Baud Rate Issue with 8MHz Crystal
Results 1 to 4 of 4
    Sep 2005
    Post Baud Rate Issue with 8MHz Crystal
    Hi All,
    I need to reach a baud rate of 115200 and I have a Dev Board that only has an 8MHz Crystal, and normally I need at least 16MHz to reach that speed. I am using a 18F87J50 which is on the Dev Board. Do you think I could do something fancy using the Internal OSC to help generate the speed for 115200?
    Any help would be greatly appreciated,
    Gavo
    Default Re: Baud Rate Issue with 8MHz Crystal
    Why not use the 4xPLL with your 8mhz xtal?
    EN82fn
    Sep 2005
    Thanks Dave, the problem is I can't see it in the Configuration Bits like the 18F26K22?
    Gavo, Look on page 36 of the 18F87J50 data sheet. It's all right there....
    EN82fn
  1. RS232 Baud Rate
    By gadelhas in forum mel PIC BASIC Pro
    Last Post: - 10th August 2010, 01:06
  2. MCLoader baud rate
    Last Post: - 14th July 2010, 02:41
  3. Baud Rate Converter
    By paul.mcallister in forum Serial
    Last Post: - 15th June 2008, 00:26
  4. Baud rate calculation
    By Demon in forum Serial
    Last Post: - 21st July 2006, 23:02
  5. Detect baud rate
    By Dick M in forum mel PIC BASIC Pro
    Last Post: - 2nd July 2005, 22:10
