Beginner in need of help !!
Results 1 to 40 of 72
    Jan 2015
    Default Re: Beginner in need of help !!
    Hi Henrik, thanks for explaining that it makes things a lot clearer as to how I'm going to run the code. What I would like to do is have one of the inputs (gp2), taking a reading from ADC every say 0.5 - 1 seconds.
    Basically I want the chip to enter low power mode along with the device. When the device is off, one of the component pins goes to 0.00v, then when it is turned on it goes to 0.70v & stays at that. So I would like the ADC to monitor this, then when the voltage drops below 0.60v the chip is in low power mode, then when the voltage is higher than 0.60v I want it to come out of low power mode.
    I hope this can be done in some way,
    Rob
    Jan 2013
    Texas USA
    Rob,
    I don't think the ADC module will accomplish what you are attempting as Henrik stated in his last reply.
    You should look into the Comparator of the PIC, again as Henrik suggested.
    TABSoft
    You can use the ADC to sample the voltage but the PIC needs to be awake for the ADC to operate and, again, the ADC doesn't run continously and can not automatically generate an interrupt when a given voltage or threshold is detected. You'd need to wake the PIC up every now and then, sample thevoltage at the pin and based on that determine if you should stay awake or go back to sleep. No problems doing that but to me it looks like you'll be better served by using comparator module. Using that you can put the PIC to sleep and it will automatically wake up when the comparator output flips.
  1. Beginner help!
    By Recognize in forum General
    Last Post: - 26th April 2012, 15:55
  2. pic24 beginner
    By robertpeach in forum General
    Last Post: - 13th August 2009, 12:57
  3. need help! to beginner
    By emilhs in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 19:44
  4. Beginner at PB
    By alphahr in forum Off Topic
    Last Post: - 21st April 2008, 18:43
  5. Can anyone help a beginner in a struggle?
    By douglasjam in forum mel PIC BASIC
    Last Post: - 6th May 2005, 00:29
