PIC16F886 not running.
Results 1 to 20 of 20
    Jan 2015
    Default Re: PIC16F886 not running.
    The circuit works. If i do the same thing in GCB, I have no problem. Its just to get PBP to do the same thing. But the config solved most of it. just a few things left, like make the analog to digitla outputs. But I hope to solve that tonight.
    Im using a AN589 programmer, and its works great with code from GCB.
    I did read the first chapters, but I just couldnt get the PIC started.
    Somehow the portb is solved too. I changed PortB to portb, programmed it, and now, for some undefined reason. it works....
    After that, I can use PortB (with caps) again and it works!!!
    Dont know why, dont care for the moment, im up and running...
    Thank you all for all the help.
    Ill be back if something else wont work for me.. :-)
    Search the forum for ALLDIGITAL. It will help you determine what you need to make all pins digital.
  1. Replies: 8
    Last Post: - 28th January 2014, 15:21
  2. Config problem PIC16F886
    By Bosse in forum mel PIC BASIC Pro
    Last Post: - 2nd January 2014, 07:24
  3. pic16f886
    By NURULHAIZA in forum General
    Last Post: - 21st May 2010, 09:09
  4. PIC16F886 Register Settings
    By aherrera in forum mel PIC BASIC Pro
    Last Post: - 29th July 2009, 18:52
  5. Pic16f886
    By Larry in forum mel PIC BASIC Pro
    Last Post: - 10th October 2008, 23:40
