XOR woes
Results 1 to 3 of 3
Thread: XOR woes
    Default XOR woes
    Hi, need some help, guys!
    I need to set a port to a certain value, depending on another variable which will have only 1 of 2 possible values, 0 or 255.
    For example, if the variable is 0, the port should output 45; if the variable is 255, the port should output its complement, 210.
    Now, I expected an XOR'ing of the 2 values to give the following results:
    0 XOR 45 = 45
    255 XOR 45 = 210
    However, what I get are pretty random results.
    I have tried both operators (XOR as well as ^), with no luck.
    Any idea what's happening?
    Default Re: XOR woes
    You don't want to use the XOR operator, you want the ^ (bitwise XOR).
    A VAR BYTE
    B VAR BYTE
    C VAR BYTE
    HSEROUT["Start",13]
    A = 0 : B = 45
    GOSUB Display
    A = 255 : B = 45
    GOSUB Display
    PAUSE 10
    Display:
    C = A ^ B
    HSEROUT[DEC A, " ^ ", DEC B , " = ", DEC C,13]
    Gives
    Start
    0 ^ 45 = 45
    255 ^ 45 = 210
    If it doesn't work at your end, please post the code.
    Henrik, thanks for that. And sure, in its basic form the '^' operator works as expected.
    In this specific case, I realize that the complication(s)'s arisen because of the fact that the port being bit-manipulated has some pins which are inputs, and not to be controlled by the XOR.
    I'll need to mask off those bits, I guess.
    Thanks again
  1. Logical difference between 2 8-bit ports XOR?
    By circuitpro in forum mel PIC BASIC Pro
    Last Post: - 23rd July 2010, 05:17
  2. XOR result different with PC application
    Last Post: - 26th January 2009, 05:56
  3. Xor?
    Last Post: - 12th October 2008, 07:13
  4. Xor Sum
    By Sphere in forum General
    Last Post: - 7th December 2006, 08:52
  5. Exclusive OR - XOR
    By Archangel in forum mel PIC BASIC Pro
    Last Post: - 14th September 2006, 10:44
