how to "shift" a data into led matrix display ?
Results 1 to 15 of 15
    Default Re: how to "shift" a data into led matrix display ?
    No I'm definitely not but thanks anyway :-)
    Might be interesting to put the bitmap data in FLASH instead of RAM (well, you're already putting it in FLASH but then loading it to RAM....). It probably won't be as straight forward but should be doable, perhaps using READCODE. Then again, if it works and does what it needs to there no need to bother....
    Yes I will have to read data from EEPROM, since this is just short demo and I need a lot of data, speaking in pixels, it will be 200*5*7, quite much for solely PIC to handle.
    Here's the sample video how it works:
    But have no idea how to handle these parasitic lights, if I increase DRO variable, then these half lit segments go away, but then flicker is noticeable.
    Checked in details, these parasitic lit segments are on even with larger DRO values. Tried to disable internal pull-up resistors - no change. Even tried to interlace update, do a 1,3,5,7,2,4,6 row sequence - no difference.
    Solved, just added this to each line draw end routine:
    c1=0
    c2=0
    c3=0
    c4=0
    c5=0
  1. Replies: 0
    Last Post: - 14th November 2013, 04:32
  2. Replies: 3
    Last Post: - 15th October 2012, 09:06
  3. Adding data to an "array" in ASM
    Last Post: - 22nd November 2009, 04:21
  4. Replies: 2
    Last Post: - 22nd January 2008, 15:25
  5. LED "capacitance" won't get lower
    Last Post: - 3rd May 2007, 21:31
