Beginner in need of help !!
Results 1 to 40 of 72
    Jan 2015
    Default Re: Beginner in need of help !!
    Hi, okay I've been playing about with comparator interrupt now & think I have got the hang of it using flags. The code below is something little I came up with
    Now I think I would like to implement the nap command now, or do you think I should learn something else before jumping to the nap command?
    Thanks again,
    Rob
    'PIC 12F683
       __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF
    PAUSE 50 'wait for hardware to settle
    DEFINE OSC 4 '4mhz ocsillator
    ANSEL = %00000010 'pin 6 analog
    CMCON0 = %00000100 'comparator mode
    VRCON = %10101000 'voltage reference
    TRISIO = %00000010 'pin 6 input
    ON INTERRUPT GOTO int1 'interrupt handler is int1
    INTCON = %11001000 'enable GIE and GPIE; clear GPIF
    PIE1 = %00001000 'enable comparator interrupt
    POT1 VAR CMCON0.6 'read potentiometer
    LED VAR GPIO.2 'led pin 5
    loop1 var word 'loop1 counter
    bitTest var bit 'Debug test bit.  Set/Clear in ISR and Check in main
    bitTest = 0
    Loop1 = 0
    ENABLE
    IF bittest = 1 THEN
    GOTO FLASH
    LOW LED
    GOTO main
    ENABLE
    FLASH:
    do
    for loop1 = 1 to 1000
    HIGH LED
    PAUSE 1
    NEXT LOOP1
    LOW LED
    PAUSE 1
    NEXT LOOP1
    IF bittest = 0 THEN
    GOTO main
    LOOP
    DISABLE 'disable interrupts in handler
    int1:
    if PIR1.3 = 1 then  'Comparator Interrupt fired (must be cleared before resume)
    BITtest = pot1
    INTCON =%11001000
    PIR1 = %00000000 'reset CMIF
    RESUME 'where left off
    ENABLE 'enable interrupts
    Jan 2013
    Texas USA
    Rob,
    Looks like you got it working.
    One little thing though.
    The Pause command is based upon the "DEFINE OSC" value to calculate the pause interval correctly.
    It is a good practice to have your "DEFINE OSC" statement up top in the source code before you use any time sensitive commands such as "Pause x".
    The way you have your program setup the following occurs, which I presume you have seen in practice on your physical system.
    The LED on GP2(pin5) will stay LOW (OFF) while the voltage input on GP1(pin6) is above your reference voltage.
    The LED GP2(pin5) will blink in 1sec intervals while the voltage input on GP1(pin6) is below your reference voltage.
    This works fine on my simulator.
    Good job!
    It looks like you're ready for a "nap" now.
    TABSoft
    Jan 2015
    Hi Tabsoft, thanks for comfirming also thanks again for all your help, I wouldnt have got to this point if it wasnt for you. I havent got a simulator so I just test straight on the BB.
    I will drop the pause below the osc value, thanks for that tip
    Do I implement the nap command in the same way as flashing an LED? So if bittest = 1 : nap 1, if bittest = 0 : goto main? Something like that ?
    Thanks again,
    Rob
    Jan 2013
    Texas USA
    Rob,
    Why don't you check this out.
    'PIC 12F683
    high LED    'Start with LED ON
    pause 500   'Pause .5 secs so you can see the LED turn on
    bitTest = POT1  'Take initial reading of input voltage state
    Loop1 = 0
    ENABLE
        IF bitTest = 1 THEN 'input voltage is < reference voltage
            low LED
            nap 1
        else    'bitTest = 0 - input voltage is > reference voltage
            GOTO FLASH
        GOTO main
    ENABLE
    FLASH:
        do
                HIGH LED
                PAUSE 1
            NEXT LOOP1
                LOW LED
                PAUSE 1
            NEXT LOOP1
            IF bitTest = 1 THEN
                GOTO main
        LOOP
    int1:
    bitTest = pot1
    INTCON =%11001000
    TABSoft
    Like Tabsoft wrote, you generally want your DEFINEs at the top of the program but it's for readabillity. In reallity it makes no difference because they are not runtime commands.
    Another little note
                HIGH LED
                PAUSE 1
            NEXT LOOP1
    What's the purpose of setting the LED high inside the loop?
    There's nothing inherently wrong in doing it but it does take (a little) bit of time.
    Also, now that you're starting to get the hang of it you might want to consider ditching the HIGH/LOW commands and simply set the pin directly, LED=1, LED=0. For this to work you need to clear the corresponding TRIS-bit first (TRISO.2 = 0 ' Set GPIO.2 to output). Doing it this way executes faster and consumes less codespace since it doesn't waste resources clearing the TRIS bit each and every time (which is what HIGH/LOW does for you).
    Again, you're not doing anything "wrong" - it all works fine, I'm just pointing out a couple of things you could improve and take with you to the next project.
    Jan 2015
    Thanks guys, I will have a play
    Rob
  1. Beginner help!
    By Recognize in forum General
    Last Post: - 26th April 2012, 15:55
  2. pic24 beginner
    By robertpeach in forum General
    Last Post: - 13th August 2009, 12:57
  3. need help! to beginner
    By emilhs in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 19:44
  4. Beginner at PB
    By alphahr in forum Off Topic
    Last Post: - 21st April 2008, 18:43
  5. Can anyone help a beginner in a struggle?
    By douglasjam in forum mel PIC BASIC
    Last Post: - 6th May 2005, 00:29
