defines values for 2nd / 3rd serial ports
Results 1 to 4 of 4
    Feb 2012
    PERTH AUSTRALIA
    Default defines values for 2nd / 3rd serial ports
    hi guys ,
    was wondering what the define values would be for the 2nd and 3rd serial port , only ever seen for port A
    DEFINE HSER_RCSTA 90h ' Hser receive status init
    DEFINE HSER_TXSTA 24h ' Hser transmit status init
    DEFINE HSER_BAUD 38400 ' Hser baud rate
    regards
    Sheldon
    Jan 2013
    Texas USA
    Default Re: defines values for 2nd / 3rd serial ports
    In section 8.1 of the PBP manual it shows the HSER defines. There are defines for HSER (port1) and HSER2 (port2).
    I don't see anything about port3.
    TABSoft
    Feb 2012
    PERTH AUSTRALIA
    thanks , always good to rtfm with a number to go look for
    for those looking for the defines in the manual its
    section 8.7 , with the other details of the serial ports options within section 8.x
    DEFINE HSER_PORT 1 'HSER port to use on devices
    with more than one
    DEFINE HSER2_BAUD 2400 'HSER2 baud rate
    DEFINE HSER2_SPBRG 25 'HSER2 SPBRG2 init
    DEFINE HSER2_SPBRGH 0 'HSER2 SPBRGH2 init
    DEFINE HSER2_RCSTA 90h 'HSER2 receive status init
    DEFINE HSER2_TXSTA 20h 'HSER2 transmit status init
    DEFINE HSER2_EVEN 1 'HSER2 If even parity desired
    DEFINE HSER2_ODD 1 'HSER2 If odd parity desired
    DEFINE HSER2_BITS 9 'HSER2 Use for 8 bits + parity
    DEFINE HSER2_CLROERR 1 'Automatically clear HSERIN2
    overflow errors
    Jan 2013
    Texas USA
    Yes, well it helps if you're given the correct number. Oops.
    TABSoft
  1. how to store received values in serial communication ?
    By engasm in forum mel PIC BASIC Pro
    Last Post: - 25th June 2012, 00:42
  2. DT Instant Interupt with a 2nd serial port
    By ecoli-557 in forum mel PIC BASIC Pro
    Last Post: - 11th January 2012, 06:09
  3. Serial Port Complete 2nd Edition
    By Bruce in forum Serial
    Last Post: - 8th November 2007, 15:28
  4. multipal serial ports
    By Andre_Pretorius in forum Serial
    Last Post: - 11th September 2007, 14:53
  5. TTL input - 3rd states possible?
    Last Post: - 31st March 2007, 16:04
