Did you know that... Dallas 1-Wire search trick/work around
Results 1 to 1 of 1
Threaded View
    Oct 2009
    Utah, USA
    Default Did you know that... Dallas 1-Wire search trick/work around
    Hey group,
    Just thought I'd relate my findings with respect to the 1-wire protocol.
    I have a project that uses two 1-wire devices. A DS18b20 temperature sensor and a DS2417 Real Time Clock. I needed both devices to share the same PIC pin.
    So I spent much time working on the 1-wire discovery code that I found here... http://www.picbasic.co.uk/forum/showthread.php?t=3671
    which actually works quite well (thanks jimbab!!)
    Then after studying the different command sets for each device I realized that there was no overlap between them.
    So I have tested and verified that I can still use the $CC (skip ROM) command and talk to each sensor as though it was the only one on the line because the Function command sets for each device don't overlap..
    I have been able to read and write to both sensors on the same line, no problems (so far).
    I was planning on using the search routine so that I could swap out 1-wire devices and have the code learn the address of the new device without my intervention. But now I don't need to.
    Now keep in mind this only applies if the two (or more??) devices don't share any function commands.
    I had even called Dallas/Maxim to inquire if there was a way to just specify the family code to access each device without having to include the full 64 bit ROM code. The engineer told me I would have to include the full address.
    This simplifies my code quite a bit. Sweet!
    Dwight
  1. 1 Wire Search Routine
    By Dave in forum Code Examples
    Last Post: - 4th March 2016, 08:39
  2. Dallas one-wire question
    By Travin77 in forum mel PIC BASIC Pro
    Last Post: - 7th May 2006, 18:32
  3. Dallas 1-wire search Routine
    By jimbab in forum Code Examples
    Last Post: - 7th April 2006, 17:14
  4. Interfacing with Dallas 1-Wire weather station
    By bcd in forum mel PIC BASIC Pro
    Last Post: - 1st January 2006, 12:44
  5. Dallas 1-Wire CRC Calculation
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 15th August 2005, 10:43
