porta.0 and porta.2 only goes high with HIGH command with PIC18F45K80
Results 1 to 10 of 10
    Dec 2014
    Default Re: porta.0 and porta.2 only goes high with HIGH command with PIC18F45K80
    Setting the outputs with latx.x instead of portx.x solved the problem.
    Tanks.
    Jan 2013
    Texas USA
    Glad to hear this got you moving ahead.
    There are plenty of posts on this forum regarding read-modify-write as well as a straight internet search on the subject if you want to understand the issue better.
    TABSoft
  1. PortA Doesn't Work
    Last Post: - 8th September 2015, 18:41
  2. Replies: 10
    Last Post: - 14th April 2014, 20:47
  3. high voltage high frequency H-Bridge
    By George in forum Off Topic
    Last Post: - 27th April 2009, 11:50
  4. AD works in Porta.0 but not in porta.1
    Last Post: - 19th February 2008, 20:22
  5. turning gpio.0 high after pwm command
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 21st February 2007, 18:22
