Watt's the wattage when used on a PIC?
Results 1 to 32 of 32
    Dec 2010
    Default Re: Watt's the wattage when used on a PIC?
    I'm not sure what your application is, but if it's an alarm or similar and needs to work when the vehicle is on or off, there is more to consider. You mention an input trigger, but not how you are powering the PIC. Inputs can not go higher than VDD, so this implies your voltage divider needs to be less that VDD when charging (as high as 14.4 V) and when the battery is quite discharged (about 10.8 V). You can do this with a voltage divider but there are a smaller set of values that will work. [R2/(R1+R2) = 2.85]. Finally, there's no need for zeners - a voltage divider will do it all. Zeners are useful where you need a constant voltage regardless of load. That is not your application - the load never changes if it's just the input of the PIC. You can make a zener work, but you are just wasting electricity (and of course money).
    Jan 2010
    Thanks for the replies. I don't work much with Zeners, so hence why I'm asking. I have been using optocouplers to trigger this part of the circuit, but they are expensive compared to a couple resistors, zener and cap.
    My circuit is simple; main supply goes through a voltage regulator, so the supply to the PIC is always 5 volts. This other input is just to tell the PIC that this wire has been activated. I applied the Zener to the application since any kind of over-voltage situation will increase the voltage going to the PIC. I wanted to cap it off at 5 volts.
    I chose the higher values so the PIC would read them as ones and zeros. If it was lower, I would have to do an ADC, right? I've modified my circuit design from the opto to the VD. If I did an ADC, I would have to reroute the traces to the ADC pins, and that's a cumbersome redo of my board.
    My comments about the load was stating that I just couldn't have the supply come in and go straight to the PIC and have the Zener regulate it to 5 volts. It has to pass through a resistor first, or else the Zener would blow and then the PIC. Does that sound right?
    Also, I am aware of the typical VD circuit where you have two resistors in series, supply is on one side of R1 and ground is on the other side of R2 and you tap in between R1 and R2 to get your divided circuit. I have found two such circuits with the same layout, but instead, Vin and Vout are reversed. The supply is applied between R1 and R2 and while R2 goes to ground, the other side of R1 is your output.
    Trying to use the same formula but solving for the other unknown variable using algebra does not work. Is there a different formula for this method? In this instance, R2 is 10k and R1 is 100K.
    All I want to do is trigger a pin on the PIC to let it know an input has power applied to it. There's optos, VD and transistors that can be used. Would a transistor be simpler to use in this instance?
    Tony
    Dec 2010
    You can make any of the methods you discuss work, but to reiterate, the simplest is a straight resistor divider. R1 goes from the ~12V high source to the PIC pin. R2 goes from the pic pin to ground.
    Then: Vpin = vsource*(R2/(R1+R2)) As I stated above, the biggest Vsource you will see is 14.4V. The biggest Vpin you can stand is 5V.
    so 14.4=5*(R2/(R1+R2)).
    So 14.4/5 =R2/(R1+R2)
    so 2.88 =R2/(R1+R2)
    Now go hunting for the standard resistor values that when plugged into R1 and R2 = 2.88
    Look for values between 1K and 100K
    You probably won't find an exact match (43K & 15K might be close enough), although to be as safe as possible, err on R1 being just a bit higher than the ration implies.
    Sep 2010
    Las Vegas, NV
    I'm just wondering what a voltage divider plus a zener would cost opposed to a voltage regulator to limit the input.
    Yes, most zeners must have current limiting resistor. I say most cause as soon as I say all then someone will post one that doesn't.
    This sound like you're trying to make a logic gate for the PIC. There 's a good example in the PBP manual of how to do this.
    You could use a transistor with the collector using your 5V supply and voltage divide the input to the base of the transistor. You'd still need a pull down resistor so you're not saving much. You'd end up with a higher parts count but not necessarily lower cost or reliability. Optos in essence are transistors and you've said your not having much luck with them. Though a 2n2222a and a couple of resistors aren't very expensive. If you wanted to go this route it's probably cheaper and easier to do the voltage regulator at the input.
    I'm sorry to say math is math and it's been done here already.
    Disclaimer: I've not seen your schematic and I'm often not good with word pictures. If I've botched something I apologize.
    Dec 2010
    To clarify - power supply for the PIC is not under discussion. This is all about scaling signals to not exceed VDD (5V).
    Jan 2010
    That is correct. The PIC will be powered. I want it to be able to see an input when 12 volts is applied. The program is busy doing a bunch of other things, but it will check that input like this; if input1 = 1 then do this, if input1 = 0, then don't do this.
    Jan 2010
    Quote Originally Posted by AvionicsMaster1 View Post
    Here is what I am speaking of. The left schematic is the one we are all talking about. The right schematic is one that I have seen a couple of times now. Still a high value on the top and smaller one on the bottom. What would be the formula for this bad boy?
    Sep 2010
    Las Vegas, NV
    For your current way diagram the output would be the voltage divided value at the point labeled out.
    For your other way diagram, it depends. If you hooked a meter to the out without any other circuitry attached to the out you'd get whatever the +in voltage is applied. If there is other circuitry attached and there is current flow in the circuit you'd get some voltage dropped across the top resistor. It might be the whole +in but probably less than full voltage supplied. Even if the output is grounded you wouldn't get a voltage divided value across either resistor you'd get power divided across two resistors. Something altogether different.
  1. High wattage speaker circuit
    Last Post: - 5th January 2011, 22:56
  2. High Speed Serial Comm PC - PIC and PIC - PIC
    By manumenzella in forum mel PIC BASIC Pro
    Last Post: - 16th January 2007, 22:55
  3. Looking for low Wattage heater wire
    By jmgelba in forum Off Topic
    Last Post: - 21st November 2005, 19:22
