uv set solder mask , how do i get a good result ?
Results 1 to 5 of 5
    Default uv set solder mask , how do i get a good result ?
    I bought some uv set solder mask http://www.ebay.com/itm/New-10cc-UV-...-/371198380554
    these are the instructions I received
    Features:
    100% Brand New
    High Quality
    10ml UV green paint.
    Features with quick curing.
    Insulates printed circuit board against shorting and arcing.
    This paint is used to protect PCB traces from corrosion, moisture.It is also used for repairing PCB after soldering, rework.
    Specifications:
    Color: Green
    Syringe Length: Approx. 10 cm
    Material: Paint
    Capacity: 10ml / 10cc
    Usage:
    Apply paint on your PCB.
    Spread it on the PCB with covering the transparent mask film.
    Expose it under UV light ( or sun ) for a few minutes.
    Wash away the extra paint by gasoline or oil base solvent.
    the trouble is that the mask sticks to the solder mask overlay far better than it does to the pcb, I think I need some sort of uv transparent film between the overlay and the board .
    does anybody know of something that works ?
    Default Re: uv set solder mask , how do i get a good result ?
    In this video it looks like he applies the paint and then uses a thin piece of plastic between the paint and the artwork.
    I would like to try this also.
    thanks mark
    the video is way much better than the instructions I got with the product , I will have another go with some cellophane
    success
    used a ziplok sandwich bag (its a rf12b/69cw breakout board)
    the mask is for a slightly different layout , its only an experiment
    Nice Job!
    If you perfect the process, post your methods. It will be better than translating Chinglish.
  1. Replies: 2
    Last Post: - 10th August 2012, 22:56
  2. Replies: 0
    Last Post: - 9th August 2012, 12:55
  3. Replies: 4
    Last Post: - 30th May 2012, 09:28
  4. Compute Bit Mask
    By harmand in forum Off Topic
    Last Post: - 6th March 2008, 16:23
  5. OT- lead free solder
    Last Post: - 14th May 2006, 00:04
