Input problems with 12F629?
Results 1 to 14 of 14
    Sep 2010
    Las Vegas, NV
    Default Re: Input problems with 12F629?
    Thanks for straightening me out. You learn something new every day.
    Mar 2008
    I have read this thread several times and looked at the datasheet several time as well. I am having problems with code that has worked fine in the past and suddenly I can not make GPIO.0 and GPIO.3 function as inputs. This is the code I have used in the past. I have added a TRISIO statement and this does not seem to help either. “TRISIO = %11001011”
    This code works on GPIO.1 but not on GPIO.0 and GPIO.3. I have used three ICs and continue to have no luck?
    #IF __PROCESSOR__ = "12F629"
    #DEFINE MCU_FOUND 1
    cfg = _INTRC_OSC_NOCLKOUT ; INTOSC oscillator: I/O function on GP4/OSC2/CLKOUT pin, I/O function on GP5/OSC1/CLKIN
    cfg&= _WDT_ON ; WDT enabled
    cfg&= _PWRTE_OFF ; PWRT disabled
    cfg&= _MCLRE_OFF ; GP3/MCLR pin function is digital I/O, MCLR internally tied to VDD
    cfg&= _BODEN_ON ; BOD enabled
    cfg&= _CP_ON ; Program Memory code protection is enabled
    cfg&= _CPD_OFF ; Data memory code protection is disabled
    __CONFIG cfg
    #ENDIF
    #IFNDEF MCU_FOUND
    #ERROR "No CONFIGs found for [" + __PROCESSOR__ +"]"
    #ENDIF
    CMCON = 7
    SYMBOL LTIN = GPIO.0 'input
    SYMBOL RTIN = GPIO.1 'input
    SYMBOL LTOUT = GPIO.2 'output
    SYMBOL FOURIN = GPIO.3 'input
    SYMBOL RTOUT = GPIO.4 'output
    SYMBOL PEIZO = GPIO.5 'output
    Over:
    IF LTIN = 1 THEN HIGH PEIZO
    IF LTIN = 0 THEN LOW PEIZO
    IF RTIN = 1 THEN HIGH PEIZO
    IF RTIN = 0 THEN LOW PEIZO
    IF FOURIN = 1 THEN HIGH PEIZO
    IF FOURIN = 0 THEN LOW PEIZO
    GOTO OVER
    Dec 2008
    Ploiesti, ROMANIA
    See this post : http://www.picbasic.co.uk/forum/show...=7072#post7072
    Maybe is useful !
    Mar 2008
    I just found my problem. It was these two lines
    I had changed my board on the last run and forgot to change the pin numbers in the code. The input was working fine it was the output the whole time.My silly mistake
    SYMBOL RTOUT = GPIO.5
    SYMBOL PEIZO = GPIO.4
    I am back up and running thank You for your reply!
  1. Timing input pulses and re-outputting them
    Last Post: - 28th February 2007, 02:50
  2. Input problems
    By ALFRED in forum mel PIC BASIC Pro
    Last Post: - 23rd July 2006, 22:02
  3. Using GPIO.3 as input on 12F629
    By Sharky in forum mel PIC BASIC Pro
    Last Post: - 5th May 2006, 20:41
  4. Input on 12F629
    By BGreen in forum mel PIC BASIC Pro
    Last Post: - 16th March 2005, 12:14
  5. 12F629 I2C problems
    By AIW128ProGuy in forum mel PIC BASIC Pro
    Last Post: - 12th November 2004, 00:41
