Detection of 1 wire device
Results 1 to 10 of 10
    Oct 2009
    Default Detection of 1 wire device
    I have a single 18B20 temp sensor and read the device using the code below
    'Get and display the temperature
    GIE = 0
    OWOUT DQ, 1, [$CC, $44]                 ' Start temperature conversion
    OWOUT DQ, 1, [$CC, $BE]                 ' Read the temperature
    OWIN DQ, 0, [temperature.LOWBYTE, temperature.HIGHBYTE]
    GIE = 1
    temperature = temperature */ 1600
    lcdout $FE,$D4+0,"TEMP ",dec(temperature / 100),$DF,"C"
    What I would like to do is detect if the sensor is connected or not, and if it's not present to simply display "N/C" in place of the temperature
    Any suggestions
    Quebec, Canada
    Default Re: Detection of 1 wire device
    Each device has it's unique serial number, you could try read it or write something in the scratch pad (just once) and try read it back.
    Oct 2009
    Utah, USA
    From the manual, the OWIN command...
    If a device is not present, OWIN can jump to an optional Label.
    You should be able to just use the Label function of the OWIN command to have your program jump to a routine that displays "N/C"
    GIE = 0
    OWIN DQ, 0, [temperature.LOWBYTE, temperature.HIGHBYTE], NoDevice
    GIE = 1
    NoDevice:
    lcdout $FE,$D4+0,"No One Wire Device Detected"
    GOTO main
    Dwight
    Oct 2009
    Thanks for the replies.
    Dwight, I tried your example, but all that happened was a mixture of the text on line 4 of the LCD. I'll keep experimenting maybe taking the NoDevice a gosub rather than goto... But thanks for putting me on the right track
    I'm sure you would get a better result if you actually waited for the ds18b20 to perform the measurement
    GIE = 0
    pause 800
    GIE = 1
    Oct 2009
    Cheers Richard,
    I stumbled across a PDF on one wire devices from Microchip, and it suggested the following
    OW_reset_pulse
    Describes 1-Wire protocol to generate Reset pulse to detect the presence of the 1-Wire slave device.
    Syntax
    unsigned char OW_reset_pulse(void)
    Parameters
    None
    Return Values
    Return ‘
    0
    ’ if the slave device presence pulse is detected, return ‘
    1
    ’ otherwise.
    Precondition
    None
    Side Effects
    None
    Example
    // OW_reset_pulse function return the presence pulse from the slave device
    if (!OW_reset_pulse())
    return HIGH; // Slave Device is detected
    return LOW; // Slave Device is not detected
    But this uses ASM, so I'll do some further reading on PBP to see if this can be done in basic rather than ASM
    Oct 2009
    I've been reading through the PBP manual and it really peaves me when manuals state
    But doesn't give you a working example !!
    So it would suggest the reset command would be the best option to ping the device and if it's not present it won't get an answer back
    Oct 2009
    Not sure if the logic is correct but this works
    [code]
    GIE = 0
    owin DQ, 1, [],NoDevice
    GIE = 1
    fan:'check to see if fan is needed
    fantrigger=fanset
    if (temperature / 100)> fantrigger then
    high portA.4
    NoDevice:
    lcdout $FE,$D4+0,"TEMP N/C "
    GIE = 1
    goto fan
    [code]
    The NoDevice section is outside of the main part of the program. The logic being that the PIC sends a reset pulse and if it's not received back then jumps out to the NoDevice section, and then goes to the next part of the code but skips the temperature reading section. Seems to work when I pull out the DS18B20 and then plug it back in
    Denmark
    Hi
    I use this, and it work's
    check_sensorID:
    ' Check is the sensor connected
    OWOUT DQ, 1, [ $33 ] ' Read Chip Family code
    OWIN DQ, 2, [ FAM,ID[6],ID[5],ID[4],ID[3],ID[2],ID[1],CRC]
    if (ID[1] = 0)and (ID[2] = 0)and(ID[3] = 0)and (ID[4] = 0)and (ID[5] = 0)and (ID[6] = 0) then
    LcdOut $FE, 1, " NO " ' Show message
    Lcdout $FE, $C0, " Sensor "
    Kent
    Oct 2009
    Utah, USA
    Go take a look at the last post in this thread...
    http://www.picbasic.co.uk/forum/showthread.php?t=18313
    Dwight
  1. Replies: 1
    Last Post: - 5th October 2011, 08:59
  2. Target Device does not match selected device
    By queenidog in forum FAQ - Frequently Asked Questions
    Last Post: - 25th June 2011, 00:24
  3. Target device <> Selected Device????
    By deepgfishing in forum mel PIC BASIC Pro
    Last Post: - 20th June 2007, 21:18
  4. mass storage device 1 MB Flash device
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 31st August 2006, 03:11
  5. Emulate a 1-wire device
    By johnyman34 in forum mel PIC BASIC Pro
    Last Post: - 22nd February 2005, 20:05
