Connecting PIC to servos
Results 1 to 7 of 7
Threaded View
  1. #7
    Default Re: Connecting PIC to servos
    Quote Originally Posted by The Master View Post
    Archangel: I used Off Topic because I didn't think this thread fit into any of the other forums.
    I was not an "issue", these questions usually crop up in other areas like PBP or PBP3 . . . , throw in some code and it could move to one of those areas as seems pertinent. The questions you asked are valid, esp. since you didn't really know the answer, if you needed to know this, others did too.
    The long answer to your question is it depends upon how strong the "noise" signal is vs the signal voltage. If that wire length is able to receive over about 1 volt or so out of "the aether" it could be a problem, worse if it receives 2 volts. Twist the wires and it works better too, less noise received than straight parallel wires.
  1. Replies: 2
    Last Post: - 13th September 2013, 11:27
  2. Problem with servos
    By ncet20 in forum General
    Last Post: - 11th October 2011, 15:22
  3. Hot Servos
    Last Post: - 6th August 2010, 19:32
  4. Connecting ibutton to pic!
    By jkbpower in forum Schematics
    Last Post: - 4th December 2008, 08:09
