pic16f72 spi slave - ss pin function
Results 1 to 7 of 7
    Default pic16f72 spi slave - ss pin function
    I'm trying to figure out a method of using the spi module in slave mode , but I don't quite get what function the ss pin has . the data sheet indicates that it resets the spi module (why ? what good does that do ?) .
    I really want it to inform the program that a spi request needs to be answered (ie an interrupt) . I have used up all the interrupt pins and don't want to start again pcb wise and polling the pin seems inefficient and the chips have pretty limited resources 128 bytes ram 2k flash .I think I'm missing something here , has anybody got any tips on a good approach for an interrupt driven spi slave device.
    I have got a whole bunch of these bourne absolute (8 bit grey scale) rotary encoders and a pile of pretty useless pic16f72's that combined might be useful.
    Default Re: pic16f72 spi slave - ss pin function
    Hi Richard,
    I've never used the (M)SSP module in SPI Slave mode but here's the way I understand it:
    The SS\ pin, when enabled is an active low input. When high (inactive) the (M)SSP module is held in reset meaning no data will be clocked in.
    Only when the SS\ pin is low (active) will data actually be clocked in. This is of course so you can have multiple slaves on the bus and individually selecting which one to talk to by pulling the specific slaves SS\ line low - as you would with any SPI device pretty much.
    In slave mode, the SSPIF (PIR1.3) gets set when 8 bits have been shifted in, look at figures 9.3 and 9.4, if SSPIE is set and interrupts enabled an interrupt will be tripped. The SSPIF flag needs to be cleared by your interrupt service routine.
    hi henrik
    that makes good sense , I can follow that . if I preload data into spbuff am I correct in thinking that as the master clocks its byte in the data already in spbuff would be clocked out at the same time , I would then get the irq and could then process the received byte and reply to it by reloading spbuff with data and letting the master clock it out.
    seems like a plan
    Hi Richard,
    Yes, I think that will work. When you load SSPBUF it's content will be transparently transfered to the actual shift register (SSPSR, which you can't access "manually") and then just sit there.
    When the SS pin on the slave goes low and clock pulses appears on the SCK pin the data in SSPSR get shifted out thru the SDO pin while at the same time SSPSR gets "refilled" from the other end by the data on the SDI pin.
    If the SS pin goes high in the middle of the transfer the data in SSPBUF will be untouched. Only when 8 bits have been shifted out/in the data now in SSPSR gets tranfered to SSPBUF where you can grab it and SSPIF gets set.
    At least that's how I interpret it.
    I will give it a go and reply with results , but not tonight its nearly bed time
    On the ISD chips I use, the SS pin is a chip select/enable so you can parallel multiple chips and select which one to enable.
    Works like a dream, for 1 byte transfers
    '*  Name    : are.BAS                                           *
    '*  Notice  : Copyright (c) 2013 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 1/17/2013                                         *
    '*  Notes   :    spi read of bourne rotary encoder              *
    '*          :    16f72                                          *
    cfg = _HS_OSC
    cfg&= _WDT_ON
    cfg&= _PWRTE_ON
    cfg&= _CP_OFF
    cfg&= _BOREN_ON
      __CONFIG cfg
    include "dt_ints-14.bas"
    include "REENTERPBP.bas"
    asm
    INT_LIST macro
          INT_HANDLER  SSP_INT, _spo, asm,YES
          INT_CREATE
          INT_ENABLE SSP_INT
         wsave   VAR BYTE    $20     SYSTEM      ' location for W if in bank0
    ;wsave   VAR BYTE    $70     SYSTEM      ' alternate save location for W
    wsave1  VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    'wsave2  VAR BYTE    $120    SYSTEM      ' location for W if in bank2
    'Wsave3  VAR BYTE    $1A0    SYSTEM      ' location for W if in bank3
      pos     var byte
      old_pos var byte
      mint    var portc.0
      tmp     var byte
       DEFINE OSC 20
     adcon1=6
     trisc=%11011110
     option_reg.7=0
     mint=1
     SSPSTAT.6=1
     sspcon.5=1
     sspcon.4=0
     sspcon.2=1
     pir1.3=0
     PIE1.3=1
     INTCON=$c0
     gosub getp
     old_pos=pos
     pause 2000
    MAIN
    gosub getp
    if (pos != old_pos )&& (mint)   then
      old_pos=pos
      sspbuf=pos;
      mint=0;
    GOTO MAIN
    GETP:
    tmp= (porta&$f)|((portb&$f)<<4)
    Lookdown tmp,[$7F,$3F,$3E,$3A,$38,$B8,$98,$18,$08,$48,$49,$4D,$4F,$0F,$2F,$AF,$BF,$9F,$1F,$1D,$1C,$5C,$4C,$0C,$04,$24,$A4,$A6,$A7,$87,$97,$D7,$DF,$CF,$8F,$8E,$0E,$2E,$26,$06_
    ,$02,$12,$52,$53,$D3,$C3,$CB,$EB,$EF,$E7,$C7,$47,$07,$17,$13,$03,$01,$09,$29,$A9,$E9,$E1,$E5,$F5,$F7,$F3,$E3,$A3,$83,$8B,$89,$81,$80,$84,$94,$D4,$F4,$F0,$F2,$FA,$FB,$F9,$F1,$D1,_
    $C1,$C5,$C4,$C0,$40,$42,$4A,$6A,$7A,$78,$79,$7D,$FD,$FC,$F8,$E8,$E0,$E2,$62,$60,$20,$21,$25,$35,$3D,$3C,$BC,$BE,$FE,$7E,$7C,$74,$70,$71,$31,$30,$10,$90,$92,$9A,$9E,$1E,$5E,$5F],Pos
    spo:
     mint=1;
     pir1.3=0
    @ INT_RETURN
  1. PIC24 clear SPI slave FIFO
    Last Post: - 18th January 2015, 00:43
  2. question about the pin to pin connections on a SPI interface
    By wdmagic in forum mel PIC BASIC Pro
    Last Post: - 4th January 2013, 13:03
  3. SPI, SCK Pin set up
    By Hylan in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2012, 06:23
  4. I2C function... clock pin?
    By Qacer in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2006, 22:09
  5. Need Help with PIC as SPI Slave
    By PICtron in forum Serial
    Last Post: - 16th August 2005, 19:34
