XOR woes
Results 1 to 3 of 3
Thread: XOR woes
Threaded View
    Default XOR woes
    Hi, need some help, guys!
    I need to set a port to a certain value, depending on another variable which will have only 1 of 2 possible values, 0 or 255.
    For example, if the variable is 0, the port should output 45; if the variable is 255, the port should output its complement, 210.
    Now, I expected an XOR'ing of the 2 values to give the following results:
    0 XOR 45 = 45
    255 XOR 45 = 210
    However, what I get are pretty random results.
    I have tried both operators (XOR as well as ^), with no luck.
    Any idea what's happening?
  1. Logical difference between 2 8-bit ports XOR?
    By circuitpro in forum mel PIC BASIC Pro
    Last Post: - 23rd July 2010, 05:17
  2. XOR result different with PC application
    Last Post: - 26th January 2009, 05:56
  3. Xor?
    Last Post: - 12th October 2008, 07:13
  4. Xor Sum
    By Sphere in forum General
    Last Post: - 7th December 2006, 08:52
  5. Exclusive OR - XOR
    By Archangel in forum mel PIC BASIC Pro
    Last Post: - 14th September 2006, 10:44
