DS1337 - 12h to 24h mode
Results 1 to 31 of 31
    Jan 2013
    Texas USA
    Default Re: DS1337 - 12h to 24h mode
    Try removing or commenting out the following line from your ADDHour routine within the "if hourmode = 0" block (24 hour mode)
    if BCDResult_temp > 12 then RTCHour.5 = 1
    TABSoft
    Sep 2006
    Hi again,
    here is you example with different hours..
    24Hr mode
    Time is 23:00 hours, hours = %00100110 notice bit 5 is a one
    add 1 to 23
    Time is 00:00 hours, hours = %00000000 notice bit 5 is zero
    SO the bit 5 does changes int he 24H mode...
    maybe i'm still not seeing it good..
    Sep 2006
    HooHoo ! , got it all working now.
    Ya bit 5 was a bit confusing,
    thanks a million for your time
    Jan 2013
    Texas USA
    Great! Glad to help.
    The hour register of the RTC can be a bit confusing with its mix of hour mode and am/pm options/values.
    When I did this a while back I created a spreadsheet to to visual all of the possible values and how to deal with them.
    How about posting your final code so the readers can see your final solution?
    TABSoft
    Sep 2006
    Here you go :
    '// Using the PIC16F886
    '// AM PM mode
    '// Increment Hour and Minutes
    '// Output to LCD 2x16
    '// Define section //
    INCLUDE "modedefs.bas"
    Define OSC 8
    CM1CON0.7 = 0
    CM2CON0.7 = 0
    DEFINE BUTTON_PAUSE 50
    '////////////////// HPWM /////////////////////////
    DEFINE CCP1_REG PORTC
    DEFINE CCP1_BIT 2
    Pause 20
    '// LCD configuration //
    DEFINE LCD_DREG PORTA ' Set LCD Data port
    DEFINE LCD_DBIT 0 ' Set starting Data bit (0 or 4) if 4-bit bus RB.4, RB.5, RB.6, RB.7
    DEFINE LCD_RSREG PORTB ' Set LCD Register Select port
    DEFINE LCD_RSBIT 7 ' Set LCD Register Select bit
    DEFINE LCD_EREG PORTB ' Set LCD Enable port
    DEFINE LCD_EBIT 6 ' Set LCD Enable bit
    DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits) '4 therefore put wire at 4, 5, 6 and 7 of LCD
    DEFINE LCD_LINES 2 ' Set number of lines on LCD
    DEFINE LCD_COMMANDUS 2500
    DEFINE LCD_DATAUS 250
    DEFINE CHAR_PACING 2000
    '// Variable Declaration and initialization //
    TrisB= 0
    TrisA= 0
    TrisC=%1110000
    SDApin var PORTC.4 ' RTC data
    SCLpin var PORTC.3 ' RTC clock
    tmp var byte
    pkt var byte[11]
    rtcAMPM var bit ' Storage flag to indicate AM or PM ; 0=AM, 1=PM
    hourmode var bit ' Storage flag for RTC 12/24 hour mode ; 0=24Hr, 1=12Hr
    BCDResult var byte ' Storage for temporary result for BCD Conversions
    RTCHour var byte
    RTCMin var byte
    RTCSec var byte
    'The DS1337 can be run in either 12-hour or 24-hour mode. Bit 6 of the hours register is defined as the 12- or 24-
    'hour mode-select bit. When high, the 12-hour mode is selected. In the 12-hour mode, bit 5 is the AM/PM bit with
    'logic high being PM. In the 24-hour mode, bit 5 is the second 10-hour bit (20–23 hours).
    'The only time you should need to worry about bit 5 is when bit 6 = 1 (12 hour mode).
    ansel=0 'dig i/o
    ' CMCON0=7 ' compare off
    trisc=%1110000
    'i2cwrite sdapin,sclpin,$D0,0,[$0,$14,$18,3,$14,1,$14] ' TIME AND DATE
    pause 10
    Gosub gethour
    if PortC.5 & PortC.6 then gosub ampm
    if PortC.6 then gosub ADDHour
    if PortC.5 then gosub ADDMin
    Gethour:
    i2cREAD sdapin,sclpin,$D0,0,[str pkt \3 ]
    RTCHour = pkt[2]
    if RTCHour.6 then ' this is HIGH, therfore 12H mode
    lcdout $fe,1,"Time=", hex2 (pkt[2]& %00011111),":",hex2 pkt[1],":",hex2 pkt[0] 'bit 0=sec, bit 1=min, bit 2=hrs
    if RTCHour.5 then
    lcdout $fe,$c0, "pm:"' ,bin RTCHOUR.6,":", Bin RTCHOUR.5,":", bin RTCHOUR
    lcdout $fe,$c0, "am:"' ,bin RTCHOUR.6,":", Bin RTCHOUR.5,":", bin RTCHOUR
    lcdout $fe,1,"Time2=", hex2 pkt[2],":",hex2 pkt[1],":",hex2 pkt[0]
    ' lcdout $fe,$c0, " :" ,bin RTCHOUR.6,":", Bin RTCHOUR.5,":", bin RTCHOUR
    ampm:
    I2CRead SDApin,SCLpin,$D0,$02,[RTCHour]
    hourmode = RTCHour.6
    if hourmode = 1 then ' Is the RTC set for 12-hour mode
    rtcAMPM = RTCHour.5 ' Assign AM/PM
    RTCHour = RTCHour & %00011111 ' Bits 4-0 = Hours 0-12
    BCDResult = RTCHour
    gosub Bcd2Dec
    if hourmode = 1 then '12Hr Convert to 24Hr
    hourmode = 0 ' change to 24Hr
    if rtcAMPM = 1 then 'PM
    BCDResult = BCDResult + 12 'PM
    else '24Hr Convert to 12Hr
    hourmode = 1
    if BCDResult > 12 then
    BCDResult = BCDResult - 12
    rtcAMPM = 1
    rtcAMPM = 0
    gosub Dec2Bcd
    RTCHour = BCDResult
    RTCHour.6 = hourmode
    RTCHour.5 = rtcAMPM
    I2cwrite SDApin,SCLpin,$D0,$02,[RTCHour]
    pause 10
    I2cwrite SDApin,SCLpin,$D0,$02,[RTCHour] ' Need to write twice because you changed the mode bit
    pause 10
    Bcd2Dec:
    ' Subroutine to convert BCD (2 hex digits) to Decimal
    ' Make sure to set BCDResult with parameter value before calling this sub
    ' Result is stored in BCDResult
    BCDResult = (((BCDResult >> 4) * 10) + (BCDResult & $0f))
    Dec2Bcd:
    ' Subroutine to convert Decimal to BCD (2 hex digits)
    BCDResult = (((BCDResult / 10) << 4) | (BCDResult // 10))
    ADDHour: 'increment hours
    pause 200
    if PortC.5=1 then return
    if PortC.6=1 then
    RTCHour = pkt[2]
    rtcAMPM = RTCHour.5
    '////////Selection Begins here
    if hourmode = 0 then ' this is 24H mode 0H to 23H and bit 5 is used to calculate hours
    RTCHour = RTCHour & $3F ' keeping the bit 5
    BCDResult = RTCHour
    gosub Bcd2Dec
    if BCDResult > 23 then
    BCDResult = 0
    ' hourmode = 1
    rtcAMPM=0
    if BCDResult > 19 then ' bit 5 is needed for the hours 20h to 23h
    rtcAMPM=1
    gosub Dec2Bcd
    RTCHour = BCDResult
    RTCHour.5 = rtcAMPM
    pause 10
    pause 10
    if hourmode = 1 then ' this is 12H mode 0H to 11H
    RTCHour = RTCHour & %00011111 ' keeping the bit 5
    BCDResult = RTCHour
    gosub Bcd2Dec
    BCDResult = 1
    rtcAMPM = not rtcAMPM ' 0 is for the AM mode
    gosub Dec2Bcd
    RTCHour = BCDResult
    RTCHour.5 = rtcAMPM
    pause 10
    pause 10
    ADDMin: ' increment a minutes
    pause 200
    if PortC.6=1 then return
    if PortC.5=1 then
    ' I2CRead SDApin,SCLpin,$D0,$02,[RTCHour]
    I2CRead SDApin,SCLpin,$D0,$00,[RTCSec,RTCMin,RTCHour]
    BCDResult = RTCMin
    gosub Bcd2Dec
    if BCDResult > 59 then BCDResult = 0
    Pause 2
    gosub Dec2Bcd
    RTCMin = BCDResult
    I2cwrite SDApin,SCLpin,$D0,$01,[RTCMin]
  1. 12H format setting for DS1307
    By larzazral in forum mel PIC BASIC Pro
    Last Post: - 23rd February 2010, 07:34
  2. example code for DS1337
    Last Post: - 8th December 2009, 21:16
  3. Code for DS1337
    By Fernanda in forum Off Topic
    Last Post: - 21st July 2008, 20:18
  4. PBPro for 16-bit PICs (24F/24H/DSPICs)?
    By Sergeant in forum mel PIC BASIC Pro
    Last Post: - 20th April 2007, 20:18
  5. DS1337 Problem
    By snow in forum mel PIC BASIC Pro
    Last Post: - 9th January 2005, 12:17
