It's been a long time!!!
Results 1 to 9 of 9
    Default Re: It's been a long time!!!
    ok looks like 48mhz clock is more likely to be correct , the table makes no mention of the /4 option as depicted in the osc diagram fig 3.1 ,and a 0 divide option seems more probable
    what are you using to pgm the chip , its not holding mclr low or something easy like that . pwr ok ? led works ?
    OSCCON = %01110010
    might by worth a try
    Try reversing the order:
    OSCCON must always precede OSCTUNE
    Been there done that.
    Norm
    Norm
    Have you had a chance to try the above?
    This issue also came up on another forum.
    Norm
    Sep 2008
    I tried swapping the two lines and it did not make a difference. But, I have come to the conclusion I either have a faulty chip/board or the bootloader is not actually sending the program to the chip.
  1. How long... LED on time without resistors?
    By Heckler in forum General
    Last Post: - 14th March 2011, 18:49
  2. Hello, long time no post (ADC sample rate)
    By Jhong2 in forum General
    Last Post: - 14th April 2009, 05:13
  3. Long start time
    By ttease in forum mel PIC BASIC Pro
    Last Post: - 9th April 2007, 03:45
  4. Replies: 2
    Last Post: - 27th March 2007, 13:48
  5. Using RTC to generate long time delays
    By schlaray in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2007, 01:31
