MCLR is disabled by clearing the correct "fuse" in the CONFIG word. With PBP3 you set the CONFIG word(s) with the #CONFIG/#ENDCONFIG compiler directives (more on that in the manual). Your PBP3 installation folder has a subfolder named DEVICE_REFERENCES in which you'll find a file for each and every device the compiler supports. The file contains information about the various CONFIG options and also what defaults PBP uses if you don't include any in your code.
For a 12F683 the defaults are:
   __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_ON & _CP_OFF
If you want to disable MCLR and keep everything else then copy/paste this into your program:
   __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _CP_OFF
Your a life saver mate. I knew I had to write to the config but I just could not find out which way to do it, I was nearly there I was putting @config instead though!
Thanks again,
Rob
