how to "shift" a data into led matrix display ?
Results 1 to 15 of 15
    Default how to "shift" a data into led matrix display ?
    Hello.
    I have 5x7 led matrix display connected to 16F876. I want to display some text on, scrolling from right to left. I have prepared a set of data, which has 1 where dot should be lit, and 0 - where it should not. This data looks like array of bits, with length of 64 bits and height of 8 bits. In "normal" basic, I can use MID$(VAR, START, LENGTH) variable to "read" through te array, but how can I do this in PBP ?
    Apr 2011
    Welches, Oregon
    Default Re: how to "shift" a data into led matrix display ?
    I use a 5 element byte array: Read one byte from data and output to display vertically in column 5 (rightmost). Loop several times... Move the byte in column five to array element four (the next column to the left) and load the next byte into element 5. Loop several times... Continue shifting each byte to the left as you load new bytes on the right.
    So... each byte of data represents one column of a 5x7 alphanumeric character (you're only using 7 of the 8 bits), Read all five columns, then put a 0 in column 5 (for the space between letters) then read the next five columns...
    Yes but how put data in code, in normal basic I would do a thing like this:
    R1$="000101110101010101010101" : whole data for row 1
    R2$="110101010101111110000011" : whole data for row 2
    and so on
    then I would make a loop:
    FOR A=0 TO 64-5
    LINE1$=MID$(R1$,A,5) ' read 5 pixels from row variable and shift it left on next read
    LINE2$=MID$(R2$,A,5) ' next lines and so on
    GOSUB DISPLAY
    NEXT A
    OK, trying to do it with arrays:
    line1 var bit[12]
    arraywrite line1,[%0,%1,%1,%1,%0,%0,%0,%0,%1,%1,%1,%0]
    arraywrite gives error, while line1[0]=1 works fine
    is there a way to use arraywrite with bit array?
    Don't use a bit-array, use a BYTE-array instead.
    Line1 VAR BYTE [8]
    ArrayWrite Line1, [%10101010, %10101010, %10101010, %10101010, %10101010, %10101010, %10101010, %10101010]
    To access an individual bit in the above array you can use the format
    myBit VAR bit
    i VAR BYTE
    myBit = Line1.0[i]       ' Where i of course is the index, or bit number in the array.
    Using bit arrays will make adding of information simpler - it can be visualized during entering the graphical data. Say I want to draw a circle, in BIT, it will look like
    001100
    010010
    010010
    001100
    Here is the working code, but it has two problems:
    1. It is dead huge - 3.3k, so had to use 16F876A
    2. If I decrease refresh time, for display to less flicker, some non-needed pixels also come on, but at lower brightness. I suspect, this is because MCU isn't giving "true" gnd connection?
    L1 var PORTB.0
    L2 VAR PORTB.1
    L3 VAR PORTB.2
    L4 VAR PORTB.3
    L5 VAR PORTB.4
    L6 VAR PORTB.5
    L7 VAR PORTC.1
    C1 VAR PORTC.5
    C2 VAR PORTC.4
    C3 VAR PORTC.6
    C4 VAR PORTC.2
    C5 VAR PORTC.3
    DRO VAR BYTE 'char redraw timing
    SVLA VAR BYTE    'char scroll value
    SVLA=0
    TRIALI VAR BYTE 'char holdon timing
    'define arrays
    line1 var bit[12]
    line2 var bit[12]
    line3 var bit[12]
    line4 var bit[12]
    line5 var bit[12]
    line6 var bit[12]
    line7 var bit[12]
    'write data to array
    'line 1
    line1[0]=0
    line1[1]=1
    line1[2]=1
    line1[3]=1
    line1[4]=0
    line1[5]=0
    line1[6]=0
    line1[7]=1
    line1[8]=1
    line1[9]=1
    line1[10]=0
    line1[11]=0
    'line 2
    line2[0]=1
    line2[1]=0
    line2[2]=0
    line2[3]=0
    line2[4]=1
    line2[5]=0
    line2[6]=1
    line2[7]=0
    line2[8]=0
    line2[9]=0
    line2[10]=1
    line2[11]=0
    'line 3
    line3[0]=0
    line3[1]=0
    line3[2]=0
    line3[3]=0
    line3[4]=1
    line3[5]=0
    line3[6]=0
    line3[7]=0
    line3[8]=0
    line3[9]=0
    line3[10]=1
    line3[11]=0
    'line 4
    line4[0]=0
    line4[1]=1
    line4[2]=1
    line4[3]=1
    line4[4]=1
    line4[5]=0
    line4[6]=0
    line4[7]=0
    line4[8]=0
    line4[9]=0
    line4[10]=1
    line4[11]=0
    'line 5
    line5[0]=1
    line5[1]=0
    line5[2]=0
    line5[3]=0
    line5[4]=1
    line5[5]=0
    line5[6]=1
    line5[7]=0
    line5[8]=0
    line5[9]=0
    line5[10]=1
    line5[11]=0
    'line 6
    line6[0]=1
    line6[1]=0
    line6[2]=0
    line6[3]=0
    line6[4]=1
    line6[5]=0
    line6[6]=1
    line6[7]=0
    line6[8]=0
    line6[9]=0
    line6[10]=1
    line6[11]=0
    'line 7
    line7[0]=0
    line7[1]=1
    line7[2]=1
    line7[3]=1
    line7[4]=0
    line7[5]=0
    line7[6]=0
    line7[7]=1
    line7[8]=1
    line7[9]=1
    line7[10]=0
    line7[11]=0
    DRO=2   'time refresh set
    'turn off display
    HIGH L1
    HIGH L2
    HIGH L3
    HIGH L4
    HIGH L5
    HIGH L6
    HIGH L7
    LOW C1
    LOW C2
    LOW C3
    LOW C4
    LOW C5
    cikleri:
    FOR SVLA=0 TO 6 'scroll through the array
    FOR TRIALI=1 TO 30  'time to show individual char
    low L1 'ENABLE LINE 1
    IF LINE1[0+SVLA]=1 THEN
    HIGH C1
    LOW C1
    IF LINE1[1+SVLA]=1 THEN
    HIGH C2
    LOW C2
    IF LINE1[2+SVLA]=1 THEN
    HIGH C3
    LOW C3
    IF LINE1[3+SVLA]=1 THEN
    HIGH C4
    LOW C4
    IF LINE1[4+SVLA]=1 THEN
    HIGH C5
    LOW C5
    PAUSE DRO
    HIGH L1
    low L2 'ENABLE LINE 2
    IF LINE2[0+SVLA]=1 THEN
    HIGH C1
    LOW C1
    IF LINE2[1+SVLA]=1 THEN
    HIGH C2
    LOW C2
    IF LINE2[2+SVLA]=1 THEN
    HIGH C3
    LOW C3
    IF LINE2[3+SVLA]=1 THEN
    HIGH C4
    LOW C4
    IF LINE2[4+SVLA]=1 THEN
    HIGH C5
    LOW C5
    PAUSE DRO
    HIGH L2
    low L3 'ENABLE LINE 3
    IF LINE3[0+SVLA]=1 THEN
    HIGH C1
    LOW C1
    IF LINE3[1+SVLA]=1 THEN
    HIGH C2
    LOW C2
    IF LINE3[2+SVLA]=1 THEN
    HIGH C3
    LOW C3
    IF LINE3[3+SVLA]=1 THEN
    HIGH C4
    LOW C4
    IF LINE3[4+SVLA]=1 THEN
    HIGH C5
    LOW C5
    PAUSE DRO
    HIGH L3
    low L4 'ENABLE LINE 4
    IF LINE4[0+SVLA]=1 THEN
    HIGH C1
    LOW C1
    IF LINE4[1+SVLA]=1 THEN
    HIGH C2
    LOW C2
    IF LINE4[2+SVLA]=1 THEN
    HIGH C3
    LOW C3
    IF LINE4[3+SVLA]=1 THEN
    HIGH C4
    LOW C4
    IF LINE4[4+SVLA]=1 THEN
    HIGH C5
    LOW C5
    PAUSE DRO
    HIGH L4
    low L5 'ENABLE LINE 5
    IF LINE5[0+SVLA]=1 THEN
    HIGH C1
    LOW C1
    IF LINE5[1+SVLA]=1 THEN
    HIGH C2
    LOW C2
    IF LINE5[2+SVLA]=1 THEN
    HIGH C3
    LOW C3
    IF LINE5[3+SVLA]=1 THEN
    HIGH C4
    LOW C4
    IF LINE5[4+SVLA]=1 THEN
    HIGH C5
    LOW C5
    PAUSE DRO
    HIGH L5
    low L6 'ENABLE LINE 6
    IF LINE6[0+SVLA]=1 THEN
    HIGH C1
    LOW C1
    IF LINE6[1+SVLA]=1 THEN
    HIGH C2
    LOW C2
    IF LINE6[2+SVLA]=1 THEN
    HIGH C3
    LOW C3
    IF LINE6[3+SVLA]=1 THEN
    HIGH C4
    LOW C4
    IF LINE6[4+SVLA]=1 THEN
    HIGH C5
    LOW C5
    PAUSE DRO
    HIGH L6
    low L7 'ENABLE LINE 7
    IF LINE7[0+SVLA]=1 THEN
    HIGH C1
    LOW C1
    IF LINE7[1+SVLA]=1 THEN
    HIGH C2
    LOW C2
    IF LINE7[2+SVLA]=1 THEN
    HIGH C3
    LOW C3
    IF LINE7[3+SVLA]=1 THEN
    HIGH C4
    LOW C4
    IF LINE7[4+SVLA]=1 THEN
    HIGH C5
    LOW C5
    PAUSE DRO
    HIGH L7
    NEXT
    PAUSE 5
    NEXT
     'ROTATE BACK
    FOR SVLA=6 TO 0 STEP -1
    FOR TRIALI=1 TO 30
    HIGH C1
    LOW C1
    HIGH C2
    LOW C2
    HIGH C3
    LOW C3
    HIGH C4
    LOW C4
    HIGH C5
    LOW C5
    PAUSE DRO
    HIGH L1
    HIGH C1
    LOW C1
    HIGH C2
    LOW C2
    HIGH C3
    LOW C3
    HIGH C4
    LOW C4
    HIGH C5
    LOW C5
    PAUSE DRO
    HIGH L2
    HIGH C1
    LOW C1
    HIGH C2
    LOW C2
    HIGH C3
    LOW C3
    HIGH C4
    LOW C4
    HIGH C5
    LOW C5
    PAUSE DRO
    HIGH L3
    HIGH C1
    LOW C1
    HIGH C2
    LOW C2
    HIGH C3
    LOW C3
    HIGH C4
    LOW C4
    HIGH C5
    LOW C5
    PAUSE DRO
    HIGH L4
    HIGH C1
    LOW C1
    HIGH C2
    LOW C2
    HIGH C3
    LOW C3
    HIGH C4
    LOW C4
    HIGH C5
    LOW C5
    PAUSE DRO
    HIGH L5
    HIGH C1
    LOW C1
    HIGH C2
    LOW C2
    HIGH C3
    LOW C3
    HIGH C4
    LOW C4
    HIGH C5
    LOW C5
    PAUSE DRO
    HIGH L6
    HIGH C1
    LOW C1
    HIGH C2
    LOW C2
    HIGH C3
    LOW C3
    HIGH C4
    LOW C4
    HIGH C5
    LOW C5
    PAUSE DRO
    HIGH L7
    NEXT
    PAUSE 5
    NEXT
    GOTO CIKLERI
    Double post, moderator please remove if possible.
    Wow, yeah, that's some pretty ineffecient code - no offense.
    * Try and never write the same snippet of code more than once, if more than a very simple command and it's needed more than a single time make it a subroutine. You have a VERY long piece of code copy/pasted twice (as far as I can see).
    * Avoid using HIGH/LOW, set the TRIS registers to the correct value and write directly to the PORT register (or LAT register on 18F parts). Doing that single thing saves 540 words in your program.
    * Instead of the IF/THEN thing for each bit just do C1 = LINE1[0+SVLA] etc.
    Something like:
    ' Variables etc as before but make sure to set TRIS registers properly!
    'turn off display
    L1 = 1
    L2 = 1
    L3 = 1
    L4 = 1
    L5 = 1
    L6 = 1
    L7 = 1
    C1 = 0
    C2 = 0
    C3 = 0
    C4 = 0
    C5 = 0
    cikleri:
        GOSUB ScanIt
        PAUSE 5
    NEXT
    'ROTATE BACK
        GOSUB ScanIt
        PAUSE 5
    NEXT
    GOTO CIKLERI
    ScanIt:
        FOR TRIALI = 0 TO 29  'time to show individual char
            L1 = 0 'ENABLE LINE 1
            C1 = LINE1[0+SVLA]
            C2 = LINE1[1+SVLA]
            C3 = line1[2+SVLA]
            C4 = line1[3+SVLA]
            C5 = line1[4+SVLA]
            PAUSE DRO
            L1 = 1
            L2 = 0 'ENABLE LINE 2
            C1 = LINE2[0+SVLA]
            C2 = LINE2[1+SVLA]
            C3 = line2[2+SVLA]
            C4 = line2[3+SVLA]
            C5 = line2[4+SVLA]
            PAUSE DRO
            L2 = 1
            L3 = 0 'ENABLE LINE 3
            C1 = LINE3[0+SVLA]
            C2 = LINE3[1+SVLA]
            C3 = line3[2+SVLA]
            C4 = line3[3+SVLA]
            C5 = line3[4+SVLA]
            PAUSE DRO
            L3 = 1
            L4 = 0 'ENABLE LINE 4
            C1 = LINE4[0+SVLA]
            C2 = LINE4[1+SVLA]
            C3 = line4[2+SVLA]
            C4 = line4[3+SVLA]
            C5 = line4[4+SVLA]
            PAUSE DRO
            L4 = 1
            L5 = 0 'ENABLE LINE 5
            C1 = LINE5[0+SVLA]
            C2 = LINE5[1+SVLA]
            C3 = line5[2+SVLA]
            C4 = line5[3+SVLA]
            C5 = line5[4+SVLA]
            PAUSE DRO
            L5 = 1
            L6 = 0 'ENABLE LINE 6
            C1 = LINE6[0+SVLA]
            C2 = LINE6[1+SVLA]
            C3 = line6[2+SVLA]
            C4 = line6[3+SVLA]
            C5 = line6[4+SVLA]
            PAUSE DRO
            L6 = 1
            L7 = 0 'ENABLE LINE 7
            C1 = LINE7[0+SVLA]
            C2 = LINE7[1+SVLA]
            C3 = line7[2+SVLA]
            C4 = line7[3+SVLA]
            C5 = line7[4+SVLA]
            PAUSE DRO
            L7 = 1
        NEXT
    Went from 3161 to 775 words and that's just a first go.
    I'm sure the rest can be handled with some array manipulation and indexing to reduce the size even further but I don't have time right now.
    It is not twice, it just scrolls right to left and left to right. Thanks a lot, will have a look!
    As far as I can see the FOR TRIALI=1 TO 30 / NEXT loop (which is the bulk of the code) is repeated twice. One time for right-to-left and one time for left-to-right.
    Fitted your code, you're genius!
    now even with double amount of bitmap data added, whole code is only 920 bytes!
    No I'm definitely not but thanks anyway :-)
    Might be interesting to put the bitmap data in FLASH instead of RAM (well, you're already putting it in FLASH but then loading it to RAM....). It probably won't be as straight forward but should be doable, perhaps using READCODE. Then again, if it works and does what it needs to there no need to bother....
    Yes I will have to read data from EEPROM, since this is just short demo and I need a lot of data, speaking in pixels, it will be 200*5*7, quite much for solely PIC to handle.
    Here's the sample video how it works:
    But have no idea how to handle these parasitic lights, if I increase DRO variable, then these half lit segments go away, but then flicker is noticeable.
    Checked in details, these parasitic lit segments are on even with larger DRO values. Tried to disable internal pull-up resistors - no change. Even tried to interlace update, do a 1,3,5,7,2,4,6 row sequence - no difference.
    Solved, just added this to each line draw end routine:
    c1=0
    c2=0
    c3=0
    c4=0
    c5=0
  1. Replies: 0
    Last Post: - 14th November 2013, 03:32
  2. Replies: 3
    Last Post: - 15th October 2012, 08:06
  3. Adding data to an "array" in ASM
    Last Post: - 22nd November 2009, 03:21
  4. Replies: 2
    Last Post: - 22nd January 2008, 14:25
  5. LED "capacitance" won't get lower
    Last Post: - 3rd May 2007, 20:31
