FREQOUT command
Results 1 to 5 of 5
Thread: FREQOUT command
    Aug 2003
    Default FREQOUT command
    Hi Guys,
    I’m FREQING OUT about the FREQOUT command!
    No I’m not, but wondering how it works. I assume the command must add sine tables to the program,
    and already sum each frequency and divide by two before doing anything with PWM in order to get
    the mix of both frequencies out of a single pin?
    Anyway, I’m not finished, and also improved the sound by mixing a higher than audible frequency with solitary notes.
    This removes the “flutter” distortion heard in this video, and the result is instead something easier to filter.
    but just an experiment to share, it’s playing through a MAX232 chip:
    There’s a third channel ready to go.. the hardware PWM.
    Aug 2003
    Default Re: FREQOUT command
    Ok,
    Unfortunately the thing should have been driven by a timed interrupt
    to generate a spot on time signature.
    So it sux that to go any further this verbose program has to be disposable :O
    It’s still possible to do a drummer (with brushes).
    Bombay, India
    You possibly have already run into this website. Just in case...
    http://www.pic24.ru/doku.php/en/osa/ref/intro
    Aug 2003
    I have no luck with the link there Jerson.. tried a couple of days now.
    Bombay, India
    I can access the link quite well from my side of the world. The following link would be interesting to you in particular. It is a Piano with touch keys done using the PIC_OSA (RTOS) using a PIC and wave tables. I suggest you try bending your access with a proxy server if you still find it hard to reach.
    http://www.pic24.ru/doku.php/en/osa/.../pk2_osa_piano
  1. Freqout ? ? ?
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2009, 00:39
  2. bootloader Freqout problems
    By handgio in forum mel PIC BASIC Pro
    Last Post: - 5th December 2007, 13:38
  3. FREQOUT - PWM question
    By Etcho in forum mel PIC BASIC Pro
    Last Post: - 25th February 2007, 23:51
  4. Freqout resets port pins?
    By MikeLewis in forum mel PIC BASIC Pro
    Last Post: - 16th July 2004, 04:29
  5. FREQOUT delays
    By Squibcakes in forum mel PIC BASIC Pro
    Last Post: - 6th December 2003, 23:49
