Hi Matias,
Yes, when you do things like thatRunning at high speed can cause RMW issues. What happens is that for each "bit-flip" the port is read, bit is flipped, port is being written.Code:porta.0 = 1 porta.1 = 1 porta.2 = 1 porta.3 = 1
Because the "limited" current capability of the output driver the voltage at the output doesn't rise instanously. So when PORTA.1=1 executes and the port is read the voltage at PORTA.0 hasn't reached a voltage above the threshold for a logic high so when the port is written back after flipping bit 1 bit 0 will be re-written as 0.
