How to communicate with MLX90614 IR sensor
Results 1 to 7 of 7
Threaded View
  1. #5
    Oct 2014
    Default Re: How to communicate with MLX90614 IR sensor
    After way too much time I got code that works with the MLX90614 temperature sensor. It may not be the most elegant but given the timing required by the SMBus this works.
    I wish this sensor would have used the I2C standard. Things would have been a lot easier.
    '*  Name    : MLX90614_final.BAS
    '*  Author  : Tom Baraniak  [email protected]
    '*  Notice  : Copyright (c) 2015 [select VIEW...EDITOR OPTIONS]
    '*            : All Rights Reserved
    '*  Date    : 4/4/2015
    '*  Version : 1.0
    '*  Notes   :
    '       MLX90614 test using PIC16F688 running at 8MHz
    DEFINE  OSC 8                            '8 MHz clock frequency, others not supported by PBP
    define  HSER_RCSTA 90h                   'enable the serial port receiver
    define  HSER_TXSTA 24h                   'set up the serial port, enable transmit for fast clock
    define  HSER_BAUD  9600                  'select the baud rate, run slow for the RF xmitter
    define  HSER_CLROERR 1                   'automatically clear the buffer overrun error
    DEFINE SHIFT_PAUSEUS 20                  'slow down the shift in clock or it is too fast for the MLX
    reg         var word
    addr        var byte
    TLOW        var byte
    THI         var byte
    tir         var word
    j           var byte
    command     var byte
    ACK         var byte
    FIXHI       var byte
    tempir      var word
    tout        var word
    SDA     var     portc.2
    SCL     var     portc.1
    TxD     var     portc.4
    RxD     var     portc.5                                                           '
    CMCON0 = %00000111                       'comparator off
    OSCCON = %01110111                       'runs at 8 MHz internal clock
    ADCON0 = %10000000                       'ADC is disabled
    ANSEL  = %00000000                       'all digital
    TRISA  = %11111111                       'set up port A where 1 = input, 0 = output
    TRISC  = %11101001                       'set up port C where 1 = input, 0 = output
    '                   IR GROUND TEMPERATURE SENSOR
    '       The RAM address 0x07 contains the linearied object temperature data, low byte first
    '       The slave address that is the MLX90614 is 0xB4
    sda = 1                                 'at the start
    scl = 1
    luup:
    hserin 1000, luup, [command]
    if command = "B" then                         'typing a "B" calls the temperature reading code.  This is not part of the MLX code.
        call bitbang
    goto luup
    bitbang:
    SDA = 0                                  'start
    pauseus 15                              'Can't be too fast so I added some delay.  Easier to see on the scope too.
    SCL = 0
    pauseus 15
         'This segment generates salve address B4  1011010x where x is the 8th (unused) bit (actually W).  Since W is a 0 anyway the x = 0.
         'There may be a more elegant way of sending these 8 bits but this way works and all the timing and sequencing is correct.
    sda = 1         '1
    pauseus 15
    scl = 1
    pauseus 15
    scl = 0
    pauseus 15
    sda = 0         '0
    pauseus 15
    scl = 1
    pauseus 15
    scl = 0
    pauseus 15
    sda = 1         '1
    pauseus 15
    scl = 1
    pauseus 15
    scl = 0
    pauseus 15
    sda = 1         '1
    pauseus 15
    scl = 1
    pauseus 15
    scl = 0
    pauseus 15
    sda = 0         '0
    pauseus 15
    scl = 1
    pauseus 15
    scl = 0
    pauseus 15
    sda = 1         '1
    pauseus 15
    scl = 1
    pauseus 15
    scl = 0
    pauseus 15
    sda = 0         '0
    pauseus 15
    scl = 1
    pauseus 15
    scl = 0
    pauseus 15
    sda = 0
    pauseus 15
    scl = 1         ' W
    pauseus 15
    scl = 0
    pauseus 15
    input sda                               'make sda an input for acknowledge A part of sequence
    pauseus 15
    scl = 1
    pauseus 15
    scl = 0
    pauseus 15
    output sda                              'make sda an output again to send register 0x07
    sda = 0
    pauseus 15
    for j = 1 to 5                           'for/next loop is quick for the 5 leading zeroes
    scl = 1
    pauseus 15
    scl = 0
    pauseus 15
    next
    sda = 1                                  'for/next loop for the three 1's
    for j = 1 to 3
    pauseus 15
    scl = 1
    pauseus 15
    scl = 0
    next
    pauseus 15
    pauseus 15
    scl = 1
    pauseus 15
    scl = 0
    pauseus 15
    output sda                              'make sda an output again for S
    pauseus 15
    sda = 1
    pauseus 15
    scl = 1
    pauseus 15
    sda = 0
    pauseus 15
    scl = 0
    pauseus 15
         'Like the code for B4 this segment generates B5   1011010x where x is the 8th (unused) bit (actually R).  The x=1 (0101 == 5) which R is.
         'Again, there may be a more elegant way of sending these bits but this works and the timing and sequence are correct.
    sda = 1         '1
    pauseus 15
    scl = 1
    pauseus 15
    scl = 0
    pauseus 15
    sda = 0         '0
    pauseus 15
    scl = 1
    pauseus 15
    scl = 0
    pauseus 15
    sda = 1         '1
    pauseus 15
    scl = 1
    pauseus 15
    scl = 0
    pauseus 15
    sda = 1         '1
    pauseus 15
    scl = 1
    pauseus 15
    scl = 0
    pauseus 15
    sda = 0         '0
    pauseus 15
    scl = 1
    pauseus 15
    scl = 0
    pauseus 15
    sda = 1         '1
    pauseus 15
    scl = 1
    pauseus 15
    scl = 0
    pauseus 15
    sda = 0         '0
    pauseus 15
    scl = 1
    pauseus 15
    scl = 0
    pauseus 15
    sda = 1
    pauseus 15
    scl = 1         ' R
    pauseus 15
    scl = 0
    pauseus 15
    sda = 0
    pauseus 15
    input sda                               'make sda an input for acknowledge A part of sequence.  It remains an input heading into shiftin
    pauseus 15
    scl = 1
    pauseus 15
    scl = 0
    pauseus 15
    shiftin SDA, SCL, 0, [TLOW, ack\1, thi]     'Now we can use the shiftin command to read the 8 least significant bits, the single acknowledge
                                                             'bit, and the 8 most significant bits.
    tempir = thi * $100                     'shifts 8 bits to the left to move this byte to the upper 8 bits of a word
    tempir = tempir + tlow                  'add the lower byte to the upper byte to make a word
    tout = tempir/50                         'each bit is .02 degrees K so either multiply by .02 or divide by 50
    tout = tout - 273                        'subtract 273.15 (to get temperature in degrees C
    hserout ["T = ", dec tout, 9, dec tempir, 9, dec THI, 9, dec TLOW, 13]
    pause 1000                               'added for readability during testing
    trisc.1 = 0                                'both sda and scl are outputs to reset for the next time thru
    trisc.2 = 0
    sda = 1                                    'they both start high
    scl = 1
    pause 100                                 'not needed
  1. Replies: 6
    Last Post: - 5th August 2013, 15:43
  2. Cheapest way to communicate
    By koossa in forum Off Topic
    Last Post: - 25th May 2009, 13:06
  3. Communicate PC-to-PC using PIC
    By aje_azam in forum USB
    Last Post: - 16th March 2009, 08:35
  4. What's the best way to communicate?
    By BobK in forum mel PIC BASIC Pro
    Last Post: - 2nd October 2004, 07:54
  5. pc communicate with pic16f877
    By meyou in forum mel PIC BASIC Pro
    Last Post: - 6th August 2004, 00:26
