Watt's the wattage when used on a PIC?
Results 1 to 32 of 32
    May 2009
    Default Re: Watt's the wattage when used on a PIC?
    Why do you not just use a 47k resistor in series with the input pin. The internal diodes in the pic will clamp the input voltage anyway. No need for zeners or voltage dividers.
    Grahang, How are you going to limit the current?
    EN82fn
    Nov 2007
    West Covina, CA
    Quote Originally Posted by grahamg View Post
    I've used this method too but also included a small filter cap to ground at the input pin for noise.
    The DEBUG section of the PBP manual shows this as acceptable where +-25V signals are possible to the input.
    Louie
    Aug 2011
    Bad idea.
    See http://www.picbasic.co.uk/forum/showthread.php?t=15542 post #3 for the reasons.
  1. High wattage speaker circuit
    Last Post: - 5th January 2011, 21:56
  2. High Speed Serial Comm PC - PIC and PIC - PIC
    By manumenzella in forum mel PIC BASIC Pro
    Last Post: - 16th January 2007, 21:55
  3. Looking for low Wattage heater wire
    By jmgelba in forum Off Topic
    Last Post: - 21st November 2005, 18:22
