It's been a long time!!!
Results 1 to 9 of 9
    Sep 2008
    Default It's been a long time!!!
    It's been a while since I programmed in PicBasic. I would like to get back into it. But I am struggling with the simplest of task.....blinking an LED. Spent 3 hours trying to figure out what I am missing. Maybe someone can show this old newbie what I am missing.
    ' PIC18F24K50 Configuration Bit Settings
    #config
      CONFIG FOSC=INTOSCIO
      CONFIG PLLSEL=PLL3X
      CONFIG CFGPLLEN=ON
      CONFIG CPUDIV=NOCLKDIV
      CONFIG LS48MHZ=SYS48X8
      CONFIG IESO=OFF
      CONFIG FCMEN=ON
      CONFIG PCLKEN=ON
      CONFIG BOREN=OFF
      CONFIG nPWRTEN=OFF
      CONFIG nLPBOR=OFF
      CONFIG BORV=220
      CONFIG WDTPS=32768
      CONFIG WDTEN=OFF
      CONFIG MCLRE=OFF
      CONFIG SDOMX=RC7
      CONFIG T3CMX=RC0
      CONFIG DEBUG=OFF
      CONFIG STVREN=ON
      CONFIG ICPRT=OFF
      CONFIG XINST=OFF
      CONFIG LVP=OFF
    DEFINE OSC 48
    OSCTUNE = %10000000 '3X PLL ratio mode selected
    OSCCON =  %01110000  'Switch to 16MHz HFINTOSC
    OSCCON2 = %00010000 'Enable PLL
    '*********************** PORT CONFIG ****************************
    TRISA =  0                                   'porta direction 0=OUTPUT 1=INPUT
    PORTA =  0                                   'porta preset
    ANSELA = 0
    '*******************    MAIN PROGRAM     ************************
    while 1
        low PORTA.5
        PAUSE 500
        high PORTA.5
    WEND
    Default Re: It's been a long time!!!
    you have not really provided any clue at all to what you problem is
    but looking at the data sheet osc description I doubt that
    DEFINE OSC 48
    is correct
    they way I see it it needs to be
    DEFINE OSC 24
    the x3 pll is followed by a /2 stage and the 48mhz only goes to the usb module
    CONFIG nLPBOR=OFF
    Is that "n" a typo? You have 2 like that.
    Sep 2008
    Thanks for the replies.
    The problem is, I can't even get an LED to blink. Does not come on at all, much less blink.
    Just trying to figure out the basics with this chip.
    According to this chart, using the internal OSC with 3x PLL and no clock divider, it should be at 48MHz if I am understanding it correctly.
    CONFIG PLLSEL=PLL3X
    Also, nPWRTEN, and nLPBOR are valid parameters in the PIC18F24K50.PBPINC file.
    ok looks like 48mhz clock is more likely to be correct , the table makes no mention of the /4 option as depicted in the osc diagram fig 3.1 ,and a 0 divide option seems more probable
    what are you using to pgm the chip , its not holding mclr low or something easy like that . pwr ok ? led works ?
    OSCCON = %01110010
    might by worth a try
  1. How long... LED on time without resistors?
    By Heckler in forum General
    Last Post: - 14th March 2011, 17:49
  2. Hello, long time no post (ADC sample rate)
    By Jhong2 in forum General
    Last Post: - 14th April 2009, 04:13
  3. Long start time
    By ttease in forum mel PIC BASIC Pro
    Last Post: - 9th April 2007, 02:45
  4. Replies: 2
    Last Post: - 27th March 2007, 12:48
  5. Using RTC to generate long time delays
    By schlaray in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2007, 00:31
