Beginner in need of help !! - Page 2
Page 2 of 2 FirstFirst 12
Results 41 to 72 of 72
  1. #41
    Jan 2015
    Default Re: Beginner in need of help !!
    Thanks Tabsoft for that info & trying to help. I will go over all that until it becomes clear, I refuse to give up!
    Thanks again,
    Rob
  2. #42
    Jan 2015
    Okay I think I have made sense of this now - correct me if I'm wrong.
    So if I wanted to set the comparator up with say an internal reference & output (cm<2:0> = 011), I would set the cmcon0 register as CMCON0 = %00000011 ?
    Now to the VRR -
    I think Im right in saying that the comparator uses the main VDD+ pin on the chip to compare the internal reference to? What I dont understand is this -
    IF VRR=1 and VR3 ... VR0 = 1111 (15) with a VDD of 5V the Vref will be (15/24)*5 = 3,125V
    ^^ Where are they getting that 15 from? Also where do you get the 24 from?
    IF VRR=0 and VR3 ... VR0 = 1111 (15) with a VDD of 5V the Vref will be 5/4+(15/32)*5 = 3,593V
    ^^ Also why has the 24 changed to a 32 just from vrr=1 changing to a 0?
    One last question, Am I right in thinking that you have to use the CIN- pin on the chip to provide the voltage to check? Cant you use a comparator on any pin of the chip (apart from gp3, vdd & vss).
    Thanks again,
    Rob
  3. #43
    Jan 2015
    Update: Ive looked in the data sheet & found out the reason for dividing by either 24 or 32, if your working out low range then : 24, high range : 32. Thats another thing understood.
    So the last thing I am struggling to understand now is, how do you get the number from th bits?
    VR<3:0> = 1111 (15). < How on earth do you get 15 from just bits 1111?
    This is the only thing that I'm struggling to understand now.
    Rob
  4. #44
    the low range internal vref gives you 15 steps of 0.208 volt steps starting at 0v
    the high range internal vref gives you 15 steps of 0.156 volt steps starting at 1.25v
    if you don't need the cout as an actual physical output CM<2:0> = 110 is a better choice
    and lets you chose pin 6 or 7 as your input (select with cmcon0.3 "CIS")
    why waste pins on a 8 pin chip
    0000=0
    0001=1
    0010=2
    0011=3
    ...................etc etc
    its called binary
  5. #45
    Jan 2015
    Edit: just re-read your post. I need to be able to read a pin & output on it at the same time (obviously with pauses, so do I need to use comparator with output?
    Hi Richard, I just came back here from doing a bit of googleing. It took me about 2 mins to figure out that its just binary, maybe if I had paid more attention in Maths I would know this!
    I now understand the voltage steps as well, everything is coming together now, its actually quite simple once understood.
    I still need to know if you can use a comparator with internal reference on any pin or does it have to be the CIN- pin?
    Cheers,
    Rob
  6. #46
    input to comparator is [ cin+ pin 7] or [cin- pin 6] with CM<2:0> = 110 its your choice
    there are other modes but in all cases cin is only on pins 6,7
  7. #47
    if you need or can use the comparator output use CM<2:0> = 101
    it still lets you chose pin 6 or 7 as your input (select with cmcon0.3 "CIS")
  8. #48
    Jan 2015
    Okay Richard thanks for your help.
    So lets say I wanted an LED to be OFF if the voltage on cin+ is below 1.1v, & LED to be ON if the voltage is higher than 1.1v. Would I use this -
    VR3 ... VR0 = 1000 (8) with a VDD of 3.3V the Vref will be (8/24) x 3.3 = 1.1V
    I hope this is right lol
  9. #49
    there is not enough info to answer
    what comparator mode ?
    what cis setting
    is vrr set
    what cinv seting
    how is led connected ?
  10. #50
    Jan 2015
    Richard, I'm specifically talking about just the VRR nothing else. I just want to know if I've got the workings out right. If you need the whole code to tell me if that part is right or not then I can do that no problem.
  11. #51
    that is correct it will set the reference to 1.1 for a vdd of 3.3v
  12. #52
    Jan 2015
    Thats great thanks for the help, now I can have a go at the code.
  13. #53
    Jan 2015
    Angry Re: Beginner in need of help !!
    Okay I have had a go & failed What am I doing wrong?
    'PIC12f683
       __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF
    DEFINE OSC 4 '4mhz ocsillator
    ANSEL = %00000010 'pin 6 analog
    CMCON0 = %00000100 'comparator mode
    VRCON = %00001000 'voltage reference
    TRISIO = %00000010 'pin 6 input
    POTEN VAR CMCON0.1 'pot pin 6
    LED VAR GPIO.2 'led pin 5
    PAUSE 20
    IF CMCON0.1 = 1 THEN
    HIGH LED
    LOW LED
    GOTO main
  14. #54
    Jan 2013
    Texas USA
    Rob,
    Glad to see your working through the design and issues.
    You are very close.
    Here are a couple of things you need to correct.
    1. VRCON: Look at the register description in "Register 8-3" on page 53 of the datasheet.
    In your program you are setting VRCON like this: VRCON = %00001000 'voltage reference
    There are more bits in the register that you need to take into account.
    A. You have bit7=0 which does this "0 = CVREF circuit powered down, no IDD drain and CVREF = VSS". This turns OFF the internal reference voltage.
    You need to change this to "1", 1 = CVREF circuit powered on, to turn on the internal reference voltage circuit.
    B. You have bit5 = 0 which does this "VRR: CVREF Range Selection bit 0=High Range"
    This changes your CVref equation and result to this: "VRR = 0, CVREF = (VDD/4) + (VR3:VR0 X VDD/32)", which when you plug in your values you get this
    for your reference voltage. (3.3/4) + (8/32) = (0.825) + (0.25) = 1.075 Vdc. Now this may be what you were actually trying to do, if so then your are good.
    2. In your main loop you are attempting to test the output of the Comparator like this: "IF CMCON0.1 = 1 THEN"...
    Look at the CMCON0 register description in "Register 8-1" on page 47 of the datasheet and compare that with the "CMCON0.1 = 1" above.
    You are testing bit1 of the CMCON0 register, that is what the ".1" does. xxxx.1 says I want to look at bit1 of xxxx.
    Is this the bit you need to check for the Comparator Output? If you're not sure have a look at "FIGURE 8-3" on page 49 and look at the figure for the
    CM Mode you are using "100". That diagram indicates what the Comparator Output is by name.
    Check and correct this.
    3. Lastly, and somewhat obscure in the DS, you need to determine how you want the Comparator to test and output.
    As I understand you want to check the input pin voltage against your "1.075 Vdc" reference you are setting up internally and have the following outcomes:
    If the input is "Lower than 1.075 Vdc" you want the LED to be OFF and you want the LED to be "ON when the input is Higher than 1.075 Vdc".
    To get these results you need to take a look at a couple of items in the datasheet.
    A. Look at CMCON0, "Register 8-1" on page 47, and review the information for bit6 and bit4.
    Also look at "TABLE 8-1" on page 48.
    Between these two, you should be able to piece together how you need to configure the operation to get your desired "Output" of the Comparator.
    You are getting close, hopefully these additional points will get you further on your way.
    TABSoft
  15. #55
    Jan 2015
    Hi Tabsoft, thanks a lot for your help I appreciate it. I will go back through everything you have stated & set it up right this time. I did think there were other bits to change but didnt want to mess as I didnt know what I was doing, but ai should now with your info.
    Thanks again, I will let you know how it goes.
    Rob
  16. #56
    Jan 2013
    Texas USA
    Rob,
    One correction in my earlier post.
    The CVref calculation for High Range is CVREF = (VDD/4) + (VR3:VR0 X VDD/32).
    Using your input values of VDD=3.3 and VR3:VR0=8, the calculation will come out like this.
    (3.3/4) + (8 x (3.3/32) = (0.825) + (8 x 0.103125) = (0.825) + (0.825) = 1.65 Vdc
    If you use Low Range then here is the info:
    CVREF = (VR3:VR0/24) x VDD = (8/24) x 3.3 = 0.333 x 3.3 = 1.1 Vdc
    TABSoft
  17. #57
    Jan 2015
    Hi Tabsoft,
    Right I have changed the bits in the VRCON to the right stuff, so I think that is right now. I did change bits in the CMCON0 but none of it seemed to make a difference, so I have put it back to how it was. I'm thinking either I'm testing the wrong bit still or my actual hardware setup is wrong.
    Maybe you can point something out?
    BTW I am using the low range Also this is correct - As I understand you want to check the input pin voltage against your "1.1" reference you are setting up internally and have the following outcomes: If the input is "Lower than 1.075 Vdc" you want the LED to be OFF and you want the LED to be "ON when the input is Higher than 1.075 Vdc".
    Code -
    'PIC 12F683
    VRCON = %10101000 'voltage reference
    POT1 VAR CMCON0.2 'pot pin 6
    PAUSE 20
    IF POT1 = 1 THEN
    HIGH LED
    LOW LED
    GOTO main
    Thanks again,
    Rob
  18. #58
    Jan 2013
    Texas USA
    Rob,
    Yes you're not testing the correct bit for the actual output of the Comparator..
    Look at my post again where I listed the things you need to correct. Look at item 2.
    I point you to where you can find the answer of which bit in which register to test.
    I also point you to where you can determine what the output of the comparator will be for different configurations and physical connections.
    Have a read of this info again, I'm sure you'll get it.
    TABSoft
  19. #59
    Jan 2015
    Hi Tabsoft, okay had another read at first it was just going over my head. Am I right in saying I need to read bit 6 of CMCON0? So CMCON0.6?
    Rob
  20. #60
    Jan 2013
    Texas USA
    Exactly!
    CMCON0 Register:
    bit 6 COUT: Comparator Output bit.
    This is the logic bit output of the Comparator.
    CM: Comparator Mode = 100
    With this setup the comparator is comparing VIN- (CIN-/GP1) to VIN+ (which is not an external pin but it is "From CVREF Module", internal voltage reference)
    So you need to look at the description of COUT in the CMCON0 register listed below AND you need to look at Table 8-1 in the DS.
    This will help you work out what value CMCON0.6 will be based upon a given input on GP1.
    Take note that CINV is a configuration bit within the CMCON0 register that determines the logic polarity of COUT.
    COUT: Possible values
    When CINV = 0:
    1 = VIN+ > VIN-
    0 = VIN+ < VIN
    When CINV = 1:
    1 = VIN+ < VIN-
    0 = VIN+ > VIN
    TABSoft
  21. #61
    Jan 2015
    Brilliant! Thanks for the info again your the best! I should be able to get this working how I want it to now, then & only then will I move onto interupt with it.
    Thanks again,
    Rob
  22. #62
    Jan 2015
    Hi Tabsoft, I got the comparator working perfectly so I decided to move onto adding an interrupt, which believe it or not hasn't worked. Here is the code I have fully written, maybe you can help where I have gone wrong?
    Rob
    You will probably have a laugh at this, as its probably completely wrong lol
    'PIC 12F683
    PAUSE 20 'wait for hardware to settle
    ON INTERRUPT GOTO SLSELECT 'interrupt handler is slselect
    INTCON = %11001000 'enable GIE and GPIE; clear GPIF
    IOC = %00000010 ' enable IOC1 (GPIO.1 Interrupt on change)
    PIE1 = %00001000 'enable comparator interrupt
    POT1 VAR CMCON0.6 'read potentiometer
    ENABLE
    HIGH LED 'light led
    GOTO main 'repeat
    DISABLE 'disable interrupts in handler
    SLSELECT:
    IF POT1 = 1 THEN 'if <1.1v sleep
    NAP 1
    INTCON = %10001000  'enable GIE and GPIE; clear GPIF
    PIR1 = %00000000 'reset CMIF
    RESUME 'where left off
    ENABLE 'enable interrupts
  23. #63
    Jan 2013
    Texas USA
    Glad to hear if Rob.
    You did not say what is happening only that it is not working.
    I took a look at your code and several things jump out at me.
    1. You are jumping into the deep end of the pool with testing "nap"
    If would take a smaller step first. Set a flag in the ISR and resume. Then in the main act on the flag you set in the ISR.
    This way you can see the effects of the ISR logic.
    2. You have IOC.1 enabled, which is GP1, which you are using for the comparator. You need to comment out IOC.1.
    3. You are not testing for which Interrupt is firing inside of your ISR. It is almost always a good practice to determine what interrupt caused the jump to the ISR.
    4. At the end of your ISR you are not setting the INTCON register they way you think. I believe you have a typo in the value you are assigning to it.
    I changed your code to the following which shows the changes.
    'PIC 12F683
    'IOC = %00000010 ' enable IOC1 (GPIO.1 Interrupt on change)
    bitTest var bit 'Debug test bit.  Set/Clear in ISR and Check in maiin
    bitTest = 0
    ENABLE
        'HIGH LED 'light led
        LED = bitTest
    GOTO main 'repeat
    SLSELECT:
        'IF POT1 = 1 THEN 'if <1.1v sleep
            'NAP 1
        'ELSE
        'ENDIF
        if PIR1.3 = 1 then  'Comparator Interrupt fired (must be cleared before resume)
            bitTest = POT1
        'INTCON = %10001000  'enable GIE and GPIE; clear GPIF
        INTCON =%11001000
    See if this gets you along further.
    TABSoft
  24. #64
    Jan 2015
    Hi Tabsoft, okay thanks for all that. I will go back to flagging. I think I was
    Getting a bit ahead of myself lol.
    Let you know how it goes
  25. #65
    Jan 2015
    Hi, okay I've been playing about with comparator interrupt now & think I have got the hang of it using flags. The code below is something little I came up with
    Now I think I would like to implement the nap command now, or do you think I should learn something else before jumping to the nap command?
    Thanks again,
    Rob
    'PIC 12F683
    PAUSE 50 'wait for hardware to settle
    ON INTERRUPT GOTO int1 'interrupt handler is int1
    loop1 var word 'loop1 counter
    bitTest var bit 'Debug test bit.  Set/Clear in ISR and Check in main
    bitTest = 0
    Loop1 = 0
    ENABLE
    IF bittest = 1 THEN
    GOTO FLASH
    LOW LED
    GOTO main
    ENABLE
    FLASH:
    do
    for loop1 = 1 to 1000
    HIGH LED
    PAUSE 1
    NEXT LOOP1
    LOW LED
    PAUSE 1
    NEXT LOOP1
    IF bittest = 0 THEN
    GOTO main
    LOOP
    int1:
    BITtest = pot1
    INTCON =%11001000
  26. #66
    Jan 2013
    Texas USA
    Rob,
    Looks like you got it working.
    One little thing though.
    The Pause command is based upon the "DEFINE OSC" value to calculate the pause interval correctly.
    It is a good practice to have your "DEFINE OSC" statement up top in the source code before you use any time sensitive commands such as "Pause x".
    The way you have your program setup the following occurs, which I presume you have seen in practice on your physical system.
    The LED on GP2(pin5) will stay LOW (OFF) while the voltage input on GP1(pin6) is above your reference voltage.
    The LED GP2(pin5) will blink in 1sec intervals while the voltage input on GP1(pin6) is below your reference voltage.
    This works fine on my simulator.
    Good job!
    It looks like you're ready for a "nap" now.
    TABSoft
  27. #67
    Jan 2015
    Hi Tabsoft, thanks for comfirming also thanks again for all your help, I wouldnt have got to this point if it wasnt for you. I havent got a simulator so I just test straight on the BB.
    I will drop the pause below the osc value, thanks for that tip
    Do I implement the nap command in the same way as flashing an LED? So if bittest = 1 : nap 1, if bittest = 0 : goto main? Something like that ?
    Thanks again,
    Rob
  28. #68
    Jan 2013
    Texas USA
    Rob,
    Why don't you check this out.
    'PIC 12F683
    high LED    'Start with LED ON
    pause 500   'Pause .5 secs so you can see the LED turn on
    bitTest = POT1  'Take initial reading of input voltage state
    Loop1 = 0
    ENABLE
        IF bitTest = 1 THEN 'input voltage is < reference voltage
            low LED
            nap 1
        else    'bitTest = 0 - input voltage is > reference voltage
            GOTO FLASH
        GOTO main
    ENABLE
    FLASH:
        do
                HIGH LED
                PAUSE 1
            NEXT LOOP1
                LOW LED
                PAUSE 1
            NEXT LOOP1
            IF bitTest = 1 THEN
                GOTO main
        LOOP
    int1:
    bitTest = pot1
    INTCON =%11001000
    TABSoft
  29. #69
    Like Tabsoft wrote, you generally want your DEFINEs at the top of the program but it's for readabillity. In reallity it makes no difference because they are not runtime commands.
    Another little note
                HIGH LED
                PAUSE 1
            NEXT LOOP1
    What's the purpose of setting the LED high inside the loop?
    There's nothing inherently wrong in doing it but it does take (a little) bit of time.
    Also, now that you're starting to get the hang of it you might want to consider ditching the HIGH/LOW commands and simply set the pin directly, LED=1, LED=0. For this to work you need to clear the corresponding TRIS-bit first (TRISO.2 = 0 ' Set GPIO.2 to output). Doing it this way executes faster and consumes less codespace since it doesn't waste resources clearing the TRIS bit each and every time (which is what HIGH/LOW does for you).
    Again, you're not doing anything "wrong" - it all works fine, I'm just pointing out a couple of things you could improve and take with you to the next project.
    Jan 2015
    Thanks guys, I will have a play
    Rob
  31. #71
    Jan 2015
    Hi guys, okay I've been having a mess today & I am quite happy with myself. I managed to use the comparator successfully, now I have added a button into the routine.
    It is all doing what I want it to but I am having this big issue with de-bouncing how do I sort this out, what is the best way? Do I need to read the button in a different way?
    Here is the code -
    'PIC 12F683
    ANSEL = %00000001 'pin 7 analog
    CMCON0 = %00011110 'comparator mode
    VRCON = %10100000 'voltage reference
    TRISIO = %00101111 'pin 2,4,5,6,7 input
    IOC = %00001000 'pin 3 ioc
    RTPOT VAR CMCON0.6 'right trigger pot
    RTBITTEST var bit 'trigger debug test bit. Set/Clear in ISR and Check in main
    BUT VAR GPIO.3 'tactile button
    BUTBITTEST VAR BIT 'button test bit
    RTBITTEST = RTPOT 'initial reading
    BUTBITTEST = 0 'read 0 to start
    ENABLE
    IF RTBITTEST = 1 THEN
    GOTO RAPID
    IF RTBITTEST = 0 THEN
    GOTO SLEEPY
    GOTO main
    ENABLE
    RAPID:
    LOW GPIO.0
    PAUSE 70
    TRISIO.0 = 1
    PAUSE 70
    GOTO SLEEPY
    IF BUTBITTEST = 1 THEN
    GOTO FLASH
    GOTO RAPID
    ENABLE
    SLEEPY:
    HIGH GPIO.5
    PAUSE 1000
    TRISIO.5 = 1
    PAUSE 1000
    GOTO main
    GOTO SLEEPY
    ENABLE
    FLASH:
    HIGH GPIO.5
    PAUSE 300
    TRISIO.5 = 1
    PAUSE 300
    GOTO RAPID
    GOTO FLASH
    int1:
    RTBITTEST = RTPOT
    IF IOC.3 = 1 THEN
    BUTBITTEST = BUT
    INTCON =%11001000
    IOC = %00000000 'reset IOC.3
    RESUME 'resume to where left off
  32. #72
    Jan 2013
    Texas USA
    Rob,
    You really don't state what the problem is, only that you see a problem.
    A quick scan of the code leads to too many questions for me.
    What are you trying to accomplish in the different subroutines Rapid, Sleepy and Flash?
    You seem to be using two GPIO pins, one for Rapid (GPIO.0) and another (GPIO.5) for Sleepy and Flash.
    Another question is why in each of the subroutines are you setting the GPIO high, pausing and then configuring the same GPIO as an input?
    Without more info, it is futile to offer an opinion.
    TABSoft
  1. Beginner help!
    By Recognize in forum General
    Last Post: - 26th April 2012, 14:55
  2. pic24 beginner
    By robertpeach in forum General
    Last Post: - 13th August 2009, 11:57
  3. need help! to beginner
    By emilhs in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 18:44
  4. Beginner at PB
    By alphahr in forum Off Topic
    Last Post: - 21st April 2008, 17:43
  5. Can anyone help a beginner in a struggle?
    By douglasjam in forum mel PIC BASIC
    Last Post: - 5th May 2005, 23:29
