Simple way to adjust interrupt speed in DT_INTS-14 ?
Results 1 to 4 of 4
    Default Simple way to adjust interrupt speed in DT_INTS-14 ?
    Hello.
    I'm using this sample code on 16F628A:
    ;----[16F628A Hardware Configuration]-------------------------------------------
    #IF __PROCESSOR__ = "16F628A"
      #DEFINE MCU_FOUND 1
    cfg = _INTOSC_OSC_NOCLKOUT    ; INTOSC oscillator: I/O function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN
    cfg&= _WDT_ON                 ; WDT enabled
    cfg&= _PWRTE_OFF              ; PWRT disabled
    cfg&= _MCLRE_OFF              ; RA5/MCLR/VPP pin function is digital input, MCLR internally tied to VDD
    cfg&= _BODEN_ON               ; BOD enabled
    cfg&= _LVP_OFF                ; RB4/PGM pin has digital I/O function, HV on MCLR must be used for programming
    cfg&= DATA_CP_OFF             ; Data memory code protection off
    cfg&= _CP_OFF                 ; Code protection off
      __CONFIG cfg
    #ENDIF
    ;----[Verify Configs have been specified for Selected Processor]----------------
    ;       Note: Only include this routine once, after all #CONFIG blocks
    #IFNDEF MCU_FOUND
      #ERROR "No CONFIGs found for [" + __PROCESSOR__ +"]"
    #ENDIF
    PCON=%00001010  'set int osc to 4mhz
     LED1   VAR  PORTB.1
     wsave2 var byte $120 SYSTEM
     wsave1 VAR BYTE $A0 SYSTEM
     wsave VAR BYTE $20 SYSTEM
    INCLUDE "DT_INTS-14.bas"     ' Base Interrupt System
    T1CON = $01                ; Prescaler = 0, TMR1ON
      PAUSE 1
    GOTO Main
    ToggleLED1:
         TOGGLE LED1
    @ INT_RETURN
    By changing T1CON=$01 now I have about 7hz interrupt speed, but I want to make it faster.
    Darrel's page lists another code for changing interrupt speeds, which is complex and I don't need that much code space to be wasted. So is it possible to modify above code, to make interrupt work say at 20, 50, 400hz speed?
    If I understand properly, specific values are to be written to TMR1L and TMR1H registers each time interrupt occurs, right? but how to do that and which values?
    Default Re: Simple way to adjust interrupt speed in DT_INTS-14 ?
    TMR1 generates an interrupt when it overflows from $FFFF to $0000.
    If your clock is 4MHz and TMR1 prescaler is 1:1 then TMR1 will "tick" at 1MHz, ie it'll increment one count every us.
    If you just let it freerun it'll interrupt once every 65536us or 0.065536s or 15.25Hz. Since you're toggling the LED in your ISR you get ~7.6Hz.
    If you want it to interrupt at 400Hz (2500us) you need preload TMR1 to 65536-2500=63036 so that it takes 2500 "ticks" instead of 65536 before it interrupts. And yes, you need to do it every time or it will just start over from 0. If you want to be accurate you ADD the preload value TO the current value of TMR1 as that will account for any interrupt latency. If you want to be even more accurate you need to add a couple of counts TO the preload value since it actually takes some time to execute the instructions that preloads the timer while it's stopped.
    Temp VAR WORD
    ToggleLED1:
      T1CON.0 = 0
      Temp.HighWord = TMR1H   ' Get current value of TMR1
      Temp.LowWord = TMR1L
      Temp = Temp + Preload     ' Add the preload, this will account for the interrupt latency
      T1CON.0 = 1                ' Restart TMR1
    TOGGEL LED1
    @ INT_RETURN
    If a periodic interrupt is what you want then TMR2 might be a better option. It counts up from 0 and interrupts when its value equals PR2 and then automatically starts over from 0. No need for manually preloading but it's only 8 bits wide with a limited prescaler.
    you will find links on this forum for a utility called PicMultiCalc it will assist you in finding tmr1h/l values for your chosen int rate.
    then in your isr
    stop the timer
    load the new tmrl/h values
    restart the timer
    easy as pi
    Thanks, added the values, and used scope and "try and see" method to find required values
  1. RTCC Interrupt for DT_INTS-18.bas
    By readitaloud in forum mel PIC BASIC Pro
    Last Post: - 29th November 2013, 22:33
  2. USART TX Interrupt problem. (DT_INTS)
    By HenrikOlsson in forum mel PIC BASIC Pro
    Last Post: - 17th August 2011, 12:34
  3. Interrupt Driven Serial Input using DT_Ints?
    By circuitpro in forum mel PIC BASIC Pro
    Last Post: - 12th August 2010, 02:40
  4. Serial Interrupt with DT_Ints - Error
    By gadelhas in forum mel PIC BASIC Pro
    Last Post: - 11th August 2010, 13:26
  5. 16F767 Exteranl Interrupt with DT_INTS
    By exelanoz in forum mel PIC BASIC Pro
    Last Post: - 31st May 2008, 10:12
