methods to incorporate led in a keypad matrix manufacture
Results 1 to 3 of 3
    Feb 2012
    PERTH AUSTRALIA
    Default methods to incorporate led in a keypad matrix manufacture
    hi , i am,looking to incorporate leds into the matrix keyboard design and manufacture of the PET
    the current thought , where the keyboard used mr eds scan rouine where the rows pulled high( 4k7 )change to 1k and then polled low depending on the scan rate
    my requirement is to show a mode led a,b,c constantly , ( led appears on )
    the current thought is to scan the keybaord , and then turn on the low return when the scan is complete for the mode after the scans , i need to change the standard 4k7 pullup to 1k and use the 100R low feed to allow the led to show up when using 3.3v
    this should work ?
    Name:  KEY MATRIX PAD.JPG
    Sep 2009
    Default Re: methods to incorporate led in a keypad matrix manufacture
    Only problem that I see is when you press 2 buttons.
    It will affect leds and put about 17mA thru that printed track. It should be ok, but...
    Feb 2012
    PERTH AUSTRALIA
    forgot about 2 buttons on , but thats no big one
  1. Matrix Keypad routine
    By mister_e in forum Code Examples
    Last Post: - 18th September 2022, 20:30
  2. Replies: 0
    Last Post: - 26th January 2015, 05:18
  3. 8x8 keypad matrix...
    By mbox in forum General
    Last Post: - 9th October 2014, 18:43
  4. Replies: 2
    Last Post: - 15th December 2012, 01:19
  5. Need help in matrix keypad coding
    By rano_zen06 in forum mel PIC BASIC Pro
    Last Post: - 24th May 2008, 13:16
