Darrels interrupts and multiple SOUND statements, will it work?
Results 1 to 32 of 32
    Default Re: Darrels interrupts and multiple SOUND statements, will it work?
    What happens if I run this code say at 4mhz 16F870 ? there will be no output, frequency wont match, or sound will be breaking up?
    on 16F876A, gives error during compile on this:
    IPR1.1 = 1 ' TMR2 high priority
    Gives same error on 12F1840.
    There's not enough time to actually execute the interrupt service routine before the timer fires another interrupt. The CPU will spend all of its time in the ISR, no time left for you to set the desired frequencies etc and the output frequenices will be wrong and...... Simply - It just won't work. You need 16MHz.
    The 16F series doesn't have interrupt priorities, remove the line.
    The 12F series doesn't have interrupt priorities, remove the line.
    Still does not compile on 16F876A -
    ASM ERROR:
    Symbol not previously defined (wsave), (ssave), (psave).
    Compile OK on 12F1840, but ASM warning - Found label after column 1. (Generate), Extraneous arguments on the line
    added this for 16F876A:
    wsave VAR BYTE $20 SYSTEM
    ssave VAR BYTE $22 SYSTEM
    psave var byte $24 SYSTEM
    Have no idea why, but no more errors in compile, will try runtime shortly.
    It works, sort of (20mhz crystal 16F876A).
    If any channel duration has same value, these channels won't play.
    Also, playback duration is different each time, it might play 4 or 5 times same duration, then 2 times shorter duration, then again normal.
    It works properly only when value of output timings is first is the shortest, 2nd medium and 3rd - longest. If in reverse, it will only play last, short one.
    > ASM ERROR:
    Do you have DT-Ints in the program? I thought I said:
    You can not cut'n'paste this into a program using DT-Ints. Try it stand-alone first and we'll see about DT-ints later - if needed.
    That's a warning, have you edited the source in any way? I don't get that here.....
    Are you running the program, by itself, on the 16F877 at 20MHz or are you, despite my warning, trying to run it together with the rest of your program AND DT-INTS?
  1. Multiple IF THEN Statements: PIC16F84A
    By bob425 in forum mel PIC BASIC Pro
    Last Post: - 10th August 2012, 07:01
  2. Problem with multiple interrupts
    By aratti in forum General
    Last Post: - 2nd June 2009, 09:18
  3. Multiple IF-THEN statements
    By DavidK in forum mel PIC BASIC Pro
    Last Post: - 20th June 2007, 19:28
  4. Handeling multiple Interrupts
    By BobSpencerr in forum General
    Last Post: - 1st March 2007, 02:12
  5. Multiple HW Interrupts
    By Radiance in forum mel PIC BASIC Pro
    Last Post: - 13th August 2003, 23:35
