What a Pain In The USB-utt
Results 1 to 20 of 20
    Sep 2008
    Default Re: What a Pain In The USB-utt
    Spoke a bit too soon. Works great in WinXP. Windows 8 is more stringent on USB devices and the current descriptor does not work. But it should be very close.
    This is something I've had on the backburner for years but, like many others, I've tried USB before and never been able to get it to work (apparently not been motivated enough) so I've been delaying it.
    Thanks Phil for starting this thread and thanks Dave for posting the code - much appreciated!
    If you get it working on W8, please us know what changes is needed.
    Thanks again!
    Mar 2008
    Gerogetown, Texas
    Sorry, I do not have Win8. Worked on XP and 7.
    Take care
    Look on http://USB.org, they have tool to validate descriptors, among other things.
    George
    Sep 2008
    After further investigating the Windows 8.1 problem with the USB emulation, I came across this post.
    http://answers.microsoft.com/en-us/w...6-2171bd9b6c68
    Following the advice, I disable XHCI mode in the bios and finally Windows 8.1 recognized my 18F4550 as a HID USB keyboard, no drivers necessary.
    Just for fun and to see if it was possible, I wrote a small program. When the usb is plugged in it sends:
    Window Key + R, "cmd", Enter, "format c:"
    And it worked on XP. I dare not add "y, Enter" to the end.
    Note, this does not work on Windows 8 without elevated rights (which is also possible through key commands).
    OHH the evil things you could do...........if you were evil!
    Thanks to you, Dave and this thread I managed to get a HID keyboard using a 18F46J50. (On this nice little board).
    One thing I've been thinking about is how you could check that the device actually got enumerated (from the PIC that is) so you don't start sending stuff untill it is. The USB.txt file in the PBP folder says you should call USBService every ~250us untill USBDeviceState == CONFIGURED_STATE. I tried polling for that but needless to say it didn't compile.
    Looking a bit further it seems like those are an assembly variable/constant repectively so PBP wouldn't know they exist. I wonder if the EXT modifier is the place for this.....
    Anyway, thanks again for final push I needed!
    If PC is the Host, shouldn't the host ask the slave device to start sending data? So, maybe PIC should wait until a request is received.
    Nice boards Henrik. I think it is time to try USB again.
  1. USB to USB flash Drive File Copier
    By surya089 in forum USB
    Last Post: - 16th December 2012, 01:22
  2. USB to USB flash Drive File Copier
    By emildownloads in forum General
    Last Post: - 27th October 2011, 01:23
  3. Start with USB and USB comands
    By SKOLS1 in forum mel PIC BASIC Pro
    Last Post: - 12th August 2011, 12:41
  4. usb to usb direct data transfer
    By sharath in forum USB
    Last Post: - 17th July 2011, 13:23
  5. USB PIC without USB Connection
    Last Post: - 26th December 2005, 17:39
