Beginner in need of help !!
Page 1 of 2 12 LastLast
Results 1 to 40 of 72
    Jan 2015
    Question Beginner in need of help !!
    Hi everyone, I am completely new to both these forums & pic programming. I am working with the 12f683 which I have managed to flash led 's read potentiometers etc, very basic stuff.
    Now to my question. I want to turn an LED on/off with a single tap of a tactile button. So press & release button: led turns on, then repeat to turn led off.
    I knio how to turn an LED on/off by holding the button for on & releasing for off, but I can't work out how to do the above.
    Any help would be greatly appreciated, I intend to over come any hiccups, not give up.
    Rob
    Apr 2011
    Welches, Oregon
    Default Re: Beginner in need of help !!
    Not sure how much help you need. I'm assuming you know input/ output, high/ low...
    Google "Pull down switch" and see how the level goes from high to low when the button is pressed (there is a pull up as well); use standard input technique to read the level change when the switch is pressed. To control the LED output, I think an if/ then will work well:
    If Button press = 0 and LED = off then [turn on LED]
    If Button press = 0 and LED = on then [turn off LED]
    You should also look at "debounce" as there is some issue to mechanical switches.
    Also, without some programming to limit the speed, the switch will turn the LED on/ off very quickly. A pause will work (to give the user time to release the button) or, you can look for a "1" on the switch (released) before allowing another button press to register.
    HTH,
    Jan 2015
    Okay I think I have made sense of this now - correct me if I'm wrong.
    So if I wanted to set the comparator up with say an internal reference & output (cm<2:0> = 011), I would set the cmcon0 register as CMCON0 = %00000011 ?
    Now to the VRR -
    I think Im right in saying that the comparator uses the main VDD+ pin on the chip to compare the internal reference to? What I dont understand is this -
    IF VRR=1 and VR3 ... VR0 = 1111 (15) with a VDD of 5V the Vref will be (15/24)*5 = 3,125V
    ^^ Where are they getting that 15 from? Also where do you get the 24 from?
    IF VRR=0 and VR3 ... VR0 = 1111 (15) with a VDD of 5V the Vref will be 5/4+(15/32)*5 = 3,593V
    ^^ Also why has the 24 changed to a 32 just from vrr=1 changing to a 0?
    One last question, Am I right in thinking that you have to use the CIN- pin on the chip to provide the voltage to check? Cant you use a comparator on any pin of the chip (apart from gp3, vdd & vss).
    Thanks again,
    Rob
    Hi Rob,
    Welcome to the forum! As you can imaging there are several ways to do this (and most other things). Amoque shows you one, here's another (which also tries to take care of the debounce):
    LED VAR GPIO.0
    Switch VAR GPIO.1
    ANSEL = 0                     ' No analog inputs
    CMCON = 7                     ' Comparators disabled
    TRISIO = %11111110            ' GPIO.0 as output
      IF Switch = 1 THEN          ' If the button is pressed...
        TOGGLE LED                ' ...we toggle the LED.
        Pause 20                  ' Then we wait for contact bounce on make to die, may need tweaking
        WHILE Switch = 1 : WEND   ' Then we wait for the user to actually release the button
        Pause 20                  ' Finally we wait for contact bounce on release to die, may need tweaking
    Goto Main
    Jan 2015
    Hi Rob,
    LED VAR GPIO.0
    Switch VAR GPIO.1
    Goto Main
    Thanks for this Henrik, I found this the best way. Another question, what if I wanted to run a different command to just turning on the LED, what about if I wanted to start the LED flashing upon button tap? Could I do this with the same method?
    Rob
    Don't understand this one, sorry...
    Well, yes. But as soon as you mention blinking it starts to get a Little bit more complicated. Why?
    Because then you need delays in there, during which (if using PAUSE) the button won't be polled so it'll feel unresponsive. Of course there are ways around this but the correct one depends on what you want to do after we get that LED to blink....
    Try this (I haven't, hope it works....):
    LEDState VAR BYTE
    Time VAR WORD
    LED_OFF CON 0
    LED_ON CON 1
    LED_FLASH CON 2
    Rate CON 250		      ' Time between LED toggles when blinking
        LEDState = LEDState + 1
        IF LEDState = 3 THEN LEDState = 0
      IF (LEDState = LED_OFF) or (LEDState = LED_ON) THEN
        LED = LEDState            ' Turn LED on or off, solid.
      IF LEDState = LED_FLASH THEN
        Time = Time + 1
        IF Time = Rate THEN
          TOGGLE LED
          Time = 0
        PAUSEUS 1000
    Goto Main
    Jan 2015
    Update: Ive looked in the data sheet & found out the reason for dividing by either 24 or 32, if your working out low range then : 24, high range : 32. Thats another thing understood.
    So the last thing I am struggling to understand now is, how do you get the number from th bits?
    VR<3:0> = 1111 (15). < How on earth do you get 15 from just bits 1111?
    This is the only thing that I'm struggling to understand now.
    Rob
    the low range internal vref gives you 15 steps of 0.208 volt steps starting at 0v
    the high range internal vref gives you 15 steps of 0.156 volt steps starting at 1.25v
    if you don't need the cout as an actual physical output CM<2:0> = 110 is a better choice
    and lets you chose pin 6 or 7 as your input (select with cmcon0.3 "CIS")
    why waste pins on a 8 pin chip
    0000=0
    0001=1
    0010=2
    0011=3
    ...................etc etc
    its called binary
    Jan 2015
    Edit: just re-read your post. I need to be able to read a pin & output on it at the same time (obviously with pauses, so do I need to use comparator with output?
    Hi Richard, I just came back here from doing a bit of googleing. It took me about 2 mins to figure out that its just binary, maybe if I had paid more attention in Maths I would know this!
    I now understand the voltage steps as well, everything is coming together now, its actually quite simple once understood.
    I still need to know if you can use a comparator with internal reference on any pin or does it have to be the CIN- pin?
    Cheers,
    Rob
    input to comparator is [ cin+ pin 7] or [cin- pin 6] with CM<2:0> = 110 its your choice
    there are other modes but in all cases cin is only on pins 6,7
    Jan 2015
    Hi Guys, thanks for the help. I will go away & have a play with your examples
    Thanks again,
    Rob
    Jan 2015
    Question Re: Beginner in need of help !!
    Hi again, I have been trying to play around with interrupts, both instant asm (which barely makes any sense to me) & basic 'on interrupt'.
    I have wrote a very basic code, however what I cant get my head around is how to incorporate the button method we discussed before into an interrupt? So how can one push & release of the button enter an interrupt loop & wait there, until I push & release the button again which would exit back to the main loop? Here is the small code I have written.
    Thanks again,
    Rob
    ANSEL = 0 'digital I/O
    CMCON0 = 7 'comparator off
    INTCON = %00010000 'enable pin 4 interrupt
    TRISIO = %00010000 'pin 4 input
    LED VAR GPIO.0 'pin 7 led
    Switch VAR GPIO.4 'pin 3 button
    ON INTERRUPT GOTO int1
    HIGH LED
    PAUSE 500
    LOW LED
    PAUSE 500
    GOTO main
    DISABLE
    int1:
    TOGGLE LED
    INTCON.1 = 0
    RESUME
    ENABLE
    Hi Rob,
    If you want the button to enable/disable the blining LED then you can't toggle the LED itself in the interrupt and then just continue to blink it in the main program loop. What you need is flag or semaphore telling the main loop if the LED is supposed to blink or not.
    BLINK VAR BIT
    If Blink = 1 THEN
      HIGH LED
      PAUSE 500
      LOW LED
      PAUSE 500
    GOTO main
    DISABLE
    int1:
    Blink = !Blink   ' Invert the state of the semapore
    RESUME
    ENABLE
    Please note that the PAUSE statement is basically delaying the Int1 routine from executing until the PAUSE statement finishes (that's the drawback of ON INTERRUPT). So if you push the button just as the PAUSE 500 start to exectute the ISR won't execute until 500ms later. This won't matter in this case but please keep that in mind when you start doing more complicated stuff.
    Also, the above does not incorporate any debounce, you may want to add that.
    Jan 2015
    Hi Henrik, thanks for explaing that to me it will help me a lot I am learning more & more as I go on
    Rob
    Hi Rob,
    BLINK VAR BIT
    If Blink = 1 THEN
      HIGH LED
      PAUSE 500
      LOW LED
      PAUSE 500
    GOTO main
    DISABLE
    int1:
    RESUME
    ENABLE
    Jan 2015
    Hi, please can someone tell me how I disable MCLR on gp3 (my pic is 12f683). Ive been researching for the past 2 hours & I have got no closer to disabling it, I just want GP3 as a normal input pin, not this MCLR crap!
    If anyone knows could you please help?
    Rob
    MCLR is disabled by clearing the correct "fuse" in the CONFIG word. With PBP3 you set the CONFIG word(s) with the #CONFIG/#ENDCONFIG compiler directives (more on that in the manual). Your PBP3 installation folder has a subfolder named DEVICE_REFERENCES in which you'll find a file for each and every device the compiler supports. The file contains information about the various CONFIG options and also what defaults PBP uses if you don't include any in your code.
    For a 12F683 the defaults are:
       __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_ON & _CP_OFF
    If you want to disable MCLR and keep everything else then copy/paste this into your program:
       __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _CP_OFF
    Jan 2015
    Your a life saver mate. I knew I had to write to the config but I just could not find out which way to do it, I was nearly there I was putting @config instead though!
    Thanks again,
    Rob
    Jan 2015
    Hi Henrik, I am going to start my first project which will hopefully teach me new things along the way. I have question for you before I start though, I am hoping you can give a short answer to this.
    Basically I want different modes (say 10) which are each cycled through via a tap of a tactile button (so mode 1, tap button, mode 2, tap, mode 3, etc) & each mode has its own led flashing at a different speed.
    My question is, which way is the best to do this? With interrupts or something else? I would also like the chip to watch for other button presses as well not just this one sequence of modes, so its not going to be just a simple sequnce of button tap to next mode etc.
    So I need a way of watching for multiple input changes all the time, I am expecting interrupts to be the answer after reading about, but just want to be sure
    Hope you can help,
    Rob
    Hi Rob,
    There are several ways - as is the case most of the time.
    Interrupts are probably the way to go but there may be other ways.
    Do you have a particular chip in mind, is it still the 12F683? I think not since you mention 10 modes, each with its own LED.....
    How many switches do you need to monitor?
    Jan 2015
    Hi Henrik, I will still be using the pic12f683. This is just a starter project which I am hoping to take to something bigger, but I will be flashing 1 led, the 10 modes are all outputting to the one led. I would like to sense 2 inputs, 1 tactile button & 1 using adc to mintor coltage change.
    Rob
    Jan 2015
    Angry Re: Beginner in need of help !!
    Okay I have had a go & failed What am I doing wrong?
    'PIC12f683
       __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF
    DEFINE OSC 4 '4mhz ocsillator
    ANSEL = %00000010 'pin 6 analog
    CMCON0 = %00000100 'comparator mode
    VRCON = %00001000 'voltage reference
    TRISIO = %00000010 'pin 6 input
    POTEN VAR CMCON0.1 'pot pin 6
    LED VAR GPIO.2 'led pin 5
    PAUSE 20
    IF CMCON0.1 = 1 THEN
    HIGH LED
    LOW LED
    GOTO main
    Jan 2013
    Texas USA
    Rob,
    Glad to see your working through the design and issues.
    You are very close.
    Here are a couple of things you need to correct.
    1. VRCON: Look at the register description in "Register 8-3" on page 53 of the datasheet.
    In your program you are setting VRCON like this: VRCON = %00001000 'voltage reference
    There are more bits in the register that you need to take into account.
    A. You have bit7=0 which does this "0 = CVREF circuit powered down, no IDD drain and CVREF = VSS". This turns OFF the internal reference voltage.
    You need to change this to "1", 1 = CVREF circuit powered on, to turn on the internal reference voltage circuit.
    B. You have bit5 = 0 which does this "VRR: CVREF Range Selection bit 0=High Range"
    This changes your CVref equation and result to this: "VRR = 0, CVREF = (VDD/4) + (VR3:VR0 X VDD/32)", which when you plug in your values you get this
    for your reference voltage. (3.3/4) + (8/32) = (0.825) + (0.25) = 1.075 Vdc. Now this may be what you were actually trying to do, if so then your are good.
    2. In your main loop you are attempting to test the output of the Comparator like this: "IF CMCON0.1 = 1 THEN"...
    Look at the CMCON0 register description in "Register 8-1" on page 47 of the datasheet and compare that with the "CMCON0.1 = 1" above.
    You are testing bit1 of the CMCON0 register, that is what the ".1" does. xxxx.1 says I want to look at bit1 of xxxx.
    Is this the bit you need to check for the Comparator Output? If you're not sure have a look at "FIGURE 8-3" on page 49 and look at the figure for the
    CM Mode you are using "100". That diagram indicates what the Comparator Output is by name.
    Check and correct this.
    3. Lastly, and somewhat obscure in the DS, you need to determine how you want the Comparator to test and output.
    As I understand you want to check the input pin voltage against your "1.075 Vdc" reference you are setting up internally and have the following outcomes:
    If the input is "Lower than 1.075 Vdc" you want the LED to be OFF and you want the LED to be "ON when the input is Higher than 1.075 Vdc".
    To get these results you need to take a look at a couple of items in the datasheet.
    A. Look at CMCON0, "Register 8-1" on page 47, and review the information for bit6 and bit4.
    Also look at "TABLE 8-1" on page 48.
    Between these two, you should be able to piece together how you need to configure the operation to get your desired "Output" of the Comparator.
    You are getting close, hopefully these additional points will get you further on your way.
    TABSoft
    Jan 2015
    My last post messed up a bit at the end, it was supposed to be monitor voltage lol. Anyway given the things I would like, do you think interrupts are the best route? I would end up adding more outputs to this (in the end 4 outputs, 2 inputs).
    Thanks again,
    Rob
    Jan 2015
    Unhappy Re: Beginner in need of help !!
    Ive decided to go the interrupt route... I am stuck already. Here is my simple code, why isnt my interrupt working?
    DEFINE OCS 4 '4mhz ocsillator
    ANSEL = 0 'all I/O digital
    LED VAR GPIO.0 'LED pin 7
    LED2 VAR GPIO.1 'LED2 pin 6
    ON INTERRUPT GOTO mode1 'interrupt handler is mode1
    INTCON = %10001000 'enable gp3 interrupt
    ENABLE
    HIGH LED 'led on
    PAUSE 500 'delay 0.5 second
    LOW LED 'led off
    GOTO main 'repeat
    DISABLE 'disable interrupts in handler
    mode1:
    HIGH LED2 'led2 on
    PAUSE 50
    LOW led2 'led2 off
    PAUSE 50
    RESUME 'return to where left off
    ENABLE 'enable interrupts
    Normally in the interrupt routine this is needed.
    INTCON.1 = 0
    But the data sheet for this chip reads like this is needed.
    INTCON.0 = 0
    Then at the beginning of your code below
    INTCON = %10001000
    add
    IOC.3=1
    I think...
    Jan 2015
    INTCON.1 = 0
    INTCON.0 = 0
    INTCON = %10001000
    add
    IOC.3=1
    I think...
    Brilliant, that got it working. I take it IOC.3 = 1 tells the chip when to interrupt & on what pin?
    So INTCON = %10001000 tells it to enable interrupts on pin 3 & IOC.3 = 1 tells it to interrupt on pin 3 change ?
    Thanks for your help,
    Rob
    Jan 2013
    Texas USA
    This should work for you. It works in my simulator.
    Also, since PBP's ON INTERRUPT only checks to see if an interrupt has occurred between PBP commands, you may want to use a loop counter in your main routine and use short pauses. This is how I revised your code.
    Comments are added to the code below.
    Good Luck.
    'PIC 12F683
    'DEFINE OCS 4 '4mhz ocsillator
    loop1 var byte  ' Loop 1 Counter
    INTCON = %10001000 'enable GIE and GPIE; clear GPIF
    IOC = %00001000 ' enable IOC3 (GPIO3 Interrupt on change)
    ENABLE
    do
        for loop1 = 1 to 50
            HIGH LED 'led on
            'PAUSE 500 'delay 0.5 second
            pause 10    '10 ms
        next loop1
        for loop1 = 1 to 50
            LOW LED 'led off
            pause 10    '10 ms
        next loop1
    'GOTO main 'repeat
    loop
    mode1:
    if INTCON.0 = 1 then    'one of the GPIO<5:0> pins changed state (must be cleared in software)
        HIGH LED2 'led2 on
        PAUSE 50
        LOW led2 'led2 off
        PAUSE 50
    end 'got here by mistake
    TABSoft
    Jan 2015
    Quote Originally Posted by Tabsoft View Post
    Good Luck.
    'PIC 12F683
    ENABLE
    do
        for loop1 = 1 to 50
            HIGH LED 'led on
            pause 10    '10 ms
        next loop1
        for loop1 = 1 to 50
            LOW LED 'led off
            pause 10    '10 ms
        next loop1
    'GOTO main 'repeat
    loop
    mode1:
        HIGH LED2 'led2 on
        PAUSE 50
        LOW led2 'led2 off
        PAUSE 50
    Hi Tabsoft, that worked perfectly. I can see what you mean by using loops instead of pauses, the interrupt is much more reactive.
    Now I just need to know how to stay in that interrupt routine until I tap the button again.
    Rob
    Hi Rob,
    Even though that would work for this particular application that's generally not what you want to do (ie stay in the interrupt routine). Instead you do as I showed earlier, use a flag/semaphore in the interrupt service routine which the main code reads and determines what to do.
    The same thing applies to your scenario with ten states. You have a variable which you increment in the interrupt (ie once very time you press the button), once it gets to 10 you reset it to zero. Then, in the main program loop you simply check the value of this variable and act accordingly. With a bit of thought and some math you might even USE the variables value directly as the delay in your loop to blink the LED.
    As for the analog input it's important to understand that there is no mechanism to automatically run the ADC and detect (ie interrupt) when the voltage at the input changes. You need to write code to sample the input once every minute, second, millisecond or whatever the requirement may be.
    Finally, please don't quote the full message just posted. There's really no need to have the very latest post quoted in full.
    Jan 2013
    Texas USA
    Rob,
    Glad it worked for you.
    I'm not sure if you want/need to stay in the ISR as I don't know your final objective.
    I would suggest using a flag to determine the state of the IOC.3 interrupt coming from your button.
    Then in the ISR change the state of the flag each time the interrupt occurs and then get out of the ISR.
    You can then setup a subroutine for what you wanted to accomplish in the ISR.
    Finally in your main loop check the state of the flag and gosub to the new subroutine.
    Here is a working example. Expanded on what I posted last time.
    'PIC 12F683
    loop1 var word  ' Loop 1 Counter (word for 0 to 65535 increments)
    loop2 var byte  ' Loop 2 Counter (byte used for 0 to 255 increments)
    ModeFlag var bit   ' Bit to determine what state of IOC.3 is
    '*****Initlaze Vars*****
       loop1 = 0
       loop2 = 0
    ModeFlag = 0
    ENABLE
    do
        for loop1 = 1 to 500
            HIGH LED 'led on
            pause 1    '1 ms
            if ModeFlag = 1 then
            gosub moderoutine
        next loop1
            LOW LED 'led off
            pause 1    '1 ms
            gosub moderoutine
        next loop1
    'GOTO main 'repeat
    loop
    moderoutine:
        do while ModeFlag = 1
            high LED2   'LED2 On
            for loop2 = 0 to 50
                pause 1 '1ms
            next loop2
            low LED2    'LED2 Off
            for loop2 = 0 to 50
                pause 1 '1ms
            next loop2
        loop
    mode1:
        'HIGH LED2 'led2 on
        'PAUSE 50
        'LOW led2 'led2 off
        'PAUSE 50
        'Set the ModeFlag
        ModeFlag = ~ ModeFlag
    TABSoft
    Jan 2015
    Thanks a lot for the help guys, I appreciate it I understand now how isr's work now.
    Rob
    Another aproach is to use the interrupt mechanism as a way to "latch" the buttonpress but then not actually enable the interrupt itself but instead poll the interrupt flag to determine if the button was pressed.
    State VAR BYTE
        If INTCON.1 = 1 THEN    ' GP2 input interrupt
          INTCON.1 = 0   ' Clear flag
          State = State + 1
          If State = 3 THEN State = 0
       SELECT CASE State
          Case 0
            HIGH LED
            PAUSE 50
            LOW LED
            PAUSE 50
          CASE 1
            HIGH LED
            PAUSE 100
            LOW LED
            PAUSE 100
          CASE 2
            HIGH LED
            PAUSE 150
            LOW LED
            PAUSE 150
    GOTO MAIN
    Jan 2015
    Hi, I like that way as well. Although at some point I need to add a nap command with wdt off so it wakes when a voltage is higher than 0.60v & naps when voltage is less then, so I would have to use an interupt anyway at some point?
    Rob
    Jan 2015
    Right I have changed the code from what Tabsoft last posted, so now there are 3 modes each blinking led at a different rate depending on the mode. Every tap of the button is supposed to goto the next mode.
    Something weird is happening though, each tap of the button is reversing the mode lol. So instead of going forwards to the next mode, its going backwards (should go mode 1 > mode 2, but is going Mode 1 > mode 3 > mode 2).
    Any ideas? here is the code -
    'PIC 12F683
       loop1 = 0
    ModeFlag = 0
    ON INTERRUPT GOTO modeselect 'interrupt handler is modeselect
    ENABLE
    mode1:
    do
        for loop1 = 1 to 1000
            HIGH LED 'led on
            'PAUSE 1000 'delay 1 second
            pause 1    '1 ms
            gosub mode2
        next loop1
            LOW LED 'led off
            pause 1    '1 ms
            gosub mode2
        next loop1
    'GOTO mode1 'repeat
    loop
    ENABLE
    mode2:
    do
            HIGH LED 'led on
            pause 1    '1 ms
            gosub mode3
        next loop1
            LOW LED 'led off
            pause 1    '1 ms
            gosub mode3
        next loop1
    'GOTO mode2 'repeat
    loop
    ENABLE
    mode3:
    DO
        for loop1 = 1 to 50
            HIGH LED 'led on
            'PAUSE 50 'delay 0.05 second
            pause 1    '1 ms
            gosub mode1
        next loop1
        for loop1 = 1 to 50
            LOW LED 'led off
            pause 1    '1 ms
            gosub mode1
        next loop1
    'GOTO mode3 'repeat
    loop
    modeselect:
        'next mode
        'Set the ModeFlag
    Jan 2015
    UPDATE: I've just worked it out I think, its because I haven't got any debounce in there so every 'tap' could be jumping a couple of modes instead of seeing it as 1 button tap & jumping 1 mode.
    Where do I actually add the debounce though? I couldn't add it into the sub modes as it would wreck the routine timing wouldn't it?
    No debounce may very well be part of the problem but in THIS case I think the contact bounce is what actually makes it sort of "work".
    The real issue, I believe, is that your "loops" looks for ModeFlag being equal to 1 and switches mode. But the flag is not being cleared. So, if you push the button once, the ISR sets the flag. If there are no bounce the flag will be set all the time and the program will keep cycling between the different modes since the flag is never cleared. That's a problem with the implementation.
    What's more severe is that you're using GOSUB without a matching RETURN. What you want in this case is GOTO.
    Make the ISR set (and only set) the ModeFlag, implement some debounce in the ISR.
    In the main loop you check the ModeFlag and IF it's set you first clear it and then act accordingly (ie. jump to the next mode).
    Also, there's no need to set the LED high or low 1000 times (ie do it inside the FOR_NEXT loop), one time is enough, I'd rewrite the loop like:
    DO
        HIGH LED
            pause 1    '1 ms
            IF ModeFlag = 1 THEN
              ModeFlag = 0
              GOTO Mode 2
         next loop1
        LOW LED 'led off
            pause 1    '1 ms
              ModeFlag = 0
              GOTO Mode 2
        next loop1
    LOOP
    Jan 2015
    Hi Henrik, thanks for helping. I have changed to the code to do as you said: goto's instead of gosub's & made the ISR set flag only (i think).
    It all seems to work better now, however I still have a problem with the debounce as I think it is actually 'the problem' now instead of actually making the code work as you stated. The isr sees the release of the button as an interrupt & sets a flag again which skips modes. So how do I go about adding the debounce without slowing things down?
    Isnt there a way to only interrupt or tell the ISR to flag only if the button is depressed & not when released? Here is the updated code -
    'PIC 12F683
       loop1 = 0
    ModeFlag = 0
    ENABLE
    mode1:
    do
            HIGH LED 'led on
            pause 1    '1 ms
            ModeFlag = 0
            goTO mode2
        next loop1
            LOW LED 'led off
            pause 1    '1 ms
            Modeflag = 0
            goTO mode2
        next loop1
    'GOTO mode1 'repeat
    loop
    ENABLE
    mode2:
    do
            HIGH LED 'led on
            pause 1    '1 ms
            modeflag = 0
            goTO mode3
        next loop1
            LOW LED 'led off
            pause 1    '1 ms
            modeflag = 0
            goTO mode3
        next loop1
    'GOTO mode2 'repeat
    loop
    ENABLE
    mode3:
    DO
        for loop1 = 1 to 50
            HIGH LED 'led on
            pause 1    '1 ms
            modeflag = 0
            goTO mode1
        next loop1
        for loop1 = 1 to 50
            LOW LED 'led off
            pause 1    '1 ms
            modeflag = 0
            goTO mode1
        next loop1
    'GOTO mode3 'repeat
    loop
    modeselect:
        'next mode
        'Set the ModeFlag
        ModeFlag = 1
    You're quite right, it's because you're using the IOC (Interrupt On Change), it'll trip the interrupt both when you push the button and when you release the button. (As well as on all the edges of the contact bounce). Also, when you're using IOC you need to remember to read the port (even if you're not using the value) in order to clear the mismatch condition.
    I'd wire the button to GP2 and use the "normal" INT instead of IOC.
    Jan 2015
    So if I want to use IOC, I would need to read the button or any other type of input such as the adc?
    I'm only asking as I need to be able to use interrupt on like 5 inputs, not just 1. Although gp2 will use adc not any others if that would be easier.
    Rob
    Jan 2015
    Hi guys, okay I've been having a mess today & I am quite happy with myself. I managed to use the comparator successfully, now I have added a button into the routine.
    It is all doing what I want it to but I am having this big issue with de-bouncing how do I sort this out, what is the best way? Do I need to read the button in a different way?
    Here is the code -
    'PIC 12F683
    ANSEL = %00000001 'pin 7 analog
    CMCON0 = %00011110 'comparator mode
    VRCON = %10100000 'voltage reference
    TRISIO = %00101111 'pin 2,4,5,6,7 input
    PAUSE 50 'wait for hardware to settle
    ON INTERRUPT GOTO int1 'interrupt handler is int1
    INTCON = %11001000 'enable GIE and GPIE; clear GPIF
    PIE1 = %00001000 'enable comparator interrupt
    IOC = %00001000 'pin 3 ioc
    RTPOT VAR CMCON0.6 'right trigger pot
    RTBITTEST var bit 'trigger debug test bit. Set/Clear in ISR and Check in main
    BUT VAR GPIO.3 'tactile button
    BUTBITTEST VAR BIT 'button test bit
    RTBITTEST = RTPOT 'initial reading
    BUTBITTEST = 0 'read 0 to start
    ENABLE
    IF RTBITTEST = 1 THEN
    GOTO RAPID
    IF RTBITTEST = 0 THEN
    GOTO SLEEPY
    GOTO main
    ENABLE
    RAPID:
    LOW GPIO.0
    PAUSE 70
    TRISIO.0 = 1
    PAUSE 70
    GOTO SLEEPY
    IF BUTBITTEST = 1 THEN
    GOTO FLASH
    GOTO RAPID
    ENABLE
    SLEEPY:
    HIGH GPIO.5
    PAUSE 1000
    TRISIO.5 = 1
    PAUSE 1000
    GOTO main
    GOTO SLEEPY
    ENABLE
    FLASH:
    HIGH GPIO.5
    PAUSE 300
    TRISIO.5 = 1
    PAUSE 300
    GOTO RAPID
    GOTO FLASH
    int1:
    if PIR1.3 = 1 then  'Comparator Interrupt fired (must be cleared before resume)
    RTBITTEST = RTPOT
    IF IOC.3 = 1 THEN
    BUTBITTEST = BUT
    INTCON =%11001000
    PIR1 = %00000000 'reset CMIF
    IOC = %00000000 'reset IOC.3
    RESUME 'resume to where left off
  1. Beginner help!
    By Recognize in forum General
    Last Post: - 26th April 2012, 14:55
  2. pic24 beginner
    By robertpeach in forum General
    Last Post: - 13th August 2009, 11:57
  3. need help! to beginner
    By emilhs in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 18:44
  4. Beginner at PB
    By alphahr in forum Off Topic
    Last Post: - 21st April 2008, 17:43
  5. Can anyone help a beginner in a struggle?
    By douglasjam in forum mel PIC BASIC
    Last Post: - 5th May 2005, 23:29
