porta.0 and porta.2 only goes high with HIGH command with PIC18F45K80
Results 1 to 10 of 10
    Dec 2014
    Default Re: porta.0 and porta.2 only goes high with HIGH command with PIC18F45K80
    After taking a quick look in the datasheet it seems like that coulld be it.
    I will test that tomorrow.
    Thanks.
    Sep 2010
    Las Vegas, NV
    You don't say what you've got hooked up to the port pins. Could you post a schematic?
    Make sure to disable comparators & ECCP module. Using HIGH /LOW commands disables all analog (generally) for you. PICs default to Analog inputs and you have to be sure to turn it all off to get digital to work. And it makes sense too, analog inputs are incapable of causing any "unintended" actions downstream, like shorting something out or causing a machine to suddenly start running on power up. It is for THAT reason you should set your port states prior to assigning TRIS to outputs.
    Dec 2014
    Setting the outputs with latx.x instead of portx.x solved the problem.
    Tanks.
    Jan 2013
    Texas USA
    Glad to hear this got you moving ahead.
    There are plenty of posts on this forum regarding read-modify-write as well as a straight internet search on the subject if you want to understand the issue better.
    TABSoft
  1. PortA Doesn't Work
    Last Post: - 8th September 2015, 19:41
  2. Replies: 10
    Last Post: - 14th April 2014, 21:47
  3. high voltage high frequency H-Bridge
    By George in forum Off Topic
    Last Post: - 27th April 2009, 12:50
  4. AD works in Porta.0 but not in porta.1
    Last Post: - 19th February 2008, 21:22
  5. turning gpio.0 high after pwm command
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 21st February 2007, 19:22
