Help with LCD Scroll
Results 1 to 15 of 15
    Aug 2003
    Default Re: Help with LCD Scroll
    I’m not sure what you mean there by “disabling line wrap not possible”.
    Did you get what you want done?
    Thanks Art
    See my first post in this thread. I have not been able to accomplish that
    Ken
    Aug 2003
    The way I read it, that should be what the version Tabsoft posted does.
    I might be seeing something else in my mind, or does it just scroll the wrong direction?
    Basically, this could be written simpler if it never had to be a real program.
    You could ditch the line buffer and rotate routine, step the index where you read the lookup table,
    check it’s bounds, and write 20 char to LCD at a time directly to LCD.
    Usually you want to look at, or change the display data, so I’d normally prepare
    all lines of text in buffers, and write all four lines from the line's start positions for every frame.
    even if the text doesn’t change or move.
    If you never write past the end of a line the text can’t wrap.
    Jan 2013
    Texas USA
    Carrying on with what Art mentioned previously.
    I looked pretty closely at the LCD controller and can not find away to disable the line wrapping when you use a shift command.
    Looks like that is the way the controller works.
    That being said I put together this program that will shift the message from Right to Left.
    See if this helps.
    '*  Name    : LCDScroll_v1.pbp        *
    '*  Author  : TABSoft        *
    '*  Notice  : Copyright (c) 2015 TABSoft                                                         *
    '*  Date    : 2/6/2015                                          *
    '*****PIC MCU Configuration Fuses (MPASM)*****
    #IF __PROCESSOR__ = "18F4620"
            CONFIG OSC = ECIO6            ; EC oscillator, port function on RA6
            ;CONFIG OSC = INTIO67	      ; Internal oscillator block, port function on RA6 and RA7
            ;CONFIG  WDT = OFF             ; WDT disabled (control is placed on the SWDTEN bit)
            CONFIG  PWRT = OFF            ; PWRT disabled
            CONFIG  BOREN = SBORDIS       ; Brown-out Reset enabled in hardware only (SBOREN is disabled)
            CONFIG  BORV = 3              ; Minimum setting
            CONFIG  WDT = ON              ; WDT enabled
            CONFIG  WDTPS = 512           ; 1:512
            CONFIG  CCP2MX = PORTC        ; CCP2 input/output is multiplexed with RC1
            CONFIG  PBADEN = OFF          ; PORTB<4:0> pins are configured as digital I/O on Reset
            CONFIG  LPT1OSC = OFF         ; Timer1 configured for higher power operation
            CONFIG  MCLRE = ON            ; MCLR pin enabled; RE3 input pin disabled
            CONFIG  STVREN = ON           ; Stack full/underflow will cause Reset
            CONFIG  DEBUG = OFF           ; Background debugger disabled, RB6 and RB7 configured as general purpose I/O pins
            CONFIG  CP0 = OFF             ; Block 0 (000800-003FFFh) not code-protected
            CONFIG  CP1 = OFF             ; Block 1 (004000-007FFFh) not code-protected
            CONFIG  CP2 = OFF             ; Block 2 (008000-00BFFFh) not code-protected
            CONFIG  CP3 = OFF             ; Block 3 (00C000-00FFFFh) not code-protected
            CONFIG  CPB = OFF             ; Boot block (000000-0007FFh) not code-protected
            CONFIG  WRT0 = OFF            ; Block 0 (000800-003FFFh) not write-protected
            CONFIG  WRT1 = OFF            ; Block 1 (004000-007FFFh) not write-protected
            CONFIG  WRT2 = OFF            ; Block 2 (008000-00BFFFh) not write-protected
            CONFIG  WRT3 = OFF            ; Block 3 (00C000-00FFFFh) not write-protected
            CONFIG  WRTC = OFF            ; Configuration registers (300000-3000FFh) not write-protected
            CONFIG  WRTB = OFF            ; Boot Block (000000-0007FFh) not write-protected
            CONFIG  EBTR0 = OFF           ; Block 0 (000800-003FFFh) not protected from table reads executed in other blocks
            CONFIG  EBTR1 = OFF           ; Block 1 (004000-007FFFh) not protected from table reads executed in other blocks
            CONFIG  EBTR2 = OFF           ; Block 2 (008000-00BFFFh) not protected from table reads executed in other blocks
            CONFIG  EBTR3 = OFF           ; Block 3 (00C000-00FFFFh) not protected from table reads executed in other blocks
            CONFIG  EBTRB = OFF           ; Boot Block (000000-0007FFh) not protected from table reads executed in other blocks
    #else
        #ERROR "This program requires a PIC 18F4620 MCU"
    #endif
    OSCCON = $60  ' Set PIC to 4Mhz & ECIO Clock Mode
       ADCON0.0 = 0  ' A/D Converter module is disabled
       ADCON1 = $0F  ' %0000 1111 AN2=VSS, AN3=VDD, AN12-0 = Digital
       ADCON2 = $00  ' %0000 0000
       TRISB = %11111111 ' Set PORTB as input
       INTCON2.7 = 0 ' Enable PORTB pullups
       TRISC = TRISC & %11011111   ' Set PORTC pin directions (pin5 output to RTC VCC2)
    '*****Define LCD registers and bits*****
    define LCD_BITS      4  '8  '4
    define LCD_LINES     2  ' Set to number of lines for the LCD
    Define LCD_DREG      PORTD
    Define LCD_DBIT      4  '0  '4
    Define LCD_RSREG     PORTE
    Define LCD_RSBIT     0
    Define LCD_EREG      PORTE
    Define LCD_EBIT      1
    define LCD_RWREG     PORTE
    define LCD_RWBIT     2
    define LCD_COMMANDUS 1500
    define LCD_DATAUS    44
    ' Software Constants
    LastLCDCol con 19
    ' number of Columns in your LCD
    ' Software variables
    LCD_Line1 var byte [50] 'Array to hold the Line 1 LCD Message (0 to 49)
    L1_ArrayLen var byte    'Length of LCD Line 1 Message Array
    StartPos var byte       'Pointer to start of message in Array
    idx var byte            'Current index into Message Array
    MaxCount var byte       'Loop counter max number
    LoopCount var byte      'Loop Counter
    i var byte
    '*****Intialize Variables*****
    L1_ArrayLen=50
    '*****Initialize LCD Line 1 Message Array*****
    arraywrite LCD_Line1, ["This is a test of the scrolling text screen...... "]
    '*****Initialize LCD*****
       Low LATE.2  		    ' LCD R/W line low (W)
       Pause 500       	  ' Wait .5 second for LCD to Initialize
    ' Program
    mainloop:
        MaxCount = 81
        LoopCount = 0
        StartPos = 0
        do
            lcdout $FE, $80
            LoopCount = LoopCount + 1
            for i = 0 to LastLCDCol
                idx = StartPos + i
                if idx > (L1_ArrayLen - 1) then
                    idx = (idx // L1_ArrayLen)
                lcdout LCD_Line1(idx)
            next i
            StartPos = StartPos + 1
            if StartPos > (L1_ArrayLen - 1) then
                StartPos = 0
            pause 500    'Adjust for best scrolling appearance
        loop while LoopCount < MaxCount
        pause 250
        goto mainloop   'Do it forever
        end     'Got here by mistake
    TABSoft
    Thanks TABSoft
    Sorry for the late response
    Ken
  1. Scroll text on LCD second line
    By Raadys in forum General
    Last Post: - 25th May 2013, 17:14
  2. trying to do a scroll window
    By AvionicsMaster1 in forum Test Area
    Last Post: - 7th September 2011, 15:00
  3. Scroll LCD?
    By polymer52 in forum mel PIC BASIC Pro
    Last Post: - 1st March 2010, 21:24
  4. Olympic timer Scroll Text
    By Patrick in forum mel PIC BASIC Pro
    Last Post: - 16th December 2006, 14:03
  5. how to scroll display one character
    By micro in forum General
    Last Post: - 13th March 2006, 23:32
