Beginner in need of help !!
Results 1 to 40 of 72
Threaded View
  1. #35
    Jan 2013
    Texas USA
    Default Re: Beginner in need of help !!
    Rob,
    Yes Comparators can be confusing the 1st time using them on the PIC MCU.
    First, have a read through this link.
    http://www.cuteminds.com/index.php/e...23-comparators
    It explains simply how the comparator
    on the PIC12F683 can be used. Ignore the C language stuff, but pay attention
    to the setup of the Comparator, especially the Second Case.
    This case describes what you will probably implement.
    This will give you the info on how the Comparator will work by polling the
    Comparator output, NOT USING INTERRUPTS.
    Once you have this digested, then you can move on to the Interrupt portion.
    Use the equation for VRR=1 (Low Range): (VR3:VR0/24) x Vdd to set the "Threshold Voltage"
    E.g.
    Vdd = +5Vdc
    VR3:VR0 = 5 (%1001)
    Putting this into the equation above gives this CVref "Threshold voltage"
    (5/24) x 5 = 1.042 Vdc
    This will be the reference voltage that will be used to compare the input voltage to.
    General Rules when using the Comparator:
    1. Set the appropriate pins to analog for the Comparator with ANSEL
    2. Set the direction of the pins appropriately with TRISIO
    3. Configure the Compare Module using CMCON0
    4. Configure the reference voltage using VRCON
    To use the comparator, poll the value of the status bit in CMCON0.
    See if this gets you started.
    Last edited by Tabsoft; - 23rd January 2015 at 20:10. Reason: Forget a general rule
    TABSoft
  1. Beginner help!
    By Recognize in forum General
    Last Post: - 26th April 2012, 15:55
  2. pic24 beginner
    By robertpeach in forum General
    Last Post: - 13th August 2009, 12:57
  3. need help! to beginner
    By emilhs in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 19:44
  4. Beginner at PB
    By alphahr in forum Off Topic
    Last Post: - 21st April 2008, 18:43
  5. Can anyone help a beginner in a struggle?
    By douglasjam in forum mel PIC BASIC
    Last Post: - 6th May 2005, 00:29
