MRF90XAM9A interfacing help
Results 1 to 40 of 64
    Sep 2007
    Waco, Texas
    Default Re: MRF90XAM9A interfacing help
    Crossed posts.....
    I changed the Register 00 to $2A and it still reports PLL bit as '0'.
    BUT, on page 30 of the DS it shows $00 for VTune to be determined by the inductors - not $01 ???
    Forget it, I was still reading the 140 page DS not the 36 page one for the module.
    I get it.....
    The RESET pin is tied to an IO on the proc, it is currently held low, but the module datasheet says in a high impedance state.
    Wonder if this is my issue? Should I let it float?
    "If we knew what we were doing, it wouldn't be called research"
    - Albert Einstein
    Sep 2007
    Waco, Texas
    Made PORTA.1 an input which is tied to the RESET pin, no help either.......
    Went back to earlier code and changed register $00 to $2A and have my pulses out of IRQ0 on the transmitter, but still nothing on the receiver.......
    Need a sniffer that works!
    - Albert Einstein
    Sep 2007
    Waco, Texas
    Changed the registers one more time - still no PLL lock being reported.
    Below:
         RF_Init_Values[0] = $2A                                                   'Standby mode, 915-928 MHz, VTune by inductors, ENABLE R1/P1/S1
         RF_Init_Values[1] = $8C                                                   'FSK, max IF gain, Packet Mode
         RF_Init_Values[2] = $03                                                   '100KHz Freq Dev
         RF_Init_Values[3] = $07                                                   '25kbps
         RF_Init_Values[4] = $0C                                                   'for OOK mode, not apliable
         RF_Init_Values[5] = $01                                                   '16Bytes FIFO, 1 byte threshold FIFO interrupt
         RF_Init_Values[6] = $77                                                   '915MHz R1 Reg
         RF_Init_Values[7] = $64                                                   '915MHz P1 Reg
         RF_Init_Values[8] = $32                                                   '915MHz S1 Reg
         RF_Init_Values[9] = $74                                                   '920MHz R2 Reg
         RF_Init_Values[10] = $62                                                  '920MHz P2 Reg
         RF_Init_Values[11] = $32                                                  '920MHz S2 Reg
         RF_Init_Values[12] = $38                                                  'config mode for OOK, not apliable
         RF_Init_Values[13] = $00                                                 'RCV:IRQ0=payload ready + IRQ1=CRC OK
        'TX: IRQ1=TXdone
         RF_Init_Values[14] = $01                                                  'FIFO starts filling when SYNC detected,TXDONE goes hi when done,
        'RSSI IRQ when is above level set, enable PLL lock
         RF_Init_Values[15] = $00                                                  'RSSI interupt level zero - minimum
         RF_Init_Values[16] = $A3                                                  'default filters config
         RF_Init_Values[17] = $38                                                  'default filters config
         RF_Init_Values[18] = $30                                                  'sync word ON, 24bits, 0 errors tolerance
         RF_Init_Values[19] = $07                                                  'reserved reg
         RF_Init_Values[20] = $00                                                  'RSII status read register, 0.5dB / bit
         RF_Init_Values[21] = $00                                                  'OOK config reg
         RF_Init_Values[22] = $53                                                  '"S" 1st byte of sync word
         RF_Init_Values[23] = $53                                                  '"S" 2nd byte of sync word
         RF_Init_Values[24] = $53                                                  '"S" 3rd byte of sync word  - my initials!
         RF_Init_Values[25] = $53                                                  '"S" just in case
         RF_Init_Values[26] = $72                                                  'Cutoff fcy = 200KHz, output power = 13dBm 0b000
         RF_Init_Values[27] = $3C                                                  'clk out disabled - default 427KHz
         RF_Init_Values[28] = $03                                                  '3 bytes payload
         RF_Init_Values[29] = $01                                                  'initial MAC ADDRESS, only for test
         RF_Init_Values[30] = $5E                                                  'Fix Packet Lenght, 3 bytes preamble, whitening ON, CRC ON, Node ADDR|0x00|0xFF filtering
         RF_Init_Values[31] = $00                                                  'FIFO autocreal enable if CRC fails, Write to FIFO in stby mode
    I'm frustrated ......
    - Albert Einstein
    Sep 2007
    Waco, Texas
    I now get a PLL lock indication, I put a wait until PLL lock bit was true before moving on.
                'Verify PLL Lock Flag
    PLLwait:    bReg_Address = $0E                                                  'FTPRIREG
                gosub RegisterRead
                PLL_LOCK = 0
                PLL_LOCK = bReg_Value.1
                         'You can test this bit to see if PLL Is Locked
    debug "waiting for PLL lock",13
                if PLL_LOCK=0 then PLLwait
    PLLdone:
    debug "PLL Lock=",bin1 PLL_LOCK,13
    Still no received data or IRQs however.
    Transmitter gives both IRQ0 and IRQ1 outputs - making some progress.
    - Albert Einstein
    Jan 2013
    Texas USA
    Progress for sure.
    When in TX mode your IRQ0 says you have crossed the FIFO Input threshold and IRQ1 says FIFOFull.
    Why don't you try changing your definition of IRQ1 for TX (IRQ1TX) from 0 = FIFOFULL (default) to 1 = TXDONE. This is your RF_Init_Values[13] value.
    Then in the Send_Packet: routine after changing the mode to RF_TRANSMITTER, instead of a hard pause 5, use a loop to test for IRQ1 to go high (TXDONE).
    This way you can explicitly test for the Transmitter to complete.
    TABSoft
    Sep 2007
    Waco, Texas
    Thanks for the additional input TABSoft, I had already changed the $0D register to $08, and still saw no interrupt.
    One thing I had noticed, In the Send_Packet routine, I saw you re-write the registers. I had changed your original code changing registers $1F, $0D, $0E, in which you re-wrote the registers to the original value, I changed to read the register 1st, then performed the logic manipulation thinking it may have been an oversight on your part. Still no output:
    Send_Packet:
                'Set Standby mode
                bRF_Mode = RF_STANDBY
                gosub SetRFMode
                'Enable FIFO access in Standby mode
                bReg_Address = $1F  'Register 31
                gosub RegisterRead
                bReg_Value = ((bReg_Value & $BF) | $00)
    '            bReg_Value = (RF_Init_Values(bReg_Address) & $BF) | $00
                gosub RegisterSet
                'Clear FIFO Overrun
                bReg_Address = $0D  'Register 13
                gosub RegisterRead
                bReg_Value = bReg_Value | $01
    '            bReg_Value = (RF_Init_Values(bReg_Address) | $01)
                gosub RegisterSet
                'Set PLL Locked
                bReg_Address = $0E  'Register 14
                gosub RegisterRead
                bReg_Value = bReg_Value | $02                                       'Set LSTLPLL to 1
    '            bReg_Value = (RF_Init_Values(bReg_Address) | $02)
                gosub RegisterSet
    'debug "Send Packet: waiting for PLL lock",13
    '            gosub PLLchk  'Verify PLL Lock Flag
    'debug "Send Packet: PLL locked",13
                For i = 0 to (TxPacketLen-1)
                'Wite the Packets to the FIFO
                wr_FIFO_Val = TxPacket[i]
                gosub WriteFIFO
                Next i
                'Set RFMode to Transmit
                bRF_Mode = RF_TRANSMITTER
                gosub SetRFMode
    Then as you can also see, I also added a bit test to see if in fact the PLL locked - it never did. Just sat there and spun waiting. I don't know what that is telling me. The 2 other places I have the wait until PLL lock do seem to change; the initial initialization and the RCV loop. Don't know what that is telling me either......
    I like your advice, and I had thought of doing something similar but my observations in the no IRQ0 or IRQ1 being set, I was looking for a way to test the register to see if the FIFO was ready. Some kind of flag I could use.
    I still haven't found it - an easy one.
    I have been on MC site and found numerous people grumbling over this radio - I can't believe this is so hard! One guy could never get the packet to work and went for the buffered approach. Many, Many posters have had interrupt issues as well. Seems I am not alone. All the more reason to post actual working code.
    My current drain is higher on the transmitter, so I think it is transmitting, and I actually believe the receiver is receiving - I just don't have it set to flag me so I can get the data!
    Thanks again for the assist, I owe you several beers! Any other ideas?
    Regards.
    - Albert Einstein
    Jan 2013
    Texas USA
    Sorry I've been busy on other items.
    Have you made any further headway or are you still stuck?
    TABSoft
  1. Interfacing LC75854
    By MR2010 in forum mel PIC BASIC Pro
    Last Post: - 18th July 2010, 03:42
  2. Keypad Interfacing
    By uaf5000 in forum mel PIC BASIC Pro
    Last Post: - 15th June 2010, 03:35
  3. Interfacing with the ISD4003
    Last Post: - 2nd June 2008, 16:25
  4. SPI Interfacing
    By toofastdave in forum Serial
    Last Post: - 18th November 2007, 12:15
  5. interfacing LCD
    By husakhalid in forum mel PIC BASIC
    Last Post: - 30th May 2006, 23:53
