Beginner in need of help !!
Results 1 to 40 of 72
Threaded View
  1. #8
    Default Re: Beginner in need of help !!
    the low range internal vref gives you 15 steps of 0.208 volt steps starting at 0v
    the high range internal vref gives you 15 steps of 0.156 volt steps starting at 1.25v
    if you don't need the cout as an actual physical output CM<2:0> = 110 is a better choice
    and lets you chose pin 6 or 7 as your input (select with cmcon0.3 "CIS")
    why waste pins on a 8 pin chip
    0000=0
    0001=1
    0010=2
    0011=3
    ...................etc etc
    its called binary
  1. Beginner help!
    By Recognize in forum General
    Last Post: - 26th April 2012, 14:55
  2. pic24 beginner
    By robertpeach in forum General
    Last Post: - 13th August 2009, 11:57
  3. need help! to beginner
    By emilhs in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 18:44
  4. Beginner at PB
    By alphahr in forum Off Topic
    Last Post: - 21st April 2008, 17:43
  5. Can anyone help a beginner in a struggle?
    By douglasjam in forum mel PIC BASIC
    Last Post: - 5th May 2005, 23:29
