How weird, in the code everything is ok so it must have happened when I pasted the code.
Here is the code again
' PIC18F45K80 Configuration Bit Settings
CONFIG RETEN = OFF
CONFIG INTOSCSEL = HIGH
CONFIG SOSCSEL = DIG
CONFIG XINST = OFF
CONFIG FOSC = EC3
CONFIG PLLCFG = OFF
CONFIG FCMEN = OFF
CONFIG IESO = OFF
CONFIG PWRTEN = ON
CONFIG BOREN = OFF
CONFIG BORV = 3
CONFIG BORPWR = ZPBORMV
CONFIG WDTEN = OFF
CONFIG WDTPS = 1048576
CONFIG CANMX = PORTB
CONFIG MSSPMSK = MSK7
CONFIG MCLRE = ON
CONFIG STVREN = OFF
CONFIG BBSIZ = BB2K
CONFIG CP0 = OFF
CONFIG CP1 = OFF
CONFIG CP2 = OFF
CONFIG CP3 = OFF
CONFIG CPB = OFF
CONFIG CPD = OFF
CONFIG WRT0 = OFF
CONFIG WRT1 = OFF
CONFIG WRT2 = OFF
CONFIG WRT3 = OFF
CONFIG WRTC = OFF
CONFIG WRTB = OFF
CONFIG WRTD = OFF
CONFIG EBTR0 = OFF
CONFIG EBTR1 = OFF
CONFIG EBTR2 = OFF
CONFIG EBTR3 = OFF
CONFIG EBTRB = OFF
'************************* DEFINES ******************************
define OSC 64
define LCD_DREG PORTC
define LCD_DBIT 0
define LCD_RSREG PORTC
define LCE_RSBIT 4
define LCD_EREG PORTC
define LCD_EBIT 5
define LCD_BITS 4
define LCD_LINES 2
define LCD_COMMANDUS 3000
define LCD_DATAUS 100
'************************ REGISTERS *****************************
ANCON0 = 000000
ANCON1 = 000000
ADCON0 = 000000
ADCON1 = 000000
'*********************** PORT CONFIG ****************************
TRISA = 100000 'porta direction 0=OUTPUT 1=INPUT
PORTA = 000000 'porta preset
TRISB = 010111 'portb direction 0=OUTPUT 1=INPUT
PORTB = 000000 'portb preset
TRISC = 000000 'portc direction 0=OUTPUT 1=INPUT
PORTC = 000000 'portc preset
TRISD = 111111 'portd direction 0=OUTPUT 1=INPUT
PORTD = 110000 'portd preset
TRISE = 001111 'porte direction 0=OUTPUT 1=INPUT
PORTE = 000000 'porte preset
'******************* MAIN PROGRAM ************************
lcdout $fe, $01
while 1
high porta.0
high porta.1
high porta.2
high porta.3
lcdout $fe, $80, bin8 porta
lcdout $fe, $c0, "HIGH"
PAUSE 1000
low porta.0
low porta.1
low porta.2
low porta.3
lcdout $fe, $c0, "LOW "
PAUSE 1000
porta.0 = 1
porta.1 = 1
porta.2 = 1
porta.3 = 1
lcdout $fe, $c0, "= 1 "
PAUSE 1000
porta.0 = 0
porta.1 = 0
porta.2 = 0
porta.3 = 0
lcdout $fe, $c0, "= 0 "
PAUSE 1000
wend
