Watt's the wattage when used on a PIC?
Results 1 to 32 of 32
    Jan 2010
    Default Re: Watt's the wattage when used on a PIC?
    Quote Originally Posted by grahamg View Post
    Dave with a 47k resistor the current at 12 volts is only about 255 Micro amps. I have used this method hundreds of times and never had any problems. The input resistor can be as high as 270K and stil works well.
    So just one resistor from the input wire going to the input pin? Does this work in even the noisy environment of vehicles?
    Sep 2010
    Las Vegas, NV
    This certainly has gone tangential to your original question. Going back to the beginning, for the 10k and the 4.7k a 1/8W current rating would be enough.
    I don't see where you said what PIC you're using. I looked at the 12F683 and see where it would be able to clamp 20mA at GPIO input. You may be able to use one resistor of sufficient size to take advantage of PIC internal circuitry to clamp that 12VDC but the datasheet shows only +.3V over VDD. To me a better way would be the voltage divider scheme you first posited.
    I hope you finally got your answers.
    Jan 2010
    My original question asked if I had it right or if I needed to make the resistors bigger. Suggestions were made to make the voltage smaller. My question is that with 2.5 volts, will that trigger the input? For a digital signal, you need a 1 or 0, or in this case, 5 volts or 0 volts. Am I missing something?
    I am using the 16F819. After reading the other article (link that was posted), I figured I would use the VD to a transistor to trigger the input. I just don't want to blow anything up.
    Thanks for your help thus far. I just want to understand it better.
    Tony
    Jan 2013
    Texas USA
    Tony,
    I did not see where you indicated which pin on the PIC you are using for input.
    As you probably already know that which pin you use matters in the answer to your question about what voltage will be recognized as a 1 (high) or 0 (low) by the PIC.
    The PIC you are using has 3 types of digital input pins, each with different thresholds for low and high. Standard Inputs, TTL Buffered inputs and Schmitt Trigger inputs.
    Table 15.4 of the DS has the Min/Max for Input Low and Input High for each of the pin types.
    You probably already knew this, but just in case.
    TABSoft
    Sep 2010
    Las Vegas, NV
    No. You don't need to make the resistor bigger if you keep the same ratios previously stated.
    Yes. IMSWO by looking at the datasheet if you're using a TTL input 2.5 V is above the level supposed to be recognized as a high. Why you don't design it for more voltage than that is curious. I'm assuming you'll have a 12v signal you'll have to schmooze so why not make it 5ish volts and not worry about ambiguity. According the datasheet, if I understand it right, with a Schmitt trigger input 2.5 v is way over a recognizable high. So pick a pin type and design for it.
    Jan 2010
    I was being conservative for any over voltages from the vehicle, hence the Zener. I just found another circuit with the same #2 VD setup as above. 2.2k to ground and 33k to the output yields 1.7 volts when 13.8 volts is applied. No cap and no Zener and on a 16F628A, RB0.
    This is all new to me as I've been using opto's. Never looked at the datasheet that way as I had never intended to connect it directly. Didn't think you could, but now I'm finding out that you can. Looking to explore it further. Right now, my pins are RB0, RB1 and RB2.
    Quebec, Canada
    Quote Originally Posted by ERMEGM View Post
    OK, let's start from the beginning... You said you had some opto that failed you. Optos are sensitive to reverse voltage and forward current must be limited too. Your circuit will be on a car so you must protect your opto. So, please forget about those resistor divider and/or zener and use an opto the proper way:
    The maximum continous current for the PC817 is 60mA. With a 1k resistor it's about 60V continous. Note the 1N4004 to protect the LED from any reverse voltage (spikes can occur). Trust me, do not try to connect your PIC to a vehicule voltage without an opto. At work I maintain our GPS tracking system which has I/O to monitor some things (sorry, don't have time to explain) and some I/O's are tied almost directly to the CPU and guess what? They fail some times!
  1. High wattage speaker circuit
    Last Post: - 5th January 2011, 21:56
  2. High Speed Serial Comm PC - PIC and PIC - PIC
    By manumenzella in forum mel PIC BASIC Pro
    Last Post: - 16th January 2007, 21:55
  3. Looking for low Wattage heater wire
    By jmgelba in forum Off Topic
    Last Post: - 21st November 2005, 18:22
