ADC values above 4095 for 12 bit ADC
Results 1 to 8 of 8
    Feb 2012
    PERTH AUSTRALIA
    Default ADC values above 4095 for 12 bit ADC
    seeing some readings when doing ADC on a channel giving a dec value 5534, 5144, ect when using ADCIN
    have defines set to 12 bit
    the adc channel is grounded via 26k resistor for testing
    problem is i cant see why the reading is there at such a high value , and the value should not exceed 4095
    any thoughts on why this may be happening ?????????
    cheers
    sheldon
       DEFINE OSC 32              ' Timing referance for pause , pauseus commands
        DEFINE ADC_BITS 12         ' Number of bits in ADCIN result - Required for adcin command
     ADCON1 =  %00100000           ' bit 7-6 = TRIGSEL 11= triger from RTCC, 10 = trigger from timer1 ,01 = trigger from CTMU, 00= trigger from ECCP2
                                    ' Bit 5-4 - VCFG+ 11= Internal VREF+(4.096v) ,10= Internal VREF+ (2.048v) 01=External VREF+ ,00= AVDD
                                    ' Bit3 - VNCFG-  1= External Vref- ,  0= AVSS Vref/A ,
                                    ' Bit 2-0 = Analoge Neg Ch Select ( Differential measurement )
                                    ' 111 = AN6, 110 = AN5, 101 = AN4,100 = AN3,011 = AN2, 010 = AN1, 001 = AN0,000 = AVSS,
      ADCON2 =  %10010010           ' bit 7 = 1 ADFM ( ADRESH, ADRESL - right justify ) , Bit6 n/a ,
                                    ' Bits 5-3 ACQT ( acquision time ) 111 = 20TAD ,110=16TAD,101-12TAD,100=8TAD,011=6TAD,010=4TAD,001=2TAD,000=0TAD
                                    ' Bit 2-0 ADCS ( AD clock sel) x11 =FRC , 110=Fosc/64,101= FOSC/16 ,100=FOSC/4 ,010=FOSC/32 ,001=FOSC/8, 000=FOSC/2
                                    ' Note:  define ADCIN clock  and define ADcin sample overide this setting
     ANCON2.1 = 1              ' Set PortG.3 = 1 - Select portG.3 to Analog  - AN17 - AD touch switch input 1R-TX mode
         TRISG.3  = 1              ' Set TRISG.3 = 1 - Select portG.3 to Input   - AN17 - AD touch switch input 1R-TX mode
         ADCON0 = %01000111        ' Select the A/D channel - AN17 turn on a/d
      adcin 17,value1            ' do ADC reading on AN17 - touch switch input
         HSEROUT2 ["value1 = ",dec4 value1,13,10]
      ADCON0 = %01000100        ' Select the A/D channel - AN17 and turn off A/D module
    value1 = 0003
    value1 = 0004
    value1 = 0002
    value1 = 0011
    value1 = 0005
    value1 = 0003
    value1 = 0004
    value1 = 0004
    value1 = 0005
    value1 = 0006
    value1 = 0004
    value1 = 0003
    value1 = 0005
    value1 = 0004
    value1 = 0004
    value1 = 0004
    value1 = 0003
    value1 = 0005
    value1 = 0002
    value1 = 0002
    value1 = 0005
    value1 = 0005
    value1 = 5535
    value1 = 5525
    value1 = 0004
    value1 = 0008
    value1 = 0002
    value1 = 0001
    value1 = 0004
    value1 = 0002
    value1 = 5534
    value1 = 5532
    value1 = 0005
    value1 = 0077
    value1 = 5529
    value1 = 0004
    value1 = 0008
    value1 = 0020
    value1 = 5524
    value1 = 5229
    value1 = 0025
    value1 = 0057
    value1 = 0002
    value1 = 5283
    Feb 2012
    PERTH AUSTRALIA
    Default Re: ADC values above 4095 for 12 bit ADC
    I think it may be a hardware problem with that ad channel , as testing other channels i dont have the problem
    Sep 2009
    You didn't tell what PIC you use. It can make big difference...
    For example PIC18F87K22 have differential inputs, and negative results are two’s complement of result. So for -1 = $FFFF, -2 = $FFFE etc.
    You can use SDEC to get correct result.
    Or you can use this:
    ADCIN 17,value1 'I'm not sure how ADCIN in handles negative numbers... So maybe manual reading of ADRES registers are better solution
    IF value1.1 = 1 THEN
        Sign="-"
        Sign=" "
    value1=ABS(value1)
    HSEROUT2 ["value1 = ",Sign, dec4 value1,13,10]
    Feb 2012
    PERTH AUSTRALIA
    thats a good thought about a negative input , and clearly the value for negative flag is being set
    the 18f67k22 , which i am using, Has AN0-AN6 as negative inputs , for differential input , selected by ADCON1- BITS 2-0 , where 00 = AVSS. and they are not being set
    AN4 is used for is used for ad input every 20 secs , but at no time is it set to a negative ref , by adcon1
    AD17 is part of comparitor 3 input , which is set to 0 so that should not be affecting it
    its got be stumped what setting maybe forcing the neg value ,
    and it feel like i have a setting wrong some where for an17
    i have moved to an7 to continue sorting out the CTMU for touch switch service , which has helped get a more consistent reading to sort out the touch function
    the CTMU is nice bit of the PIC chip "IF" you can work your way around all the possible settings including the interrupts ,
    i also note that the DT'S INts_18_k22.bas does not support the CTMU intrerupt for external pin triggering , and will need to be added or do it via a manual clearing of interupts , but thats for later
    Sep 2009
    Offset can be from internal differential amp or multiplexers. Inverting input is tied to GND when used in single input mode. You connect non inverting input also to GND. So any input offset or positive offset in inverting input multiplexer can produce small negative result, which look as large positive number.
    Feb 2012
    PERTH AUSTRALIA
    yep i cant see where it coming from , but it was not hard to use another a/d channel , but its something that i need to look at closer
    010=4TAD
    may be too short a time to get full conversion ???
    and especially @ 32 Mhz !!! ( have a look to datasheet ... )
    Feb 2012
    PERTH AUSTRALIA
    looking at table 23.1 4 tad should be ok at 32 mhz, using the setting of Fosc/32 for ADCS ???
    Name:  tad table.JPG
    Name:  tad conversion.JPG
    Name:  ad conversion spec.JPG
  1. Scaling ADC values
    By purkolator in forum mel PIC BASIC Pro
    Last Post: - 29th November 2007, 06:14
  2. Flash PIC with 12 bit ADC
    By Steve_88 in forum mel PIC BASIC Pro
    Last Post: - 12th October 2007, 21:35
  3. Adc giving widely flactuating values
    By tamersoss in forum mel PIC BASIC Pro
    Last Post: - 17th December 2006, 09:59
  4. MAX1247 4-Channel, 12-Bit ADC
    By Atom058 in forum mel PIC BASIC Pro
    Last Post: - 16th December 2006, 00:38
  5. Need help with 16f819 10 bit ADC
    By bannrikae in forum mel PIC BASIC Pro
    Last Post: - 26th September 2005, 16:20
