2 Then
    If S_butt = 0 Then
    LCDOUT $FE,1
    goto nitetime
    If option = 3 Then
    If S_butt = 0 Then
    LCDOUT $FE,1
    goto GetSetpoint
    'If option = 4 Then
    'If S_butt = 0 Then
    'LCDOUT $FE,1
    'goto lighting
    'endif
    'endif
    If option = 5 Then
    If S_butt = 0 Then
    LCDOUT $FE,1
    fn = 0
    viv = 1
    nitetemp = 150
    Goto mainmenu
    And attached the results when complied. - I'm stumped - I've tried this using several chips, all 18F series. The original 4 channel code works fine
  1. Replies: 10
    Last Post: - 21st December 2013, 18:48
  2. "symbol not previously defined" on 16F1933 - fuse issue i think
    By comwarrior in forum mel PIC BASIC Pro
    Last Post: - 2nd January 2011, 03:24
  3. Symbol not previously defined
    By Archangel in forum Code Examples
    Last Post: - 27th December 2008, 09:52
  4. not previously defind (_INTRC_OSC) errror
    By teverett in forum mel PIC BASIC Pro
    Last Post: - 18th October 2006, 17:59
  5. Replies: 3
    Last Post: - 3rd September 2003, 12:05
