How to calculate Burden Resistor ??
Results 1 to 10 of 10
    Quebec, Canada
    Default Re: How to calculate Burden Resistor ??
    I never used a current transformer but I suggest you place the burden resistor before the bridge.
    Then you CT is 100:50 = 20:1
    @100A on the primary you'll have 5 amps on the secondary, so 2ohms will give you 10VAC rms.
    The bridge has a 1.4V drop you must take in account. Also, AC voltage fully rectified with a capacitor and no load will give you a peak voltage of (v * 1.4142) (1.4142 = square root 2).
    So for a 10VDC max:
    (10/1.4142) + 1.4 = 8.47VAC on the secondary.
    8.47VAC / 5A = 1.694 ohm. Good luck to find one.
    My suggestion: pick a standard value < 1.694ohm and then compute the results. Finally, use a good multimeter to caliber your system.
    HTH
    May 2012
    Merseyside, UK
    Thank you for that…
    2R is the answer I got to…. I also worked out the Wattage of the resistor needs to be > 50Watt (Large and Hot)
    Possible temperature drift !!!!
    Quebec, Canada
    Yep! Lot of power! What about shorting the secondary and measuring the current with a current sensor like this:
    http://www.allegromicro.com/en/Produ...Cs/ACS712.aspx
    on a breakout board:
    http://www.dx.com/p/acs712-5a-curren...7#.VLRjedKG_CY
    [Board Admin: I'm sorry for the ad , I'm sorry! I'm sorry!]
    if you have way to calibrate and check linearity......
    May 2012
    Merseyside, UK
    Thank you Amgen
    Nice Idea.... but pot Wattage needs to be decent size. (More power) ?
    ok check these..... http://amploc.com/
    May 2012
    Merseyside, UK
    Thank you
    The sensors all ready exist.. I am attempting to use the output for my purpose.
    But will prob look at those in future.
    Thank you again
    May 2012
    Merseyside, UK
    Quote Originally Posted by MichelJasmin View Post
    I like this.....
    Also a 30Amp Version.... Might not need a CT !!!
    Thank you
  1. Calculate checksum?
    By jgauthier in forum mel PIC BASIC Pro
    Last Post: - 26th February 2013, 00:04
  2. Calculate how many amps a solenoid needs
    Last Post: - 2nd April 2008, 11:23
  3. calculate time between pulses
    By hell_pk in forum mel PIC BASIC Pro
    Last Post: - 20th October 2007, 17:49
  4. How to calculate a VDR resistor
    By Sharky in forum Off Topic
    Last Post: - 3rd December 2005, 10:13
  5. calculate with date
    By Pedro Pinto in forum mel PIC BASIC Pro
    Last Post: - 14th October 2005, 17:49
