MRF90XAM9A interfacing help
Results 1 to 40 of 64
    Jan 2013
    Texas USA
    Default Re: MRF90XAM9A interfacing help
    Just curious.
    Did you ever get these modules working for your project?
    TABSoft
    Sep 2007
    Waco, Texas
    No I did not. I had used up so much time on this 'friendly' project I wasn't getting any of my fun projects moved forward.
    I have shelved it for the time.
    Are you trying to do the same thing?
    If you succeed, please share what you found out. I think my problem is in the interrupt settings - I think its transmitting, and receiving, just not getting out?!?
    "If we knew what we were doing, it wouldn't be called research"
    - Albert Einstein
    Sep 2007
    Waco, Texas
    Tabsoft-
    Did you get anywhere ?
    - Albert Einstein
    Jan 2013
    Texas USA
    Sorry for the delay.
    No I didn't get anywhere with this as I didn't pursue it further.
    Got off on different projects.
    TABSoft
    Sep 2007
    Waco, Texas
    I know, frustrating.
    I have a ticket with Microchip, perhaps they can shed some light....
    Regards.
    - Albert Einstein
    Oct 2010
    i've seen most of the RFM topics are not completed. I'm about to use the Adafruit RFM 69HCW for sending GPS data from one side to the other. (embedded the modules and the code on this project http://www.picbasic.co.uk/forum/show...936#post143936)
    I've seen other posts as well, whicht a guy tried to do the same thing with the GPS, but didnt see any luck.
    Has anyone finally succeed to those modules? I'm on holidays right now, and the following days i will try to configure the registers at first.
    It is sad that this amazing unique forum, not to have a start up code for each major application. Just for all the users to see and experiment with every single application.
    There are still very helpful guys here but non of them have posted a startup code for those modules. And i believe that not only me would love to see that kind of help.
    Thanks so much again for your time.
    [rant]
    its not the fault of the forum its pbp's total lack of development that causes the issue.
    pbp cannot easily manage memory/memory structures or most of the pic inbuilt hardware modules. its difficult to
    make easy to use flexible pin definitions to use in include files so that library functionality can be created.
    most of my stuff uses asm and usercommand to overcome some of these hurdles but that leads to another level
    of complexity for code that translates between pic16/18 platforms. half the people here never even upgraded to pbp3
    the lack of usercommand in pbp2 kills that sort of combability anyway. you would have to wonder if more people upgraded to
    pbp3 in the past if development would have continued instead of becoming a backwater. all this stuff is dead easy in C .plug and play in Arduino
    the rfm69 family of modules are a quite complex device to use , their range and speed make the effort worthwhile
    if warranted. i have used them for several years now and did initially use them with pbp3. i did not publish
    my code for a number of reasons :-
    i wrote it specifically to suit my application , to be compatabile with rfm12bs[a retrograde step] , the code is completey undocumented .
    you could write a small novel explaining usage of a rfm69w/cw/hcw... . i look back on other less complex things i have posted
    code for like TFT modules, i went to a lot of trouble to make it easy-ish and adaptable . i think 3 people have had some
    success in using the code . three people in the whole world FFS. the rfm69 code can be more complex and they are more exotic why would i
    bother.
    unless you really need the speed/range then there a many less complex devices to use. you thought my suggestions for your gps project
    were overly complex rfm69 code is of the same ilk maybe more so.
    i was going to say nrf24L01 is a candidate ,very cheap not too hard to use but just noticed i did not even bother to create a pbp include for them , its all C from here
  1. Interfacing LC75854
    By MR2010 in forum mel PIC BASIC Pro
    Last Post: - 18th July 2010, 02:42
  2. Keypad Interfacing
    By uaf5000 in forum mel PIC BASIC Pro
    Last Post: - 15th June 2010, 02:35
  3. Interfacing with the ISD4003
    Last Post: - 2nd June 2008, 15:25
  4. SPI Interfacing
    By toofastdave in forum Serial
    Last Post: - 18th November 2007, 11:15
  5. interfacing LCD
    By husakhalid in forum mel PIC BASIC
    Last Post: - 30th May 2006, 22:53
