MRF90XAM9A interfacing help
Results 1 to 40 of 64
    Default Re: MRF90XAM9A interfacing help
    It is sad that this amazing unique forum, not to have a start up code for each major application
    [rant]
    its not the fault of the forum its pbp's total lack of development that causes the issue.
    pbp cannot easily manage memory/memory structures or most of the pic inbuilt hardware modules. its difficult to
    make easy to use flexible pin definitions to use in include files so that library functionality can be created.
    most of my stuff uses asm and usercommand to overcome some of these hurdles but that leads to another level
    of complexity for code that translates between pic16/18 platforms. half the people here never even upgraded to pbp3
    the lack of usercommand in pbp2 kills that sort of combability anyway. you would have to wonder if more people upgraded to
    pbp3 in the past if development would have continued instead of becoming a backwater. all this stuff is dead easy in C .plug and play in Arduino
    the rfm69 family of modules are a quite complex device to use , their range and speed make the effort worthwhile
    if warranted. i have used them for several years now and did initially use them with pbp3. i did not publish
    my code for a number of reasons :-
    i wrote it specifically to suit my application , to be compatabile with rfm12bs[a retrograde step] , the code is completey undocumented .
    you could write a small novel explaining usage of a rfm69w/cw/hcw... . i look back on other less complex things i have posted
    code for like TFT modules, i went to a lot of trouble to make it easy-ish and adaptable . i think 3 people have had some
    success in using the code . three people in the whole world FFS. the rfm69 code can be more complex and they are more exotic why would i
    bother.
    unless you really need the speed/range then there a many less complex devices to use. you thought my suggestions for your gps project
    were overly complex rfm69 code is of the same ilk maybe more so.
    i was going to say nrf24L01 is a candidate ,very cheap not too hard to use but just noticed i did not even bother to create a pbp include for them , its all C from here
    Oct 2010
    [rant]
    bother.
    Hi Richard,
    thanks once again for your kind reply. I'm not familiar with programming as you have already understood, so for me will be really difficult to make any of these modules to work. I always think, technology make things easier and as those modules are "new" then it would be much easier for a user to embed those small and nice systems.
    I also thought that PBP, is capable of making thinks easier for most of the users. I've seen over the internet the Arduino users, have ready libraries for everything and even sample programs that are functioned. I was wonder why not here.
    PBP is it quite friendly and can become complicated, but in arduino world, things looks much easier when libraries are documented and registered for every single application. To be honest now i'm quite old to start understanding C language, and as being on a completely different area of interest (3D printing in Medicine) i do not have much time.
    I do what i do for my own experiments and hobby.
    I dont want you share any of your code, but it would be really nice, if anyone could simply start developing a code for those applications using RFM69 or even Lora modules.
    thanks a lot once again.
    I think you have missed the point of my post , I don't think it can happen the pic environment is awash with veritable plethora of hardware combinations
    the "simple" Arduino style libraries you seek exist because the Arduino is a rigid series of products , each one has a fixed osc ,fixed pin definitions ,
    a fixed setup routine ,a fixed software shell , a fixed interrupt handler etc.... the user can change none of these things . the hardware is abstracted away from the user
    hell even the pwm freq is fixed .you need some level skill to manipulate any of the hardware and the Arduino ide makes sure its going to stay that way and will
    hide as much as it can from you
    Oct 2010
    Many people told me to stay away from arduino.
    So you are saying that in pic environment will never happen something like this, because of its complexity. People do not bother to learn and configure a complex hardware, so they move to a fixed and standardized hardware, that effort is eliminated.
    its not that people don't bother , its that there are no pbp tools to do it properly.
    i will give you an simple example of the problem that demonstrates why i don't bother making anymore "hardware module" code for pbp any longer
    if you extrapolate this to include port/pin choices,on chip hardware and complex memory needs its no wonder that no "libraries" exist .
    take my tm1637 demo
    http://www.picbasic.co.uk/forum/showthread.php?t=23417
    the code is small, efficient and feature rich and works wonderfully, usercommand allows it fit seemlessy into pbp as though it was a pbp function.
    problem is it only works on enhanced core pic16 devices.
    to use it on a older chip like a pic12f683 it needs a bit of work these chips have only got one 8 bit FSR and no BRW opcode
    whereas the modern chips have 2 16 bit FSR's and a BRW opcode .
    therefore my rjust function can't work on these old chips and the rest of the code needs a bit of a tweak too
    the asm portion of the code becomes :-
    SEG_val         ;VALID INPUT  0-9 ,A-F, a-f ," " ,-
        CHK?RP  _TM_TMP
        MOVWF   _TM_TMP
        SUBLW   0x21
        btfsc   STATUS, C
        retlw   0   ;" "
        MOVF    _TM_TMP,W
        SUBLW   0x2f
        btfsc   STATUS, C
        retlw   64   ;"-"
        MOVF    _TM_TMP,W
        MOVLW   0X40
        SUBWF   _TM_TMP,W
        btfsC   STATUS, C
        GOTO    TM_ALPHA
        MOVF    _TM_TMP,W
        ANDLW   0X0F
        GOTO    TM_LU
    TM_ALPHA
        ANDLW   0xdf    ;ucase
        SUBLW   6
        btfsS   STATUS, C
        retlw   0       ;ERROR
        MOVLW   0X37
        SUBWF   _TM_TMP,W
        ANDLW   0xdf    ;ucase
    TM_LU
        addwf   PCL, F
        retlw  0X3F    ;0
        retlw  6
        retlw  0X5B
        retlw  0X4F
        retlw  0X66
        retlw  0X6D
        retlw  0X7D
        retlw  7
        retlw  0X7F
        retlw  0X67    ;9
        retlw  0X77    ;A
        retlw  0X7C    ;b
        retlw  0X39    ;C
        retlw  0X5E    ;d
        retlw  0X79    ;E
        retlw  0X71    ;F
    TM_START
    _TM_START
        CHK?RP TM_OUT_PORT
        BSF    TM_OUT_PORT,TM_CLK
        BSF    TM_OUT_PORT,TM_DIO
        NOP
        BCF    TM_OUT_PORT,TM_DIO
        NOP
        BCF    TM_OUT_PORT,TM_CLK
        ;NOP
    TM_STOP
    _TM_STOP
        CHK?RP TM_OUT_PORT
        NOP
        NOP
        ;NOP
    TM_WRITE
    _TM_WRITE
        MOVLW  8
        CHK?RP _TM_BIT
        MOVWF  _TM_BIT
    NXBT
        CHK?RP TM_OUT_PORT
        CHK?RP _TM_DAT
        BTFSS  _TM_DAT,0
        GOTO   TM_0
        CHK?RP TM_OUT_PORT
        GOTO   TM_NB
    TM_0
        CHK?RP TM_OUT_PORT
    TM_NB
        CHK?RP _TM_DAT
        RRF    _TM_DAT,F
        CHK?RP TM_OUT_PORT
        CHK?RP _TM_BIT
        DECFSZ _TM_BIT,F
        GOTO   NXBT
        CHK?RP TM_OUT_PORT
        CHK?RP TM_TRIS
        BSF    TM_TRIS,TM_DIO
        CHK?RP TM_IN_PORT
        BTFSC  TM_IN_PORT,TM_DIO
        BSF    _TM_NAK,7
        CHK?RP TM_OUT_PORT
        NOP
        NOP
        NOP
        NOP
        CHK?RP TM_TRIS
        BCF    TM_TRIS ,TM_DIO
        BANKSEL 0
    _TM_INIT
        CHK?RP  _TM_COLON
        CLRF    _TM_COLON
        CLRF    _TM_BRIGHT
        CHK?RP TM_TRIS
        BCF    TM_TRIS ,TM_DIO
        BCF    TM_TRIS ,TM_CLK
        BANKSEL 0
    _TM_DISP4
        CHK?RP  _TM_DAT
        MOVLW   _CMD_AUTO_ADDR
        MOVWF   _TM_DAT
        CLRF    _TM_NAK
        CALL    TM_START
        CALL    TM_WRITE
        CALL    TM_STOP
        MOVLW   _NUM_DIGITS
        CHK?RP  _TM_DIG
        MOVWF   _TM_DIG
        MOVLW   _START_ADDR
        CHK?RP  _TM_DAT
        MOVWF   _TM_DAT
        CALL    TM_START
        CALL    TM_WRITE
    NXDIG
        MOVF INDF,W
        INCF FSR ,f
        CALL    SEG_val
        CHK?RP  _TM_DAT
        IORWF   _TM_COLON ,W
        movwf   _TM_DAT
        CALL    TM_WRITE
        CHK?RP  _TM_DIG
        DECFSZ  _TM_DIG,F
        GOTO    NXDIG
        CALL    TM_STOP
        CHK?RP  _TM_BRIGHT
        MOVF    _TM_BRIGHT ,W
        ANDLW   7
        IORLW   _DISPLAY_ON
        CHK?RP  _TM_DAT
        MOVWF   _TM_DAT
        CALL    TM_START
        CALL    TM_WRITE
        CALL    TM_STOP
        BANKSEL 0
    but it still wont work on a pic18 they have no MOVIW, MOVWI OR BRW opcodes.
    so it needs a rework for them too. apita .its not easy to cover all the bases . i wrote the code to suit my app
    at that time . if i need to use the code on a different chip i don't want to keep reinventing the wheel, a modular approach
    is what i'm looking for. pbp simply has no tools to make that process a pleasant one.
    to do the same thing in C needs no asm code other than a few NOPs for timing and is fully portable with no changes needed
    eg
    c source :-
    #include "tm1637.h"
    /*pin manager DEFINES :-
     TM_DIO ,TM_CLK
    char TM_BRIGHT=1,TM_COLON=COLON_OFF ;
    void SET_TM_COLON(char d){
        if (d)
            TM_COLON=COLON_ON;
            TM_COLON=COLON_OFF;
    void SET_TM_BRIGHT(char d){
        TM_BRIGHT = d&7;
    void TM_START(){
        TM_CLK_LAT=1;
        TM_DIO_LAT=1;
        asm ("NOP");
        TM_DIO_LAT=0;
        asm ("NOP");
        TM_CLK_LAT=0;
    void TM_STOP(){
        TM_CLK_LAT=0;
        TM_DIO_LAT=0;
        asm ("NOP");
        TM_CLK_LAT=1;
        asm ("NOP");
        TM_DIO_LAT=1;
    char TM_WRITE(char dat){
        char bit_cnt;
        for (bit_cnt=0;bit_cnt<8;bit_cnt++){
        TM_CLK_LAT=0;
        TM_DIO_LAT=dat&1;
        dat>>=1;
        TM_CLK_LAT=1;
        TM_CLK_LAT=0;
        TM_DIO_SetDigitalInput();
        bit_cnt=TM_DIO_GetValue();
        TM_CLK_LAT=1;
        #asm
        NOP
        NOP
        NOP
        NOP
        #endasm
        TM_CLK_LAT=1;
        TM_DIO_SetDigitalOutput();
        return bit_cnt;  //NAK IF SET
    void TM_DISP(char* buff){
        char dat,TM_DIG,tmp;
        dat=CMD_AUTO_ADDR;
        TM_START();
        TM_WRITE(dat);
        TM_STOP();
        dat=START_ADDR;
        TM_START();
        TM_WRITE(dat);
        for(TM_DIG=0;TM_DIG<NUM_DIGITS;TM_DIG++ ){
            tmp=buff[TM_DIG];
            dat=SEG_VAL(tmp)|TM_COLON;
            TM_WRITE(dat);
        TM_STOP();
        dat=(TM_BRIGHT&7)|DISPLAY_ON;
        TM_START();
        TM_WRITE(dat);
        TM_STOP();
    char  SEG_VAL(char dat){
        const char seg_data[]={ 0X3F,6,0X5B,0X4F,0X66,0X6D,0X7D,7,0X7F,0X67,0X77,0X7C,0X39,0X5E,0X79,0X71};
          if (isdigit(dat))
                return seg_data[dat-'0'];
          else if (isxdigit(dat))
                return seg_data[toupper(dat)-'A'+10];
          else if (dat=='-')
                return 64;
                return 0;
    and the header file :-
     * File:   tm1637.h
     * Author: rc
     * Created on January 3, 2018, 4:42 PM
    #ifndef TM1637_H
    #define TM1637_H
    #ifdef __cplusplus
    extern "C" {
    #endif
    #include <ctype.h>
    #include <stdlib.h>
    #include <stdarg.h>
    #include <stdio.h>
    #include "mcc_generated_files/mcc.h"
    #include "mcc_generated_files/pin_manager.h"
    #define    CMD_AUTO_ADDR 0x40
    #define    START_ADDR    0xc0
    #define    NUM_DIGITS    0x4               //number of 7seg leds
    #define    COLON_ON      0x80
    #define    DISPLAY_ON    0x88
    #define    COLON_OFF     0
    void  TM_START();
    void  TM_STOP();
    char  TM_WRITE(char);
    char  SEG_VAL(char);
    void  TM_DISP(char*);
    void SET_TM_COLON(char);
    void SET_TM_BRIGHT(char);
    #ifdef __cplusplus
    #endif
    #endif /* TM1637_H */
    and a C example of usage
    #include <xc.h>
    #include <ctype.h>
    #include <stdlib.h>
    #include <stdarg.h>
    #include <stdio.h>
    #include  "tm1637.h"
    #include  "hx711.h"
     TM_DIO ,TM_CLK
     HX_OUT,HX_SCH
     ZERO_SW
    void main(void)
        short long  cnt;
        char buffer[5];
        SYSTEM_Initialize();
        SET_TM_BRIGHT(2);
        while ( HX_OUT_GetValue()){} ;
        while (1)
          if(!ZERO_SW_GetValue() ) {
             SET_HX_ZERO();
            while (!ZERO_SW_GetValue() ) {};
          cnt = READ_HX711();
          cnt >>=5;
          SET_TM_COLON(0);
          sprintf(buffer,"%4d",cnt);
          TM_DISP(buffer);
          __delay_ms(500);
    to do the same in pbp code is possible but twice the size and half as fast with less features . and that is for a very simple device
    http://www.picbasic.co.uk/forum/show...196#post144196
    Oct 2010
    After all that, i have the simplest question.
    Why after all these years, PBP havent improve itself with a newer and more competitive version? Then Everyone could buy the compiler with no thought.
    Because as far as i see C is not only higher level language, but doesnt need asm.
    Now i'm stack at this stage with the GPS project. Not that the code i have done is efficient or a super smart, but i thought i could send those GPS info, easier from one side to the other by using those modules. I thought that it would be a setup for TX -RX and then using only few command to send GPS data.
    I think that i need to start learning C from the beginning.
    Richard, thanks once again for all of your time and help.
    OK
    Quote Originally Posted by astanapane View Post
    Daryl Taylor was involved in the development of PBP up till about 3 years ago when he passed away. Charles Leo now carries the entire burden of running ME Labs. ME Labs has been bought out by a racing products company. The real money is in the racing products. Charles continues to support PBP users in spite of the fact that the revenue from PBP sales barely pays the light bills. For above-and-beyond type support, we, as a community, must help each other. Creating cool modules and sharing them helps keep our group moving forward. It's a mixed bag I suppose.
    I just bought a couple books to do just that. I see many benefits from learning C.
  1. Interfacing LC75854
    By MR2010 in forum mel PIC BASIC Pro
    Last Post: - 18th July 2010, 02:42
  2. Keypad Interfacing
    By uaf5000 in forum mel PIC BASIC Pro
    Last Post: - 15th June 2010, 02:35
  3. Interfacing with the ISD4003
    Last Post: - 2nd June 2008, 15:25
  4. SPI Interfacing
    By toofastdave in forum Serial
    Last Post: - 18th November 2007, 11:15
  5. interfacing LCD
    By husakhalid in forum mel PIC BASIC
    Last Post: - 30th May 2006, 22:53
